Question regarding the Many-Worlds interpretation
417 replies · 51K views
tom.stoer said:
Now back to interpretation: we agree that for very simple experiments we know the branch structure.
Well, ok. Not sure what it was I have just agreed to :)
tom.stoer said:
But we can use a trick and prepare the N experiments such that all N branchings are caused far away from the observer such that she does not affect this "primary' branching" (she could in principle decide not to interact with the microscopic subsystem at all). I think this "primary branching" would not called branching at all but is simply a coherent superposition of all possible results of the N experiments. Right?
It is not sufficient to prevent the observer from interacting directly with the system under observation. In fact it never happens like that, in real life observer interacts with the system through a whole bunch of intermediates. To do what you want, you would have to cut all interactions through the common environment. The only way to achieve that would be to put the experiments into their individual Shroedinger Cat boxes, isolating them completely from the observer and from each other. I'm not sure it is physically or even theoretically possible.
1. CMB or gravitation might be sufficient to cause decoherence.
2. If your state is entangled with the content of the box, it will remain entangled after you close the lid. You can try to disentangle yourself by interacting with your environment but this will not change the amount of correlations between the inside and the outside of the box, it will only spread those correlations all over your environment.
3. The process of decoherence requires access to environment which has nearly infinite number of degrees of freedom where the cross-correlation terms can spread out and dissipate. When you put your experiment into a box, the content of the box has large but still finite number of degrees of freedom. I think if you separate the content of the box into microscopic system under test, measuring apparatus and environment, with environment being much larger that the other two, then looking just at the measuring apparatus, the branches will be split (wavefunction collapsed if you prefer), but when looking at the content of the box as a whole it will still be in superposition with all cross-terms intact.
tom.stoer said:
What we have achieved so far is that we agree on the "primary branch structure" including its counting.
No, sorry, I don't think we did. No branching happens until you open the lid and look inside. Until then we just have boxes with stuff in some unknown superposition state in them.
tom.stoer said:
...most observers reside in branches...
Here you seem to implicitly assume "One branch - one observer". There is no such rule.
tom.stoer said:
either MWI with its branches is wrong, or my simple branch counting applied to the full branch structure is wrong (or meaningless) and we have to correct it in some way.
I think the branch count is meaningless but whether it can be corrected, I don't know. That would require showing that the the branches are in some way have equal measure (from symmetry point of view) or subdivide it into large number of small branches and then somehow invoke central limit theorem.
tom.stoer said:
MWI must provide ... a derivation of the QM probabilities.
Indeed, wouldn't it be nice? But MWI is only an interpretation. Any such derivation must be done using ordinary QM formalism. If such a derivation can be done without reference to "Measurement Apparatus" or "Ensemble of Identically Prepared Systems" or "Pilot Wave", it will benefit MWI indirectly by providing some room to swing Occam's razor about, otherwise it won't change the status-quo.
Up to now you only told me what I did wrong.
Just for curiosity it would be nice to explain how it should be done correctly ;-)
Suppose I have a Schrödinger-like cat + box; outside the box we have vacuum, and everything is pitch black; the box opens automatically after half-life-time; at the same time a light inside the box is switched on. So there is no interaction between a far distant observer and the box after preparing the experiment and before the first photons arrive at the observer.
Of course there is decoherence due to the entanglement of the cat with the air molecules inside the box.
Could you please write down
- what the observers will see
- how the total state and the reduced density matrix (partial trace) look like
- how the branch structure looks like and how it is related to the total state and/or the density matrix
(formulas a preferred)
EDIT: Could you please write down the corresponding formulas and information
- observation
- state, density matrix
- branch structure, its relation to state and density matrix
for N such experiments in parallel
Delta Kilo said:
Sorry, I guess I wasn't clear enough. I was talking about off-diagonal elements of the reduced density matrix. Say you start with cat in state a|Cdead> + b|Clive> where <Cdead|Clive> = 0 and environment in state |E>, the state of the composite system being a product state. Final state of the system is then a|Cdead>|Edead> + b|Clive>|Elive>, with <Edead|Elive>≈0 FAPP. But while these cross terms <Edead|Elive> are vanishingly small, they can never become exactly 0, otherwise the unitarity is violated.
