Question with slope, masses, pulley
  • Thread starter Thread starter mystmyst
    Pulley Slope
The discussion centers on calculating the acceleration of a system involving two masses on a slope and a mass hanging from a pulley. When there is no relative motion between the two masses on the slope (masses b and c), they must share the same acceleration due to the constraints of the pulley system. The net force acting on the system is derived from the weight of mass d, with the equation m_dg = (b+c+d)a applicable when friction is absent. In the presence of friction, the equation modifies to m_dg - f_k = (b+c+d)a, where f_k represents the frictional force acting on the masses on the slope.
  • Understanding of Newton's Second Law (F = ma)
  • Knowledge of pulley systems and their constraints
  • Familiarity with forces acting on inclined planes
  • Concept of friction and its effects on motion
  • Study the dynamics of pulley systems in physics
  • Learn about inclined plane mechanics and forces
  • Explore the role of friction in motion equations
  • Investigate the effects of mass and acceleration in multi-body systems
Students studying physics, particularly those focusing on mechanics, as well as educators seeking to clarify concepts related to forces, motion, and pulley systems.
mystmyst
[PLAIN]http://img413.imageshack.us/img413/4452/mechanicsdiagram2.png
There is no friction between mass c and the slope. The pulley and rope have no mass. The coefficient of friction between the two masses on the slope is \mu_1
Get an expression for the acceleration of the system of masses when there is no relative motion between the two masses on the slope.
There is something I don't get: If there is not relative motion between the two masses on the slope, then each mass has a different acceleration. The question makes it seem that I should still find a total acceleration of the entire system but I don't think that is possible.
Also, even though b and c have different accelerations, c and d still have the same acceleration, correct?
So, the way I would do it is find the acceleration for b, and find the acceleration for c and d. Is that correct or is there really one unifying acceleration?
I think you are very confused here.
Firstly, b and c, if there is no relative motion between them, they must have the same velocity and acceleration.
Now, they can have the same acceleration but different force acting on them.
F = ma, they have different masses, hence they have different magnitude of force acting on them. This is because you need more force to accelerate something that is heavier (to be precise, more inertia).
Also, the acceleration of d is the same as acceleration of b and c. d cannot accelerate more than b and c since the rope cannot stretch, or break for all that matter.
Acceleration of d cannot be less that b and c, if not the string will not be taut.
delzac
ooo. I thought relative motion means they are moving together at the same velocity and acceleration. So if there is no relative motion they are moving at different velocities and different accelerations.
Thanks for clearing that up.
so basically the only force acting on the system is the weight from mass d. so:
m_dg = (b+c+d)a
correct?
and if there was friction between the mass and the slope it would be:
You have to take into account that the the force is not one sided, meaing, b and c also provides a force in the opposite direction.
The difference in the 2 forces will determine if the mass will move in either direction.
o you i forgot about the mg\cos \alpha and mg\sin \alpha stuff...
thanks
When I am calculating the net force, do I also include the force from the small mass (with mass b):
bg\sin \alpha
or I don't since the friction cancels it out?
as in either:
dg - cg\sin \alpha = (b+c+d)a
or
dg - cg\sin \alpha - bg\sin \alpha= (b+c+d)a
Well, you will have to take into account both mass, since both b and c is tugging on the rope. You can imagine that there are glued together, so their mass will have to add up.
I know I take their mass into account. that's why i have (b+c+d)a
but my question is referring to the net force. Do I take into account the force from the smaller mass or since the friction cancels it out (which is why it is not moving) I only take into account the large mass.
Like i said, b and c is as good as glued together, meaning you should treat them as one object.
gotcha!
Thanks.
  • · Replies 18 ·
  • · Replies 30 ·
  • · Replies 22 ·
  • · Replies 17 ·
  • · Replies 22 ·
  • · Replies 40 ·
