Questopn about phase shift SHM
The discussion centers on determining the phase constant (\(\phi\)) in simple harmonic motion (SHM) when the initial displacement is zero and the initial velocity is directed negatively along the x-axis. The equation provided is \(x(t) = x_m \cos(\omega t + \phi)\). It is established that for \(x(0) = 0\), \(\phi\) must equal \(\frac{\pi}{2}\) to satisfy the cosine condition. Additionally, since the initial velocity \(v(0)\) is negative, it confirms that \(\sin(\phi)\) must be positive, reinforcing that \(\phi\) is indeed \(\frac{\pi}{2}\).
  • Understanding of simple harmonic motion (SHM)
  • Familiarity with trigonometric functions, specifically sine and cosine
  • Knowledge of phase constants in oscillatory systems
  • Basic calculus, particularly differentiation for velocity calculations
  • Study the derivation of phase constants in SHM scenarios
  • Learn about the graphical representation of cosine and sine functions
  • Explore the implications of initial conditions on oscillatory motion
  • Investigate the relationship between displacement, velocity, and phase in SHM
Students and educators in physics, particularly those focusing on mechanics and oscillatory motion, as well as anyone seeking to deepen their understanding of phase shifts in simple harmonic motion.
Saladsamurai
Question about phase shift SHM
The displacement of an object is given by
x(t)=x_mcos(\omega t+\phi)
If the inital displacement is 0 and the initial v is in the negative x direction, then the phase constant must be ___rads
I know that if x=o then the cosine of the phase must be 0
\cos(\omega t+\phi)=0
so\omega t+\phi=\frac{\pi}{2}
and I am stuck from here...hints?
Initial means t=0. So x(0)=xm*cos(phi). phi=pi/2 works for that. Is v(0) negative? If so then you have a solution.
v is in -x direction...that is where I am most confused, does that just mean that phi has to be negative?
It means v=dx/dt is negative at t=0.
Okay...
so if v=-\omega x_m\sin(\omega t+\phi)=-
and x_m=+
t=0
then -\omega x_m\sin(\phi) is negative
so sin(phi) is positive
Thus, phi=+pi/2
Does that check out?
Looks ok to me. Draw a graph of cos(x) if you don't believe me.
I will...cause I don't.
No I won't...cause I do.
but I probably should so I can see the relationships...
Thanks again Dick.
  • · Replies 20 ·
