Can a Moon-Sized Spinning Sphere Create Livable Artificial Gravity?
A hollow sphere the size of the moon, spun to create 1g of centripetal acceleration, raises significant engineering questions regarding structural integrity, gravity variations, and habitat design. The maximum height of structures on the equator is limited by material stress, with tapered designs potentially mitigating some gravitational effects. Traveling around the equator at 1000 kph alters artificial gravity by approximately 0.15g, suggesting that efficient transportation methods, such as tethered systems, are essential. Additionally, filling the uninhabited hemispheres with water could disrupt the habitat's spin, necessitating careful consideration of drag and water dynamics.
  • Understanding of centripetal acceleration and its effects on artificial gravity
  • Familiarity with structural engineering principles, particularly in large-scale constructions
  • Knowledge of fluid dynamics, especially in rotating systems
  • Awareness of concepts related to habitat design in space environments
  • Research the engineering principles behind Bernal spheres and their applications
  • Explore the effects of rotational dynamics on fluid behavior in large habitats
  • Study the implications of gravity variations on structural design and material selection
  • Investigate transportation systems suitable for high-speed travel in rotating habitats
Aerospace engineers, architects specializing in large-scale structures, physicists studying artificial gravity, and anyone interested in advanced habitat designs for space colonization.
Adrovane
Consider a hollow sphere roughly the size of the moon, spun up to produce 1g of centripetal acceleration along a band at its equator (about 15000 kph)
Big stuff, I know.
I have a few questions about the implication of such a system, and I hope someone can help me find some answers!
- How tall could a structure be on the equator? Is there a point where the structure would undergo too much stress from th difference in gravity from its base to its top?
-Travelling around the equator at speeds of about 1000 kph will increase or decrease the artificial gravity by about 0.15g if my calculations are correct, but would it be more efficient to connect various posts if the habitat with "chords" that cross through the centre of the sphere?
-What happens if you leave the equator and begin walking towards the poles? Would some kind of curved or twisted track be able to compensate for the gravity changes?
-Could the uninhabited volumes of the north and south hemispheres be filled with water? How would this affect the spin of the habitat?
-Assuming there is a kind of sun window at one pole, could the axis of rotation be made to process over a 24 hour-ish period to simuladmte a day-night cycle? Or is that kind of speed unstable?
Wow, a lot to talk about- sorry if it's a bit much, but I'd love to hear any ideas you may have!
In case you've not seen it designs for spherical rotating habitats exist in the form of Bernal spheres:
https://en.wikipedia.org/wiki/Bernal_sphere
Big stuff, I know.
Likely too big for that acceleration. An engineer called McKendree worked out the largest diameter of a cylinder rotating at 1g using carbon nanotubes for a NASA conference years ago, IIRC they were 1000km in radius. Any bigger and the force from their rotation would rip them apart.
Difficult question to answer given that the structure can be tapered significantly. Also if you're capable of building something that big you could string a tether between two sides.
Going around a circle to the opposite side rather than cutting through the middle covers 1.57x the distance (half pi). So long as your elevators were capable of climbing the spoke cables at >1/1.57 times the speed of whatever vehicle averages 1000kph around the rim then yes that would be faster.
The ground gets steeper and you get lighter. You could have a series of switchback paths to compensate for the steepness, but you'd want to tether yourself to something to prevent floating off at altitude. You'd also want to bring a space suit because the atmosphere isn't going to extend hundreds-thousands of kilometers.
If you just suspend water anywhere in the center of the rotating structure it will just float there, given that it's above the atmosphere and not touching anything that will cause it to be pushed/dragged to the edges. Not sure why you'd want to do this though.
If you can build a megastructure of this sort you can certainly arrange a mirror at the pole that rotates at a different speed to the whole, reflecting in light for only half the day.
The difference in gravity is not a problem, it's an advantage. You get the upper parts to weigh less, so cause less stress on the lower bits than they would on Earth. It let's you build a taller building. But, given the size of the habitat, it won't be that much of an advantage. You should assume the practicalities of building construction to be roughly the same as on Earth.
(I'm assuming you're thinking of structures built on the inside here)
I was thinking more that it would be covering the inner surface of the sphere like a lake - I was unsure whether a) the water would stay on the inner surface and b) not interfere with the habitat's spin by perhaps increasing drag
Thank you for your reply! I have seen the Bernal Sphere before, though I wasn't aware of it when I first started toying with this idea - and the tapering tower, plus Bandersnatch's comment about decreasing stress on the materials, make things a lot easier
Sure, but this structure is 3500km in diameter. The summit of a dozen Everests stacked on top of each other has just a 3% difference in pseudo gravity to the base. It’s likely a static structure is unlikely to get up to a size that the gravitational difference is that helpful. Not unless it’s incredibly tapered or uses other clever tricks.
The water touching the wall will be slowly spun, as that force propagates out it will cause the “lake” to disperse. Much of it will fall down the inner surface increasing in speed until it crashes to the rim. Most of it will probably spray outwards, hitting the inner rim at a later time.
Could this precipitate (heh) some kind of water cycle?
Is there a certain volume that will mean that parts of it would become unbound by the centripetal force and drift into the centre? That water would then fall into the rim and, if it is raised, drain back into the "seas", replenishing them?
I may not be thinking about this in quite the right way, but that's why I'm asking!
Things like this often sound good in my head but have nothing to do with real physics
In a structure of this size I'm pretty sure you'd have rain the same as on a planet. Heat from the sunlight reflected through the poles causes water bodies to evaporate, it rises up several kilometers into the thinning atmosphere where it cools and condenses into clouds and later falls as rain.
Adrovane said:
-Assuming there is a kind of sun window at one pole, could the axis of rotation be made to process over a 24 hour-ish period to simuladmte a day-night cycle? Or is that kind of speed unstable?...!
See the Banks orbital from Iain Banks' culture series. The Banks orbital is not possible with an material that exists. That is also true of your sphere.
That this is sort of the wrong question. A structure like a tower can at most "only" be the radius in material (moon =1740km). The tower also gets lighter as it rises. The more difficult problem is a thin layer of dirt. All of the dirt is adding weight to the equatorial ring. So 10 cm by 10m of damp topsoil with grass is also 10,900 kilometers around the diameter. That would add 10 million tons of mass. The spheres' structural material that supports the 10 million tons of grass also adds mass which needs to also be supported.
If you switch your building architecture style to chandelier type structures(video) you use much less material. They should hang down and not touch the "ground".
  • · Replies 28 ·
  • · Replies 159 ·
15K
  • · Replies 52 ·
