Question on this overload program
  • Thread starter Thread starter yungman
    Program
89 replies · 8K views · last reply
yungman
Hi
I modified the program originally from Jtbell. I don't want to hijack his thread, so I ask my questions in this thread. I change names, mainly I assign names instead of a, b, c. I have question on one part of the program:
C++:
#include <iostream>
#include "OverLoad.h"
#include <cstring>
using namespace std;
int main()
{   char Ara[] = "First", Arb[] = "Second", Arc[] = "Result";
    Vec First(Ara, 1, 2);
    count << " In main,  &First = " << &First << "\n\n";
    Vec Second(Arb, 3, 4);
    count << " In main,  &Second = " << &Second << "\n\n";
    Vec Result(Arc);
    count << " In main,  &Result = " << &Result << "\n\n";
    Result = First + Second;
    count << " &Result = " << &Result << " Result = " << Result << "\n\n";
    return 0;
This is header file:
C++:
#ifndef OverLoad_H
#define OverLoad_H
#include <iostream>
#include <cstring>
class Vec
{private:   double x, y;
public:
     char* name;
     Vec(char* desc)
        { x = 0;  y = 0;   name= new char[strlen(desc)+1];
          strncpy_s(name, strlen(desc) + 1, desc, strlen(desc) + 1);
          count <<" [In Constructor(name)],     Object created is:   "<<name <<
           "("<<(*this).x <<", "<<(*this).y << "),   address is "<< this << "\n";
     Vec(char* desc, double x0, double y0)
        { x = x0;  y = y0; name = new char[strlen(desc) + 1];
          count << " [Constructor(name,x0,y0)]   Object created is:   "<< name <<
           "("<<(*this).x << ", "<<(*this).y << "),   address is "<<this <<"\n";
        }// this print out name of the object created.
     Vec(const Vec& original)
        { char tp[] = "Temp"; x = original.x;  y = original.y;  name = tp;
          count << "[Copy Constructor],  original: " << original.name <<
           "\n    Object created: "<<(*this).name <<",     address: "<< this<<endl;
     ~Vec()
        {count<<"\n object destroyed: "<<(*this).name <<",     address: "<<this<<endl;}
     const Vec operator+ (const Vec& rhs) const
        { count << " [In op+] \n"; char Ars[] = "sum";
          Vec sum(Ars);
          count << " \n declare " << sum.name << ", address: " << &sum <<
             ",   rhs is: " << rhs.name << ",  address: " << &rhs << endl;
          sum.x = x + rhs.x;  sum.y = y + rhs.y;
          count <<"\n "<< sum.name << " "<< sum <<" = "<<*this<<" + "<<rhs<<"\n\n\n";
          count << " [To operator+],   ";
          return sum;
     Vec& operator= (const Vec& rhs)//count << rhs.name don't work, but &rhs works why?
        { count << "\n [in op=] rhs.name:" << rhs.name << ",  address: " << &rhs;
          x = rhs.x;   y = rhs.y;
          count << "\n Address of copied object:     this =" << this << *this << endl;
          return *this;
     friend ostream& operator<< (ostream& out, const Vec& v)
        { out << "[In op<<] " << "(" << v.x << "," << v.y << ")";
          return out; }
#endif
1) first question: If you look at the word file, there are garbage when I try to print out the name. Please look at the header file, This is from running line 37 in operator+() jumping to operator+(). I try to print out rhs.name, that gives me the garbage. By if you look at line 23 in Copy Constructor, I assigned "Temp" to the name of the object created. I even verified by printing out the name in line 25 and it works.
When going to operator+(), object Temp is passed to &rhs by reference. I should be able to get "Temp" when I count << rhs.name; But I got garbage. I double check &rhs = &Temp. Why the name doesn't follow?2) When I want to pass the c-string name from main to either Constructor, I have to create dynamic memory( name = new char[strlen(desc) + 1]), then using strncpy_s() to copy. I tried declaring a char array[] to copy in, it won't work. Is this the only way when passing c-string?
Thanks
The problem is in Vec(const Vec& original). You do a shallow copy of a c-string (temp). Not only does that not copy the string (only the pointer), temp is also stack allocated and goes out of scope, and is destroyed, at the end of the function.
You need a deep copy. So you have to delete the old string, allocate memory for the new one, and then copy over the characters from the one to the other.
Since yungman are clearly heading into C++ territory and only use the string to give vectors a name while debugging, I will recommend he just switch to using std::strings instead.
