Which Capacitor Questions Did I Get Wrong?
  • Thread starter Thread starter r3dxP
    Capacitors
The discussion centers around a user seeking help with capacitor problems from a textbook, specifically identifying incorrect answers and understanding the concepts behind them. The user suspects errors in questions 4 and 5, which involve the behavior of capacitors in parallel and series configurations. Key clarifications include that in series, the total capacitance is always less than the smallest capacitor, and in parallel, the voltage across both capacitors remains the same. The correct answers for the questioned items are confirmed as 4 for question 1, 1 for question 4, and 2 for question 5. Understanding these principles is crucial for solving capacitor-related problems effectively.
r3dxP
hey guys, i did these problems out of my book for review and it does not give me the answers. So if you could please, tell me which ones I've got incorrect and if you don't mind explaining and writing down the correct answer for the wrong answer will be awesome! Thanks in advance. (BTW, I think I got #4 and #5 incorrect because I didn't know how to do it.)
1)If three capacitors of values 1.0, 1.5, and 2.0 mcirofarads each are connected in series, what is the combined capacitance?
1) 4.5 microfarads
2) 4.0 microfarads
3) 2.17 microfarads
4) 0.46 microfarads
i got 3)
2)Increasing the separation of the two charged parallel plates of a capacitor which are disconnected from a battery will produce what effect on the capacitor?
1) increase charge
2) decrease charge
3) increase capacitance
4) decrease capacitance
i got 4)
3)If three capacitors of values 1.0, 1.5, and 2.0 mcirofarads each are connected in parallel, what is the combined capacitance?
1) 4.5 microfarads
2) 4.0 microfarads
3) 2.17 microfarads
4) 0.46 microfarads
i got 1)
4)There are two capacitors with A bigger than B and they are connected in parallel with a battery.
1) There is more potential difference across A.
2) There is more potential difference across B.
3) There is the same charge stored on each capacitor.
4) There is the same potential difference across both capacitors.
i got 2)
5)There are two capcitors with A bigger than B and they are connected in series with a battery.
1) There is more charge stored on A.
2) There is more charge stored on B.
i got 4)
6)The plates of a parallel-plate capacitor are maintained with constant voltage by a battery as they are pulled apart. During this process, the amount of charge on the plates must ...
1) increase
2) decrease
3) remain constant
4) either increase or decrease. There is no way to tell from the information given.
i got 2)
7)Doubling the voltage across a given capacitor causes the energy stored in that capacitor to ...
1) quadruple
2) double
3) reduce to one-half
4) reduce to one-fourth
i got 1)
8)If the electric field between the plates of a given capacitor is weakened, the capacitance of that capacitor ...
1) increases
2) decreases
3) does not change
4) cannot be determined from the information given
i got 3)
9)A parallel-plate capacitor has a capacitance of C. If the area of the plates is doubled and the distance between the plates is halved, what is the new capacitance?
1) C/4
2) C/2
3) 2C
4) 4C
i got 4)
10)A dielectric material such as paper is placed between the plates of a capacitor. What happens to the capacitance?
1) no change
2) becomes larger
3) becomes smaller
4) becomes infinite
i got 2)
for series capapcitors you add them like so
C_{eq} = \frac{C_{1} C_{2} C_{3}}{C_{1}+C_{2}+C_{3}}
for parallel plate capacitors the capacitance is given as
C = \frac{\epsilon_{0} A}{d} whee d is the separation between the plates
also dieletrics have the certain effect on capacitance
for a parallel plate capacitor for example :
C = \frac{\kappa \epsilon_{0} A}{d} where k si the dielectric constnat of whatever what placed in betweren the plates
accordinly do your calculations
For 4 and 5
What happens in a parallel and series circuit (speaking in terms of voltage (potential difference)? You can even forget about the capacitors, just think about the rules for series and parallel circuits for a second.
1) no change
2) becomes larger
3) becomes smaller
4) becomes infinite
i got 2)
Thats correct.
For question one, I'd consider: the total capacitance of a circuit comprised of a series connection of capacitors is ALWAYS less than the smallest capacitor in the circuit. From a qualitative view, you can eliminate a lot of bad choices..
For question five, consider: since the capacitors are series connected, they have the same charge in each capacitor. Q = C x V, or V = Q/C. With smaller Capacitance and same charge Q, would the voltage across the capacitor be greater, or lesser?
so for #1, its 4
#4, its 1
#5, its 2
right? yes no?
for Ques 1--- always take care that the resultant capacitor in series combination is smallest of all
#4 voltage is same in parallel combination
#5 charge is same in series combination
Do follow any good book .any university level