This has nothing to do with unitarity. Consider the cat basis {|d>,|a>} and the input environment basis {|e1>,|e2>} and construct a separable state. Then map the product basis (|e1>|d>, |e1>|a>,|e2>|d>,|e2>|a>) to a new basis with 4 orthogonal environment states, in this order: (|d>|e'1>,|a>|e'2>,|d>|e'3>,|a>|e'4>). That is a unitary map, because you map an orthonormal basis to another orthonormal basis. The input and the output space are different, because the size of the environment increases. This can be understood as increasing entropy in the environment, which is necessary for what we do here. This is why I said that the result is much more related to infinite dimensional state spaces than unitarity. Calculate the density matrix of the input and output states. The interference terms vanish completely.
Cheers,
Jazz
Quantumental said:
That's like saying "**** science"
Science is about finding the truth, not stopping when **** gets complicated.
No, science is about models which match observations. You can never tell how far these models are away from the real thing. We don't know if our universe is something big or something small in an absolute sense, we only know it is big wrt to us.
Delta Kilo said:
Now, as a result of decoherence, terms corresponding to inconsistent states (where observer's left eye sees X and right eye sees Y) will have vanishingly small amplitude and the remaining terms can be divided into two non-overlapping sets: one set has observer and the environment consistent with the result X, another with result Y. We can call these two sets of terms "branches". Each branch then describes infinitely many observers, all of them having seen the same result (either X or Y) but differing in all other aspects.
No. Decoherence can resolve interference of superpositions, but not different local already stabilized results. So an observed difference between two eyes is not resolvable by any decoherence mechanism. It's not that simple.
Cheers,
Jazz
Cheers,
Jazz
When experiment is prepared so that both eyes will observe same unknown polarization, then the eyes are being tuned so that the eyes that reseive same kind of light are propelled into aproximately same direction in Hilbert space.
Right?
mfb said:
Right
Counting branches (as 1+1=2) is the wrong approach, nothing will help there. It is like the lottery example: if I just count "I will not win" and "I will win" I don't get a relevant result - I just get a list of all options.
Sorry to interject, but I think the lottery example is not posed in a fair way. If you pic one number from say, 1 million possible out comes in the lottery, then there are 999,999 possible out comes where you don't win, and only 1 where you do. Put into MWI perspective where each outcome is a branch you could simply count the branches to work out the probability.
If only 2 branches are created for a a non 50/50 probability, then you seem to be saying that you would most likely find your self being the most likely you, not the less likely you. But if for every more likely you, there is guaranteed to be a less likely you, how can the less likely you actually be less likely. I would think by definition, they must be equally likely, which is where everything falls apart.
However, I personally don't have any problem adding as many branches as necessary to reproduce probabilities. If you already believe there are infinite branches, then it won't even change the total count;)
I think also the Many Many Worlds phenomenon is relevant here: the number of worlds depends on how you decompose the whole universe into subsystems (see Many Worlds proved inconsistent? - Physics Forums for example). Explantions of the emergence of probabilities have to be consistent with this.
The problem seems to be that we are not discussing the Many-World-Interprertation but a collection of interpretations of Many-Worlds-Interpretations.
There is a rather simple statement in the Kopenhagen Interpretation (or variants): when measuring a quantity A which is represented by an observable A acting on Hilbert space states
1) a state ##|\psi\rangle## collapses to an eigenstate ##|\psi\rangle \,\longrightarrow\,|a\rangle## with eigenvalue a (we don't know how and why)
2) the probability observing the eigenvalue ##a## is determined by ##|\langle a|\psi\rangle|^2##
So these interpretations talk about states, probabilities and collapse; they can exactly say how to calculate probabilities and how to define a collapse (expressed in terms of the standard formalism)
What I am still missing is the same clarity of statements for MWI. MWI is about branches (or whatever) so it should be possible to write down the definition of a branch (again in terms of the standard formalism)
A simple definition is to take the von Neumann measurement scheme and instead of singling out one term in the final sum by collapse, you interpret each term as a branch. The physical justification to talk about such a sum in the first place is given by decoherence.
