Question regarding Hardness and Wear Resistance
The discussion centers on the hardness and wear resistance of materials used for fountain pen nibs, specifically comparing tungsten carbide and iridium-osmium alloys. Tungsten carbide has a Mohs hardness of 9.0, significantly higher than the 6.5-7.0 of iridium, leading to questions about its durability and wear resistance on paper. Participants highlight that while hardness is an intrinsic property, wear resistance can vary based on the materials involved and the conditions of use. There are suggestions for alternative materials, like silicon nitride and BAM, which offer high hardness and low friction but pose challenges in shaping. Overall, the conversation emphasizes the complexity of predicting wear resistance based solely on hardness values.
dovidu
Hello, everyone
i always had this question in mind, and also tried to look for answers on the web,
but alas! i can't seem to find definite answer!
i am currently making a fountainpen nib with a carbide point.
the traditional material for fountainpen tipping is iridium + osmium alloy (iridosmium)
iridosmium moh hardness is roughly 6.5-7.0
tungsten carbide is typically 9.0
also check this out:
"The scale is roughly logarithmic,
that is, a material with a hardness of 8 is,
roughly 10 times as hard as another material whose hardness is 7,
which in turn is 10 times as hard as a material whose hardness is 6,
and so on. The minerals chosen by Mohs for this scale are:
10: diamond
9: corundum
8: topaz
7: quartz
6: orthoclase
5: apatite
4: fluorite
3: calcite
2: gypsum
1: talc"
the question is...
<1>
this quote in conclusion indicates that,
tungsten carbide is roughly 200-250 times harder than iridomium, as moh scale is "logarithmic"
is this true?
<2>
relationship between hardness and wear resistance??
for example, a iridomium tipped nib on paper will last roughy 10 years...
>>>> how about a tungsten carbide tipped nib on paper? 10 X 250 years?
Hardness is an intrinsic property of a material (having to do with the molecular bonding) whereas "wear resistant" is more subjective and can depend on the answer to the question "resistant to wear from what material?"
How would you form it into the tip shape?
Do a search on "machining tungsten carbide" and read some of the answers. It sounds like you want to pre-form a tip made out of other material, then sinter the tungsten carbide layer as the new surface. Ordinary grinders and milling tools other than diamond, are too soft to machine tungsten carbide.
I was surprised when searching "tungsten carbide tip" to find pens with such tips. But they were not ink pens, but rather engraving/etching scribes.
I think tungsten carbide is pretty rough, whereas a pen nib needs to be smooth to "glide" over the paper surface.
Anyhow, it sounds like a good challenge. Good luck.
i have already succeeded making such carbide point nib.
the relevant question here is:
low much longer would it last, compared to traditional iridosmium point nibs
writing material is paper
That's really hard to say.
How do you define end of life?
How does the coefficient of friction compare tungsten versus traditional?
You would need data on abrasion resistance of tungsten versus traditional. That is related to but not identical to hardness.
You may find some data here https://en.wikipedia.org/wiki/CRC_Handbook_of_Chemistry_and_Physics
You are mistaken.
As a part of my engineering hobby I do *turn* on odd occasion tungsten carbide.
Modern turning tool manufacturers, eg Sumitomo Electric but also some cheap chinese suppliers are producing special *cubic boron nitride* tipped inserts good enough for the task.
For grinding Tungsten carbide you can use diamond, cubic boron nitride or cheap silicon carbide grinding wheels.
@dovidu,
If your objection is to manufacture *indestructible tip for fountain pen*, you might consider 2 materials.
1. Silicon nitride tip or even better:
2. BAM (Aluminium - Magnesium Boride) tip.
The latter has a hardness very close to diamond *and* the lowest friction coefficient of any earthly material known (about twice lower than teflon). On the top of it excellent chemical resistance and it is easy to wet with water or organic based ink.
It is pig to shape even with diamond laps or grinding wheels. Even NASA complains.
unfortunately its impossible to make 0.05mm slit for such material...
even carbide has to be done with diamond
Martin0001 said:
@dovidu,
It would be possible on BAM with electric spark erosion technology.
could be but not the slitting thickness of 0.05mm
How true. Soft 'white metal' bearings will wear down a hard steel crankshaft.
I have a lathe with plain bearings. I had to replace bearings one time but not a journal.
Bearings are becoming harmful usually if there is inadeuate lubrication or if hard particles, eg dust from nearby grinder, finds its way into bearing surfaces.
Then process known as lapping will take care of journal, eg destroy it by galling.
Under normal working conditions you will replace bearings several times before replacement or regrinding of journal is called upon.
Likes sophiecentaur
Very true. My ex employer found out the hard way that Nylatron is very wear resistant when running against steel, but not at all wear resistant against paper.
the post is becoming very off topic!
so, nobody has clue? whether moh scale is logarithmic?
what's the hardness difference between 7 vs 9 ? 100 times??
does anyone know wear resistance of osmium vs tungsten carbide on paper?
it doesn't have to be exact
I am not aware of any published information on wear resistance of materials against paper. I do know that CPM10V is a popular alloy for slitter knives. I once was told that if CPM10V does not have sufficient wear resistance, then you need to use a carbide. That was before CPM15V came out.
Also, hardness alone does not predict wear resistance. Crucible makes a series of knife steels that are far more wear resistant than simple carbon steels at the same hardness. Here is a wear resistance comparison of some tool steels: http://www.crucible.com/eselector/general/generalpart6a.html.