No, the whole exercise is pointless. The compiler will optimise away any code that doesn't do anything (such as, in this case, creating a temporary object on the stack to hold a result and then immediately copying that object somewhere else). The moment you put in code with a side effect (such as incrementing a static counter, writing to a stream, creating a string etc.), you prevent the compiler from optimising it away.
It's like trying to measure which slit the photon goes through in an interference pattern - the moment you do that, the pattern is no longer there.
Of course it would not be a good idea to have a string be part of a vec class. But if for some reason you had that requirement then it might be a good idea to at least have it occupy a fixed size chunk of memory contiguous with the other fields. That way you have each vec is in one contiguous part of memory, an array of vec is one contiguous chunk of memory, and you have the convenience that you can directly index into the chunk of memory for IO and stuff like that.
A potential use case would be if you need to couple categorical data with numerical data. Even in that case, I think you would be better off composing a vec with a string in a new struct, so that a vec is just a vec.
C:
// will be contiguous in memory, with sizeof(Vec_Str<T,N>) = sizeof(T) + N*sizeof(char)
template< class T, int N >
struct Vec_Str
    Vec3< T > vec;
    char str[ N ];
    Vec_Str( const Vec_Str< T, N > & other )
        for( int i = 0; i < N; ++i )  {
            str[ i ] = other.str[ i ];
        vec = other.vec;
And if you need to have dynamic strings, then you might as well use std::string, or a custom string class, which does a deep copy in it's operator= overload already. But beware that std::string is heap allocated, and the values in your struct will not be contiguous in memory and you will need to account for that with IO, for example.
C:
// data not contiguous in memory, with sizeof(Vec_Str<T>) = sizeof(T) + sizeof(std::string)
template< class T >
struct Vec_Str
    Vec3< T > vec;
    std::string str;
    Vec_Str( const Vec_Str< T > & other )
        str = other.str
        vec = other.vec;
Thanks for the reply, I agree that the Temp will be destroyed as soon as it goes out of scope, but you can see the code and the printout that it is not out of scope as the very next step is copying from Temp into object Result. It has to be still valid when I ask to display the name.
Thanks
It does give me a better feel of what's going on. I already learn a lot in Jtbell's thread, Here, I want to have a way to make and display the name that follows from all the manipulations. Just an excuse to get more familiar with C++.
The program works, that's not even an issue, just want to get a better feel of how the compiler works.
Thanks
Thanks
Can you clarify what you mean? I thought I have been studying C++ all along! You mean all the former 12 chapters I studied are just a warm-up? 😊 :smile:
I actually started out using std::string all along and just switch back to c-string lately! Main reason is I was working on a vector of structure and I need every single element to be the same size. If I use std::string, every name is of different size and thereby every element of the vector of structure will be different size and very hard to do searching and all. So I went back to fixed sized c-string that I can set the size to say 25 char for the name. Yes, in this case is not important, but the program I worked on matters.
I know my thread here doesn't make much sense, Jtbell already exhausted this topic already. I just find it very interesting, like a back door way to understand the compiler a little better, AND give me a reason to play around with the operator overload in as different light. Of cause I would not use this as method of debug unless it's called for, just for the fun of it.
But I think the first question is valid. Because object Temp is still in use and you can see Temp is destroyed in later lines, not when I try to display the name. It doesn't make sense I get garbage...even though the final program works.Thanks
I don't think that's what he (Filip Larsen) meant, only that it didn't make sense to be using a C-string in the context of a class.
I didn't try out your code, but jarvis gave the answer back in post #2. Your copy constructor isn't doing a deep copy. This is exactly the same thing that I was talking about in another thread of yours where I showed a small piece of code in which I didn't supply a copy constructor, but instead relied on the one provided by the compiler.
In a shallow copy, the data and pointer values are copied over. If two objects are pointing to the same data, and one object gets destroyed due to going out of scope, The other object's pointer will likely be pointing to garbage.
Exactly.
For yungmans benefit I feel the urge to add that using raw C-strings in a C++ is really a no-go today unless one has good reasons to do so. Avoiding C-strings and manual allocations/deallocation is the first important steps away from shooting yourself in the foot all the time using C++. It may not be apparent with small toy programs, but for (newer) industry strength systems its a must.