So tracing out the environment E the system "cat + pointer" is described by
##\rho_E = \text{tr}_E (\rho) = p_a\,P_a\,P_1 + p_d\,P_d\,P_2 + \ldots##
pa,d is the probability to find the cat a(live) or d(dead)
Pa,d is the corresponding projector to a huge cat-subspace
P1,2 is the corresponding projector to a huge pointer subspace with positions 1 or 2
"..." indicates further branches which are supressed due to decoherence
Correct?
OK.
So for my original experiment with polarizations σ and result strings s(σ) like "xyxxyy..." the reduced density matrix looks like
##\rho_E = \sum_\sigma p_\sigma\,P_\sigma\,P_{s(\sigma)} + \ldots##
The remaining problem is to show that the probabilities pσ obtained for the reduced density matrix correspond to the correct quantum mechanical probabilities.
The basic measurement being referenced has two states, but the probabilites of each state isn't 50-50. Doesn't two states mean 2 branches at each measurement? If two states means two branches, then how can state counting in any way help with probabilities. I have a hard time with the view that calculating the probability isn't fundamental to the state preparation and measurement processes but, rather, is somehow a function of interpretation.
As far as I understand branch counting isn't relevant at all (but I will come back to it later). Instead there is a claim that the Born rule follows automatically. In the above mentioned example we would have something like
##( a_x|x\rangle + a_y|y\rangle ) (\langle x|a_x^\ast + \langle y|a_y^\ast) \; \stackrel{\text{decoherence}}{\longrightarrow}\; |a_x|^2 |x\rangle\langle x| + |a_y|^2 |y\rangle\langle y| + \ldots ##
(I know that using reduced density matrices is by no means complete and that the r.h.s. is only an approximation following from partial trace, but it allows for a rather compact notation; for the same reason I ommited further subsystems like pointers etc.)
So there are several claims:
- there is a preferred factorization of the Hilbert space singled out by dynamics (not fixed by hand *)
- this factorization is stable w.r.t. further interaction and time evolution (dynamical superselection rule for subspaces **)
- this allows for a description of subsystems in terms of (reduced) density matrices with off-diagonal terms ≈ 0
- in addition dynamics automatically fixes the preferred pointer basis (corresponding to polarization states)
- the coefficients |ai|2 on the r.h.s. are determined by dynamics (Born rule derived rather than postulated)
- MWI follows directly from (*) and (**); every term in the sum corresponds to one branch
Questions:
- is this correct? (up to sloppy notation)
- do N polarization experiments simply result in 2N terms with subscripts "xxx..."?
Historically, Everett, Wheeler, Deutsch and other MWI supporters agreed that probabilities must emerge from branch counting, if done properly. This only changed when recent results (90s) showed, that the number of branches depend on the course graining level you apply and that there's no objective way to count. This was a big problem for the theory, and derivations shifted to different approaches that are much less well founded in logical deduction than branch counting but instead called philosophical principles and new postulates.
So I think branch counting is very relevant, it's just not used anymore. But being unable to identify (and count) branches is also a huge problem for identifying stable single measurement outcomes, especially for a measurement on a finite or countable basis.
It depends on what you mean with "automatically", but in general the reduced density matrix "probabilities" are not used for arguing about probabilities in MWI. Even more, density matrices are entirely avoided in recent arguments about decoherence, or only used as an illustrative tool, not as a fundamental contribution to derivations. The reason is that density matrices make implicit use of the measurement postulate. This may not be obvious, but the one reason to describe an ensemble with the use of a density matrix is that the measurement postulate allows you to mix quantum and classical probabilities. So since the measurement reduces the state to probabilities anyway, we can encode an ensemble in the compact form of density matrices. If there was no measurement postulate, the only way to encode an ensemble would be to list the single states and their corresponding probability.
