Staff Emeritus
2025 Award
- 22,736
- 7,836
Well, nuclear systems generate thermal energy, so they are a fancy way to generate heat, which is usually transferred to a working fluid. The working fluid(s) transfer energy and momentum to turbomachinery, which is used to drive a generator to produce electricity.aquitaine said:This seems (at least from my POV) to be a really low tech and inefficient way to turn the heat into actual work. The turbine method was invented in the 19th century, surely there must be a more advanced method for getting work out of it. The Tokamak operates on plasmas, maybe that could be utilized somehow.
In the case of a plasma, two possibilities are extracting energy directly from the plasma as it expands against the magnetic field, or use charge separation. The strategy depends on the system geometry, i.e. plasma confinement and magnetic field configuration.