Not so. A std::string, like any other variable size container in the standard library, actually takes up a constant amount of storage in the class where you use them, that is, sizeof(std::string) is constant. On one of the online gcc compilers for instance its 8 bytes, on another system or compiler it could be different but still constant. Of course, the string data that is managed by the string instance also takes up space somewhere, but that is on the heap (allocated with new[] or similar), potentially far away from where the string instance itself resides.
Which makes it all the more important to have a copy constructor (and others) that does the copy in a smart way.
Indeed, or when using the std::string and similar classes with value semantics as members in your class, just go without copy constructors and let the default copy constructor handle it. I find I rarely have to write a copy constructor in the production C++ I'm involved with because the classes are usually already tuned to behave with the desire value or reference semantics. If I need deep copy on a member with reference semantics I would probably add a DeepCopy method instead of having it hidden in a copy constructor that can be invoked in all sorts of surprising situations. Or in other words, if there is a need for deep copying a member in a copy constructor then that is a smell that maybe changing the member to a class with value semantics is cleaner.
Of course, the classes at the "bottom layer" (like the std::string) that operate on allocated memory chunks will of course need a copy constructor as part of providing value semantics. But normal "business logic" classes that does not allocate anything themselves should hopefully not care about this.
I did not know that. I took it very literally. You mean it gets destroy even before the Destructor as it was very clear Destructor is called to destroy Temp in LATER lines.
You mean there's a deep copy and "shallow" copy? Where do you get all these information...Maybe I really don't want to know at this point as I am drowning with new information already! :)).
thanks
Filip Larsen said:
Exactly.
How come all the examples I saw in the book using c-string and pointer new char[size] to copy name over? These are all new to me, I don't really get what you are saying.
You mean if I use std::string for this purpose, they will be constant size? What if I have last name like Wong which is very short and another last name of some European name that is 20 characters? The compiler will know and use the longest name as the size in a vector of structures or save in files? Far as I understand like files, they don't really care about your elements of vector or anything, it just go to the location you give and take out certain amount of bytes.
Thanks
Hi guys
I thought I do this experiment to go a step deeper, but it sounds like it's going a lot deeper than I thought. All the deep copy and how the compiler might think... If so, maybe I should stop digging for now. I have plenty to learn right now, if this is not the time to open this can of worm, I am more than happy to drop this thread and go back to my studying. I am sure the book say nothing of these yet. I still have not finish chapter 14 that I should go back to.
Thanks
I am trying to wrap up this program, I notice I forgot to delete the dynamic allocated memory in the Destructor as I added the name = new char[size] everywhere. So I added the line delete name[]. The debugger gave me this:
What is this?
Edit:
I stepped through, it was going into Destructor of Temp object when things went wrong. it gave me this page:
thanks
Guys
I am not sure I can agree reading rhs.name gives me garbage is about not a deep copy. The reason is we all know:
1) in operator+(), temporary object sum is created to store Left + Right.
2) Then sum is copied into object Temp that is another temporary object.
3) Sum is destroyed.
4) Temp is copied into Result by operator=() where parameter &rhs is reference to Temp.
I know that because in operator=(), x = rhs.x, y = rhs.y. This copy the value into Result to display in line 15 of main(see post 1).
BUT remember, the values of x and y were copied over to Result by operator=() in line 39 of header file. Then using operator <<() to display. It will display Result.name = "Result".BUT if you look at both operator=() and operator<<(). ONLY x and y is being copied over and nobody touch the name in Result. That's the reason when display Result.name, you get "Result".
So I did an experiment. I modify the operator=() and operator<<() by adding name=rhs.name and output v.name resp. You can see the printout that when I display Result, I got garbage.
C++:
        { //count << "\n [in op=] rhs.name:" << rhs.name << ",  address: " << &rhs;
          name = rhs.name;//adding this line
          return *this;
        { out << "[In op<<] " << "(" << v.name << v.x << "," << v.y << ")";//adding v.name.
          return out; }
ONLY one way can be right. I showed x and y are copied over from Temp to Result. BUT in the same function after I added the name, the garbage is copied over. I don't think this is about deep copy. The information in name is lost.
This is the copy of the printout of the few lines executed:
You can see Temp is destroyed in the second to the bottom line with the correct address. Last line is from line 15 of main verified with correct address. you can see the garbage, BUT you can see correct value of x and y as show. How do you explain by deep copy?
Something is really wrong here. Program is NOT working. If you have a c-string that you need to pass on, it will give you garbage. It just happened the two number got passed correctly.
