Question re. the Pressure Energy of a Fluid
The discussion revolves around the concept of pressure energy in fluids, specifically how it can be quantified as a head of fluid. Participants explore the relationship between pressure, energy, and the height of a fluid column, addressing both theoretical and practical implications in fluid mechanics and hydraulics.
  • One participant expresses confusion about how energy per unit weight is represented as a head of fluid, questioning the role of length in the energy calculations.
  • Another participant corrects the initial claim about work done, emphasizing that it relates to force and displacement rather than the length of the fluid column.
  • A participant references a source stating that pressure energy per unit weight is equal to the height of the head, leading to a discussion about the interpretation of force as constant over displacement.
  • Some participants propose that pressure cannot be considered energy per unit weight but rather energy per unit volume, leading to a mathematical breakdown of the relationship between pressure, density, and head.
  • Another participant mentions the need for clarity regarding the Darcy Coefficient in relation to permeability values of soil, indicating a practical application of the discussed concepts.
  • One participant raises a question about the hydraulic gradient in the context of flow velocity through soil, seeking to understand its implications for pressure energy conversion.
  • A later reply emphasizes that kinetic energy is not significant in groundwater flow, focusing instead on viscous flow through soil pores.
  • Clarifications are made regarding the definitions of hydraulic conductivity and permeability, along with the importance of considering the hydraulic gradient as a vector.
Participants express varying interpretations of the relationship between pressure, energy, and head. There is no consensus on how to best conceptualize these relationships, and multiple competing views remain regarding the definitions and implications of pressure energy in fluid mechanics.
Some participants note limitations in their understanding of the concepts, particularly in relation to the assumptions made about pressure being constant over displacement and the interpretation of hydraulic gradients.
This discussion may be useful for students and professionals in fluid mechanics, hydraulics, and related fields, particularly those interested in the theoretical and practical aspects of pressure energy and flow dynamics in fluids.
Sir James
I’m confused as to how energy per unit weight can be quantified as a head of fluid. I have tried to understand this from a couple of angles but am getting confused. I’ll go through my methodology to see where you can spot the cracks.
If energy = work done = (force * length over which it acts) then pressure energy of a fluid is Pressure*Area*Length
A column of water exerts a downward force, being its weight, and so the pressure required to support a column of water is equal to the weight of the column divided by the base area of the column. So, if the pressure exerted by the column of water is equal to
mass density*gravity*height
then the pressure at the bottom is equal to
but acts vertically upward. The energy of the fluid supporting this head would then be
pressure*area*length = mass density*gravity*height*area*length
However, what is confusing me is what the final term length is. From my reading it seems to suggest that the column of water is the governing factor, in which case the length would be the height of the column so the pressure energy would be:
mass density*gravity *area* height^2
However, on looking at a column of water I just can’t see how this is correct. If the column was split into incremental parts then surely the pressure which acted upward would only move 1 increment by a distance of the height (to the top) whereas another increment would only be moved halfway up the column? Does this not mean that the pressure energy at the base of the column would be more like force*average distance over which it acts, i.e. height/2?
Cheers for the help
Welcome to PF!
Hello Sir James! Welcome to PF! :smile:
No, work done = force "dot" displacement of the point of application of the force.
(it has nothing to do with the length of the column)
Hello Tiny Tim, thanks very much.
I'm still a little lost with this one though. In Understanding Hydraulics (Hamill, 2011) it states that the pressure energy per unit weight of a fluid is equal to the height of the head.
Then total energy indicated by a head is:
head * weight
which can also be written
head * (mass density*gravity*area*head)
As the (mass density*gravity*area*head) is a force, it would suggest that the head is, in this case at least, equal to the displacement from the point of application of the force?
What I don't understand is how we can regard this force as constant over this displacement.
exactly correct :smile:
a head of water assumes that the height stays constant
if you remove water from one end, you have to replace it at the other end …
you're calculating the work done as if the column collapses :wink:
(but examining pressure in terms of energy really isn't appropriate …
pressure is a force, and you can easily find the pressure of a column of water using an ordinary force diagram)
To me, this seems to be a combination of two separate, but related, questions. How can pressure be thought of as energy per unit weight? and Why is this considered head (height of a column)?
The first question is related to units. But pressure cannot really be considered energy per unit weight. It is really energy per unit volume. Here is how all this works out:
p = F/l2 = (F)(l)/l3=energy per unit volume
Now let's divide pressure by density:
p/ρ = ((F)(l)/l3)[itex]\div[/itex](m/l3)=(F)(l)/m=energy per unit mass
Now let's divide by gravitational acceleration g:
p/(ρg)=(F)(l)/(m)(g)=energy per unit weight
But p/(ρg) represents the height that the pressure p can raise a column of fluid of density ρ. This height is call the "head" of fluid. So, the energy per unit weight (as interpreted above) is also equal to the heat of fluid.
Tiny-Tim and Chestermiller thanks very much, your answers have helped me to clear up what I was confused over. I'm looking at this in relation to permeability values of soil so need to get it right before I bring in the Darcy Coefficient.
I can help you in this area too. I've had considerable experience with groundwater flow in confined aquifers, single phase.
In that case Chestermiller I do have another question. I am trying to get my head around the equation for the velocity of flow through a soil.
The equation is:
V = Ki
Where:
V = velocity
K = Darcy coefficient of permeability
i = Hydraulic Gradient = (head at point 1-head at point 0/horizontal length between points 1 and 0)
I guess my main question is how the hydraulic gradient in this equation should be interpreted. Does the component “i” in the equation for velocity mean that we are effectively multiplying by a ratio that gives the pressure energy that has been converted to kinetic energy, per horizontal unit distance?
The equation is:
V = Ki
Where:
V = velocity
Forget about kinetic energy. Kinetic energy does not apply to groundwater flow. The magnitude of the kinetic energy and its gradient are too small to be important. What we are dealing with here is viscous flow through the tiny pores of rock, and the viscous effects dominate.
In your equation above, V is what they call the superficial velocity. This is the flow rate averaged over the cross sectional area of both rock and pores. This differs from the pore velocity which is averaged only over the cross sectional area of the pores, and is therefore higher.
Also, in your equation above, K is what I am accustomed to calling the hydraulic conductivity, not the permeability. The hydraulic conductivity has units of velocity, and is expressed in terms of the permeability by:
[tex]K=\frac{kρg}{μ}[/tex]
where k is the Darcy permeability, and, if I remember correctly, has units of length squared.
The hydraulic gradient is the derivative of head with respect to distance. (You have had calculus, correct?) The velocity V is a vector that is pointing in the same direction as the head gradient vector. Incidentally, there should be a minus sign in your equation on the right hand side. The flow is from high heat to low head.
Get yourself a copy of the book Groundwater by Freeze and Cherry.
Chet
Much appreciated Chet, I was going wrong by not looking at the hydraulic gradient as a vector. This meant I didn't understand why the length L was sometimes measured horizontally, sometimes vertically or sometimes in the direction of flow. I now see that this just depends on the direction of the velocity you are trying to obtain.
Also noted the minus sign I missed off.
Cheers again!
  • · Replies 16 ·