This is a tough one. It is sometimes claimed, that there are preferred factorizations, but in general, there are no such factorizations. Even worse: There are no factorizations, at all! As a simple example, look at the Fock space of any particle and try to single out one of those particles and describe it in a tensor factor space. That does not work. It gets even more problematic if you consider the direct sum of several Fock spaces.
So the whole "factorization business" used in decoherence is very questionable, as it cannot really be used to talk about the local information we have about a system.
The preferred basis problem is only solved by decoherence in some pathological cases, but unfortunately not in general. There has been a lengthy discussion of this in the community, and it's now generally accepted, that we need more than decoherence to fix a basis.
No, the Born rule enters this argument through the back door. By using a density matrix for describing the reduced state and comparing that state to an ensemble, you implicitly used the Born rule.
Cheers,
Jazz
Given only the full Hilbert space and the full Hamiltonian, I don't see how a preferred factorization could possibly emerge. I think this claim is quite certainly false. However, I haven't read much MWI papers and not a single one which makes that claim explicitly. I don't know in detail how people today define the MWI.
The decoherence argument is that the processes of relaxation (= substantial change in |ai|) and decoherence happen on very different time scales. Of course, this doesn't answer the fundamental question why we should interpret the coefficients as a probability.
Can you recommend some papers to read about this?
Also a little off topic: you mentioned that you are not an Everettian. Do you have a preferred interpretation?
Jazz, thanks for the information; your conclusions seem to be much more pessimstic (and quite different) than those from "standard" review papers (Zurek, Zeh et al.). If I understand you correctly then branch counting (which was my original idea) does not work for weights or probabilities but in addition there are no other derivations, either (and even if branch counting would work, I am still convinced that the contradictions from post #1 are not resolved).
Is there any objective review paper summarizing the current status including open issues for MWI and decoherence?
Let me explain why I thought that branch counting is relevant. It depends on the perspective.
Top-down
- one starts with a Hilbert space
- dynamics selectes a preferred basis and mutual orthogonal subspaces
- subspaces, identified with MWI branches, are "dynamically disconnected"
- weights for subspaces are related with Born's rule
(let's assume that all these ideas are correct then everything is fine - and from a top-down-perspective for the full Hilbert space branch counting is irrelevant)
Bottom-up
from the perspective of one observer "within" one branch the relative weights of the branches are irrelevant and not observable; for repeated experiments as described above one observer can write down the results & branchings and in most cases (as defined by branch counting) he will find himself in branches with very low probability (as defined by QM calculations); but the observer, from his bottom-up-perspective, does not see the full Hilbert space, and for him the calculated probabilities = weights for branches are irrelevant; only branch counting, which is directly related to the results of the experiments, is relevant.
So the contradiction I indicated in my first post is relevant for a single observer (in the sense I understood decoherence, branches and observers in MWI). Most observers with knowledge about QM will wonder why they observe and live in a branch with low probability. Of course one single observer can always argue that he may be the untypical, pure observer living in a branch with low probability, but that in total everything is fine. But if most observers have to argue that they live in unypical branches, then this is a major issue.
That's why I still think that branch counting and QM probabilities should not contradict each other.
Of course this becomes irrelevant if branching can be defined differently.
tom.stoer said:
Bottom-up
Well, it depends on your goal.
Do you want to get physics right in most branches, or in most of the measure?
The first won't succeed, but the second does (as most of the measure will see "right" distributions).
In a probabilistic interpretation, do you want to get physics right in most possible experimental results, or with the largest probability?
The first won't succeed, but the second does.
"Most branches get 'wrong' results" is as much an issue for MWI as "most possible result are very unlikely" is for probabilistic interpretations. I don't think it is one.
Excellent summary.
First of all it's not a problem in collapse interpretations b/c there is only one observer.
