Question on optimization and limits
3 replies · 3K views
semc
You are designing a rectangular poster to contain 50 cm2 of printing with margins of
4 cm each at the top and bottom and 2 cm at each side. What overall dimensions will
minimize the amount of paper used?
What i did was let the length and breath of the whole poster to be x and y so the area would be 50=(x-4)*(y-8) and perimeter=2(x-4)+2(y-8). Equate the area into the perimeter and differentiate Perimeter wrt y. However i got x=y which means its the maximum area?
Limit as x tends to 0 [tex]\frac{e^x + e^-^x -2}{1-cos2x}[/tex]
Applied Hopital rule once and got 0/2 however answer is 1/2. Am i correct?
What does it mean to "equate the area into the perimeter"?
I would approach this in a different way by letting w and h represent the width and height, respectively of the printed area. From these definitiions you get wh = 50.
Now what you want to do is to minimize the area (not perimeter) of the overall piece of poster paper, so you want to minimize A = (w + 4)(h + 8). Use the other relationship to rewrite A as a function of only one variable, and then do your calculus magic.
The stuff below seems to be unrelated to this problem.
for the 2nd problm... apply it once again...it will give the correct answer
after applyin it once it still gives 0/0 form...