ThanksJust in case, this is the modified header file:
C++:
#ifndef OverLoad_H
#define OverLoad_H
#include <iostream>
#include <cstring>
class Vec
public:
     char* name;
     Vec(char* desc)
     ~Vec()
        {count<<"\n object destroyed: "<<(*this).name <<",     address: "<<this<<endl; /*delete[]name;*/}
          Vec sum(Ars);
          return sum;
          name = rhs.name;//Added for testing
          return *this;
        { out << "[In op<<] " << "(" << v.name << v.x << "," << v.y << ")";//Added for testing.
          return out; }
#endif
yungman said:
C++:
          Vec sum(Ars);                                       // <---- 1) This line is a problem
          return sum;
C++:
          name = rhs.name;//Added for testing                // <---- 2)This is also a major problem
          return *this;
Regarding comment 1: Why is operator+() calling a copy constructor? The code from jtbell didn't call a copy constructor from within its operator+() implementation. Why did you make this change?
Also, we've been through this before -- please choose better names for variables. Ars is not a useful name -- is it an abbreviation for Arse? If not, Ars is in fact a terrible name. Maybe you can keep it straight, but you repeatedly ask us for help. Poor choices for variable names make it harder for us to get at what your code is trying to do.
Regarding comment 2: What do you think happens with name=rhs.name?
If the name field of the rhs object is allocated on the heap, what do you think happens to rhs.name when rhs goes out of scope (and is destroyed)?
I don't know why operator+() call copy constructor exactly, I thought it was like this in Jtbell's program with ThreeVector c; c = a + b; I take it operator+() created sum = b.operator(a) Then when "return sum", that triggered Copy Constructor to create object Temp and copy object sum over as sum is going to be destroy the moment exiting out of operator+(). Then operator= () is called to copy Temp into c. These steps are shown both in my program and Jtbell's program.
I did not change the flow of the program from Jtbell, I just added the name to make it easier to track by displaying the name all along.
It should be exactly the same as x = rhs.x; y = rhs.y in line 44 of the header file. I declared char* name in the public of the class definition. So the class has x, y and name as member variables.
Put it in another way. Jtbell has 3 variable x, y and z. I have 3 variables x, y and name. Same header file should pass and display them correctly whether it's z or name. Nothing got changed on this between Jtbell's program and mine.
Thanks
You put it in there. If I recall correctly, jtbell's code for operator+() started off like this:
C++:
ThreeVector ThreeVector::operator+ (const ThreeVector& rhs) const
    ThreeVector sum;
    sum.x = x + rhs.x;  sum.y = y + rhs.y;  sum.z = z + rhs.z;
No copy constructor.
No, see above.
I just pointed out how you changed the behavior of operator+(), which of course changes the behavior of your program.
No, it's not the same. The data members x, y, and z are qualitatively different from the member you added - name.
What are the types of x, y, and z?
What is the type of name?
Some questions I asked in my previous post:
What do you think happens with name=rhs.name;? Hint: It's not the same as, say, x = rhs.x; .
Regarding the assignment statement above, if the name field of the rhs object is allocated on the heap, what do you think happens to rhs.name when rhs goes out of scope (and is destroyed)?
C++:
    ThreeVector sum;
No, see above.
You mean I have to do strncpy_(name, strlen(rhs.name) + 1, rhs.name, strlen(rhs.name) + 1) ?
Still giving me error. But if this is the right direction, I can work on it.Thanks
Say you have a house, and it has an address. You can give someone a copy of your address (shallow copy), or you can make then an actually copy of your house (deep copy).
If you have your house demolished, the address you gave will be an address to a demolished house.
In other words, shallow copy is like "Mi casa es tu casa". Deep copy is like, I built you a house that's just like mine.
Now vec::name is a memory address. You set name=temp.name (shallow copy). When temp is destroyed, the memory it held is now garbage. So name, is now a memory address to garbage.
I was hoping that @yungman would reach this conclusion on his own...
Suppose you have this code.
C++:
double x = 3.4;
double y = 1.7;
char name[] = "First";
Given the above, is there anything wrong with the following code?
C++:
x = 6.2;
y = 8.3;
name = "Second";
Thanks for the reply.
But I already show Temp was destroy after I got the garbage. You can see clearly in post 17, Temp is destroyed in the second to the last line, I got garbage the line before that. Temp was not destroy at the time. Can you explain that with shallow copy?
