Question: Run-around coil heat recovery systems
The discussion focuses on calculating the required mass flow rate of the second fluid in a run-around coil heat recovery system for a gas-fired furnace. The air enters at 20°C with a mass flow rate of 0.2 kg/s and an air-fuel ratio (AFR) of 12 by volume. Participants emphasize the need to determine the mass flow of the exhaust gases, which can be derived from the known densities of air and fuel, along with the AFR. The key takeaway is that the mass flow rate of the exhaust gases equals the combined mass flows of the air and fuel entering the furnace.
  • Understanding of gas-fired furnace operation and thermodynamics
  • Knowledge of air-fuel ratio (AFR) calculations
  • Familiarity with mass flow rate and density concepts
  • Basic principles of heat recovery systems
  • Calculate the mass flow rate of exhaust gases using the known densities of air and fuel
  • Explore the design and efficiency of run-around coil heat recovery systems
  • Study the impact of varying air-fuel ratios on combustion efficiency
  • Investigate methods for optimizing preheating air in gas-fired furnaces
Engineers, HVAC professionals, and energy efficiency consultants involved in designing and optimizing gas-fired furnace systems and heat recovery applications.
Lord Dark
hey guys ,, how are you all ??
guys , I've got the following problem , Air enters a gas-fired furnace at 20deg at a mass flow rate of 0.2kg/s and is burned with an air-fuel ratio by folume of 12. the gases leave the furnace at 350deg. A run-around coil system is installed to recover some of the energy of the exhaust gases in order to preheat the air entering the furnace. Calculate :
1- the required mass flow rate of the 2nd fluid.
.etc .
my problem is i don't know how to get the mass flow of the gas exiting , i have the AFR = 12 in volume , how to use it to get the gas out of the furnace ? they gave me the density of the air and the fuel only not the gas out .. should i get it density too ?
The mass rate out is the same as the combined mass flows in of the fuel and air. You know the the density of the air you can work out the volume of air which from the ratio you can work out the volume of fuel. You know the density of the fuel so you can work out the mass flow of the fuel.
  • · Replies 17 ·