The problem in MWI is that we want to explain physical and observable results fom the top-down perspective (which gets it right) but that our own perspective of observers is the bottom-up perspective. And in this perspective there is no measure, there is only one branch which I am observing. I introduce the labelling "xyxxyxxxx..." for branches (and I know that other observers do the same thing in their branch - but I don't need this for my argumentation).
Now it's rather simple: if the measure is correct and if the measure affects the branching in some way then there is a chance that the observed frequency of "x" and "y" I observe is the correct one (correct in terms of the 90% and 10%). If the measure does not affect the branching then the measure is not observable for me, and all that remains is the result string "xyxxyyx...". If the branching is not affected by the measure in some way then "x" and "y" in each result string are equally probable and therefore the measured statistical frequency is wrong (when compared to the QM result based on 90% and 10%).
So I cannot agree to
I want to get physics right in most experimental results in all cases and for all interpretations b/c this is what I as a single observer do observe.
There is a big difference between the branching in MWI (as I have described it) and the collapse: the collapse to either "x" or "y" is affected by the QM probability (we do not know how, it's postulated, but it gets it right); the collapse to |x> happens with 90% probability, so in 90% the single observer will observe "x" and everything is fine.
In the MWI as described by me the branching is not affected by the measure of the branch, so there is one observer in the "x" branch and one observer in the "y" branch. Repeating the experiment each observer will calculate the probability for his branch and will find 1/2N which does not agree with the QM result. But b/c he cannot change from the bottom-up to the top-down perspective all he can do is to conclude that he was not lucky and is sitting in the "wrong branch", unfortunately.
And here's my point: repeating this very often the observer will no longer trust in this model b/c in most cases be is sitting in the wrong branch; and if this happens to most observers (and it happens to most observers in the experiment I described) most observers will no long trust in this model.
My conclusion is not that MWI is wrong, but that at least this model of branch counting is wrong (and it's this simple branching which is always used to explain the MWI, so it's not irrelevant). My conclusion is that a measure multiplying a branch is not observable from the bottom-up perspective and does therefore not help (b/c the top-down perspective which may get it right theoretically is not available for experimentalists). So there must be something more complex (e.g. a measure affecting further branching)
Another conclusion is that these contradictions cannot be resolved by wording, discussions etc. b/c MWI says that there is nothing else but the QM state vector it should be possible to derive the correct observation based on the formalism = via calculations. So if the above mentioned simple branching model is wrong that's not a problem for me but for MWI (b/c it's what they quite frequently use to explain MWI); they should be able to get the model right.
The claims that I mentioned above is in summary what I expect from the MWI + decoherence:
- to get a correct (classical) and dynamically stable factorization
- to get the classically stable preferred pointer basis
- to get both the top-down and the bottom-up perspective right (correct statistical frequency for me as an observer!)
- to define branching, branch structure, branch counting and measures or to derive it from the theory
(please note that this is well-defined in the collapse interpretations; yes, it's an additional axiom and not derived from the theory, but it works FAPP; as long as this is not defined or derived for MWI than I am not convinced that MWI works FAPP = for the bottom-up perspective)
A final remark: I think I understood that diffent branches in the MWI are nothing else but infinite-dimensional "dynamically selected and dynamically stable, orthogonal superselection sectors" in the whole Hilbert space. If this is true and can be proven then I do not have any philosophical problem with the MWI. On the contrary, I would become a follower immediately. But what I learn from this discussion is that we are far from proving these claims (which is different from what I read or hear e.g. in Zeh's articles and talks!)
Maybe there is more then one way to interpret what single branch is.
Perhaps what some refer to as single branch, if you look at the mathematical definition, could also be interpreted as a (infinite?) number of identical branches.
Maybe it just makes things simpler to say there are 2 branches with different weights, rather then there are 2 sets of an of an infinite number of branches, with the infinities balanced right so that they produce the right odds.
I have very little understanding about anything though.
I think I'm much more realistic than pessimistic. I've been working in this field for more than 10 years and I had to read a lot of exaggerated claims, that are kept up despite very good evidence against them. Many physicists, who work in that field have become quite delusional, following the same route and trying to improve their arguments even though we know that they most likely won't lead anywhere. Of course this is partly due to the lack of alternatives.