I am looking into what I did wrong with copying c-string. I was wrong on name = rhs.name. to copy c-string. It has to be strncpy_s(name, size, rhs.name, size). But there is a problem with c-string inside class definition I still don't understand. I am also looking at using std::string.
Thanks
C++:
double x = 3.4;
double y = 1.7;
C++:
x = 6.2;
y = 8.3;
name = "Second";
I got that, thanks, I have to use strncpy_s().
I was working on this last night, I have issue with defining c-string inside class. I want to show two separate programs. The first one is just a simple copying c-string inside main, It works perfectly, I can copy from name2 to name1:
C++:
//Function for strings
#include <iostream>
#include<cstring>
int main()
    const int size = 25;
    char name1[size] ;
    char name2[size] = "Nancy";
    strncpy_s(name1, size, name2, size);
    count << name1 << "\n\n";
    return 0;
But when I put it inside class definition, it flagged me error right from the beginning. I cannot even go any further. Can you help me on this first. This is the header file. I can see red wiggle line under "size", this is the same as in the main above, it just doesn't work inside class definition.
C++:
#ifndef OverLoad_H
#define OverLoad_H
#include <iostream>
#include <cstring>
class Vec
{private:   double x, y; const int size = 25;
public:
     Vec(char*desc) { char name1[size] = "Alan"; char name2[size]; }
#endif
I am not discounting what you and Jarvis323 talking about the swallow copy, I already see the problem of copying c-string, I want to see this through first.
Thanks
Which one? If I add a member named size to the class that jtbell wrote, the program compiles and runs with no problems.
C++:
class ThreeVector
private:
    double x, y, z;
    int serialNum;          // unique for each ThreeVector instance
    static int numVectors;  // counts the number of ThreeVectors constructed
Is the red squiggly line in your constructor that takes a string argument? If so, hover over the squiggly part and VS will give you a clue as to what's wrong.
C++:
class ThreeVector
private:
    double x, y, z;
This is the picture, I have to take a picture with camera to show what the message said having the arrow on the red wiggle.
I so wish I can get pass this and at least do my best to learn about c-string passing into the class object. There should be no reason to use name = new char[] every time that I have to delete name[].
This is an example I really want to do, I just wrote one Constructor as an example:
C++:
#ifndef OverLoad_H
#define OverLoad_H
#include <iostream>
#include <cstring>
class Vec
 public:
     char name[size];
     Vec(char* desc)
       { strncpy_s(name, size, desc, size);
         x = 0; y = 0;
#endif
Now, I am not ignoring what you and Jarvis323 on the shallow copy, I see a problem that I feel I should learn first. I am even going to try using std::string to verify it has a constant size. Remember in my Directory program, I have a long array of structures store in file. I cannot have each structure element having different sizes as when reading file, it doesn't care about what element, structure, it literally go to that address to read certain amount of bytes. Each element has to have the same size to do that, or else it would be very hard to do.
I am running out of idea on this red wiggle error thing. I tried click search online, I don't understand what they are talking. Please help.
Thanks
@yungman
You post a code asking what is the error. We tell you what the error is and how to fix it. You remain skeptical, don't fix the error, and instead start trying other stuff.
At the very least correct the errors you have (in this case shallow copy). It will be a waste of time debugging code full of known errors.
Unfortunately you will not be able to use a string for your use case. The reason, yes a string is a fixed size, just like vec::name has a fixed size. The size of the data they reference is something else.
Writing a string in binary directly, would be making a shallow copy of it onto the disk, when again you need a deep copy.
Understanding deep and shallow copy is still the key.
Note that string is something like this.
Code:
struct MyString{
    char *;
    int size;
Now an array that is NOT dynamic is ok for what you want. So you can use char name[N], and you'll be fine. But not string or char * name = new char[N].
See my second post for an example.
Jarvis323 said:
@yungman
Code:
struct MyString{
    char *;
    int size;
Thanks for the reply. I am working on this also. The way I can think of to avoid shallow copy is actually declare sum outside of the operator+() so sum is not destroyed when exiting the function. I am experimenting with this and I have no luck so far. Please understand I am just learning, this is quite a bit above my knowledge, I am kind of blind guess here. I need a little more literal help. I can assure you the book talk nothing of these stuffs. You think I should wait to learn these later when I am ready.
Tell me whether I am on the right track.
Thanks
