Question on the equation for the period of a pendulum
  • Thread starter Thread starter channel1
    Pendulum Period
The discussion centers on the equation for the period of a pendulum, T=2π√(I/mgL), specifically questioning the role of mg in the equation. Participants clarify that mg represents the gravitational force (Fg) acting on the pendulum and cannot be arbitrarily replaced by the sum of gravitational and electric forces (Fg + Fe) without a valid justification. The conversation emphasizes the importance of adhering to established physics principles, such as Newton's Laws and Coulomb's Law, when attempting to modify the equation. Additionally, the method of images in electrostatics is mentioned as a relevant concept for understanding the effects of a charged sheet on the pendulum's motion.
  • Understanding of pendulum motion and the formula T=2π√(I/mgL)
  • Familiarity with gravitational force (Fg) and electric force (Fe)
  • Basic knowledge of Newton's Laws of Gravitation
  • Concept of charge density and its implications in electrostatics
  • Research the method of images in electrostatics for a deeper understanding of charge interactions.
  • Study the derivation and implications of the effective gravitational force (geff) in pendulum equations.
  • Explore the differences between conducting and non-conducting charged sheets in electrostatics.
  • Review the principles of small-angle approximations in pendulum motion analysis.
Students studying physics, particularly those focusing on mechanics and electrostatics, as well as educators seeking to clarify concepts related to pendulum dynamics and force interactions.
channel1
[a]1. Homework Statement [/b]
essentially my "problem statement" is to determine what the mg in the equation T=2π√(I/mgL) is being used to represent
T=2π√(I/mgL)
in a nutshell, i solved a difficult problem in a way that my professor probably didnt intend for the problem to be solved---but i know I can get full credit if i correctly justify my answer. so the equation T=2π√(I/mgL) is for the period of a pendulum.
my question is as follows: is the mg part of the equation being used to
(1) to ONLY to represent Fg ?
or
(2) to represent the total downward forces acting on the pendulum?
for my actual homework assignment, the pendulum is hanging from a sheet of charge, so in that case could i say that the equation for T is T=2π√(I/(Fg+Fe)L) ?
when i do this i get the correct answer but as i said i need to be very specific in my proof/explanation for my answer since I am sure this is an alternative method to solve the problem rather than using gauss' law. this method makes the most sense to me which is why i want to use it.
First thing's first--mg is used to represent total downward force when only gravity is there.
What you did is correct and your sir should accept it.However to calculate Force due to electric field you need to use Gauss law.you can't escape it.
I got F_e without using Gauss' Law though i just used F_e=qE
so is there an official way to rewrite T=2π√(I/mgL) as T=2π√(I/(Fg+Fe)L) ? I am thinking that if he's seen the equation before then ill have a better shot of convincing him. (last time i tried doing something like this i had the right answer and i knew my method would work, but because i couldn't adequately explain to him as to why my answer works he told me i had to use a different "regular" method)
Is it a CONDUCTING CHARGED SHEET?
that information is not given but why would it matter?
It matters a lot.
When the charged sheet is conducting then charge induced on sheet varies due to bob of pendulum varies with position.
To understand more search the net for "method of images in electrostatics".
ok so say it is conducting but the pendulum is only moving very very slightly...?
im still a bit confused, why would the varying position matter if the formula for F is just F=qE= qσ/(2ε_0 ) and therefore not dependent upon r?
(i read a bit on method of images just now but all the info I am finding is referencing to a lot of theorems that are not part of basic electrostatics :/ )
Perhaps because the equation you listed for the period is only valid for "small" angles of oscillations.
No. You can't just arbitrarily replace mg by Fg+Fe. You need a valid reason such a substitution is okay to do. "It gives me the right answer" isn't a valid reason.
im still a bit confused, why would the varying position matter if the formula for F is just F=qE= qσ/(2ε_0) and therefore not dependent upon r?
The expression E=\sigma/2\varepsilon_0 is only applicable to a sheet of constant charge density. With a conducting sheet, you don't have a constant charge density because the charges in the sheet will move in the presence of the charge on the pendulum.
Forget about the method of images, etc. You're probably supposed to assume it's a non-conducting sheet of charge so that the charge density remains constant.
"You can't just arbitrarily replace mg by Fg+Fe. You need a valid reason such a substitution is okay to do."
ok so what would that valid reason be then?
Well, that's what your job is to figure out. Frankly, I don't think there is one.
Why take it for granted that sheet is non-conducting?It changes everything and method of images is very easy to follow.
The valid reason is that basic Newton's Laws of Gravitation and coulomb's law are similar and inter-convertible.Both are inverse square laws.You can solve problems of gravitation if you know the result of same problem in electrostatics just by replacing 1/4(pi)(epsilon) by G and charge by mass.Though the converse is not always possible because in electrostatics we have 2 elementary particles(+ve and -ve) while in gravitation we have only one type.However in case of similar charged systems(either all charges in system are positive or all negative) we can apply formula's derived for gravitation.The same is your case.Though more precise method should be (Fg+Fe)/m=geffthen use formula for simple pendulum where only change is g changes to geff.
  • · Replies 27 ·
  • · Replies 32 ·
  • · Replies 20 ·