Interestingly, especially Zurek and Zeh keep claiming that their approaches solve all/most problems while the community disagrees or at least remains very skeptical. I would recommend that you look elsewhere if you want something less subjective. See below.
Yes, branch counting does not work in general, and in those instances where you can make it work, they predict the wrong statistics.
Other "derivations" really don't deserve the name. The assumptions that go in there are just as good as postulating the Born rule in the first place. Zurek for example argues that, if a probability law exists (and certain stability assumptions about states in the environment are true), then it must be the Born law. This is only slightly better than Gleason's theorem and doesn't really tell us, why there should be probabilities in the first place, specifically in the realist understanding of the quantum state he refers to.
Others believe the problem is not one of physics, but one of behaving sensibly inside a quantum universe. They argue that if you wanted to bet on which reality you end up with, the best bet would be in agreement with the Born rule prediction. Of course, what they postulate without further explanation is, that the "value" assigned to the reality is proportional to the squared magnitude amplitude.
David Wallace has invested some time on these approaches and published at least two relevant papers (one with Deutsch and one alone), but these days he doesn't believe in the idea anymore. He says, that the assumptions are too strong (partly because another publication has shown that other natural betting games give completely different results), and that the Born rule should instead follow from a proof that shows, that an observer, who *assumes* the Born rule is correct, will never find good statistical evidence against his assumption.
David Wallace has written a good overview paper, but it's from 2007 and does not include the most recent publications and is slightly biased towards MWI. Still, it's a very relevant read:
David Wallace (2007) , "The quantum measurement problem: State of play"
http://arxiv.org/abs/0712.0149
And then there's Hanneke Janssen's thesis (2008) "Reconstructing Reality: Environment-Induced Decoherence, the Measurement Problem, and the Emergence of Definiteness in Quantum Mechanics"
http://philsci-archive.pitt.edu/4224/
I hope this will help to give you a perspective on the state of the art. The last 5 years have not changed anything significant. There have been papers, followed by rebuttals, iterated over a few times. No breakthroughs.
Cheers,
Jazz
I think both aspects are well covered in the two papers, I linked in my answer to tom.stoer just above. There's much more, but those two are the most complete and coherent collection of arguments I can think of right now. And David Wallace really manages to give a good and nearly objective overview. He is probably the least dogmatic well published Everettian.
And I must say that I don't really subscribe to an interpretation. I'm a realist, and that implies that I believe in some physical state and corresponding process, that explains it all. What I am looking forward to, is a physical theory, that explains observation and our experience exactly. And I think that this will necessarily come with predictions that are experimentally verifiable.
The obvious candidate for a realist theory of observation would be MWI in fact. I have worked on it for a rather long time and came to understand, that it wouldn't work out. But I still believe, that the idea of a universal quantum state with unitary evolution is a very good starting point. In order to avoid to go the MWI route from there, we have to adjust the questions to research slightly. I think, one of the reasons why MWI is flawed is the requirement for factor spaces of some sorts, but the idea of looking into subjectively relevant information (i.e. the relative state of the universe with respect to the observer in MWI) is basically right.
My alternative to MWI therefore asks the following questions:
1) What does quantum theory look like from the inside?
If you are a mechanism, realized within a quantum universe, what can you say about the universe and your environment?
MWI answers this with relative states, but those are not local. But locality is fundamental for the way we learn about our environment, because we do that by interaction. That leads to the next question:
2) How can we define and describe subsystems of the universe that are not factor spaces?
The obvious alternative to factor spaces would be parts of the universe that a spatially related. Asking for the state of a part of the universe, that is inside some horizon around an observer would be sensible for example. This is clearly not a trivial question.
3) Why can we describe the state of the local universe around us so successfully with a pure quantum state?
Considering everything we know about how to reduce global quantum sates to subsystems there should neither be a factor space representation, nor a pure state representation (but rather a density matrix) for the world we see around us. So there's definitely something missing in our understanding.
4) How would information exchange with the environment affect this local pure state?
Let's say we have found a way to describe the local quantum state from 3), then how would it react if a photon comes in and interacts locally? The photon was not part of the local description before, so it provides new information and a possible source of subjective randomness. The appearance of the new information is also abrupt and would probably require a discontinuous update of the local state.
5) What would be the laws for (4)? Is this related to quantum jumps and possibly even the Born rule?
Random jumps of the perceived quantum state suggest such a relationship. So it may be possible to derive the Born rule from the answer of questions 1-4.
6) How is the construction of the quantum state space compatible with relativity?
When we make QT covariant, we really mean that the hamiltonian and the interactions it generates are covariant (and therefore Einstein-local). The state space contains non-local multi particle states however, and those have a preferred rest frame in which the Schroedinger equation updates non-locally entangled properties instantly. This is not a problem for observations, because the non-locality only leads to correlations that are independent of the order of measurement on entangled systems and the indeterministic nature of the outcomes effectively hides all non-local aspects. This specifically makes the preferred rest frame undetectable.
If we however uncover a collapse mechanism as suggested in 5), or even only insist on a realistic picture of quantum theory, does this break relativity on some level? If not, how can the quantum state space be constructed without reference to a preferred frame?
7) If there is a mechanism associated with the collapse and the Born rule, can it be controlled?
Such control would make 6) a practical problem and might reveal the preferred rest frame, if it exists. Deterministic control over the collapse process may also result in several new physical results related to no-go theorems. For example no-cloning and no-signaling rely on indeterminstic collapses.
I believe that studying and answering these questions will advance our understanding of quantum theory. Interestingly, it seems that none of them have been answered until now, and that is surely partly to be blamed on the rather dogmatic view, that quantum theory cannot be understood in that way. And I'm afraid, that simply asking these questions will be enough reason for some to criticize me.
Cheers,
Jazz
Jazzdude: have you read Wallace's "emergent multiverse" ?
If you are a mechanism, realized within a quantum universe, what can you say about the universe and your environment? MWI answers this with relative states, but those are not local. But locality is fundamental for the way we learn about our environment, because we do that by interaction.
Thanks for sharing your thoughts. My personal opinion is that we won't get rid of the non-seperability of QM in a satisfactory way. I mean, non-locality is also present in the inside view. Or how do you take Bell tests into account?
Yes. There's nothing new in there, if you have been working in the field for many years. It's mostly an exposition of the idea for someone who has not looked into it a lot. The much better read is "Many Worlds?", also edited by Wallace, because it also contains some critical contributions.
Cheers,
Jazz
I think we have a misunderstanding there. That's not what I meant to imply. Of course, the non-separability is fundamental and Bell is very important and very right! And I wasn't meaning to imply to change anything about this.
What I meant to say way, that we have to find a way to describe a system locally, in some way. This is clearly an incomplete description, but it's what we do anyway if we describe the world around us. The observable universe does not live in a tensor factor space of the whole universe, still we are able to describe it. Clearly, we cannot just remove anything outside the horizon of observation, because of the non-separability as you rightly stated. But we have to understand how that local description relates to the whole.
Consider doing an experiment that's limited to some spatial region. We get the right experimental predictions from assuming that there is a pure state that can be assigned to the state of the experiment. And the question is, why we can do that. And how that local description that we use so successfully relates to the real state of the whole universe.
Does that make it clearer?
Cheers,
Jazz
That is a big issue for collapse interpretations. How do you define a probability, if something either happens or does not? There is no way to observe "ah this happened with 10% probability", it either happened or it did not. Performing the measurement many times does not help, all you do is calculating the "probability" of the whole experimental result (like XYYXYYYYYXXY) and you get the same issue again.
To get a meaningful probability value, you need something like the ensemble interpretation - hypothetical exact repetitions of the experiment. But then you have multiple (imaginary) observers and counting them won't help ;).
