Quiz: Why/how does this circuit oscillate?
  • Thread starter Thread starter gnurf
    Circuit Quiz
11 replies · 5K views
gnurf
I hooked up a small circuit I found towards the bottom of this url and plotted the result in a spreadsheet (figure 1). Figure 2 shows the DC-coupled output waveform at 12V input. Only the frequency changes at different input voltages.
So what's going on here?
Figure 1:
Figure 2:
Hint 1: Relaxation oscillator
Hint 2: http://www.eng.yale.edu/ee-labs/morse/compo/datasheets/2n2222.pdf
Hint 3: PN junction
EDIT - To avoid confusion: The Vce voltage from the table in Figure 1 is the 'DC' voltage measured with a multimeter.
gnurf said:
I'm sorry, there's no price for copying the link from the top of the OP, but thanks for playing. :D
P.S I suspect you're over-qualified for this quiz.
Crap, I didn't even notice you had that same link in the OP. I just scanned the thread and remembered I'd seen the circuit before somewhere.
It's the breakdown behaviour of bipolar transistors when the base is open. This voltage shows a hysteresis, because it take a minimum "base" current to have a current gain that reduces the breakdown voltage.
Many things are reverse polarized in your diagram. The capacitor can't be intentional. The transistor is probably intentional, in order to use the smaller base-emitter breakdown voltage. Though, as the reverse current gain is smaller, so is the hysteresis.
In real life, this would be more difficult to observe. I suspect the simulator introduces some "software" hysteresis by "deciding" if the junction avalanches.
Simulator? The circuit and waveform are real.
There are so many oscillator circuits, I don't think I want to turn the NPN around and play with it like this. Do it the right way, tricks don't pay.
It is common knowledge that reversing the BE junction, you get a zener diode. But you don't do that because it's not meant to be and it's not guaranty that different parts behave the same, also degradation can happen if you use the part that's not designed to do, this is a no no in real world design. In real design, predictability and reliability is much more important than little wise tricks. Look up some simple oscillator circuits.
It was a real circuit, not simulated, but apart from that Enthalpy's explanation is spot on. Well that is to say, it agrees entirely with my interpretation of the circuit. :smile:
A BJT will work with emitter-collector interchanged, but typically with very much reduced current gain and very much reduced breakdown voltage.
But this hysteresis or should I say a negative resistance effect between collector and emitter junction. Occurs only for NPN transistor.
Long time ago I measure reverse-bias voltage from emitter to base and emitter to collector in general purpose BJT
For PNP
BC556
Vbe=10V; Uce=10.65V
BD140
Ube=12.55V ; Uce=13.02V
And for NPN
BC337-40
Veb=8.2V; Vec=6.7V; I=5.5mA
BC549B
Veb=8.3V; Vec=7.2V; I=5.5mA
BD139-16
Veb=8.5V; Vec=6.7V; I=5.5mA
BC639
Vbe=7.7V; Vec=6.3V; I=500uA
BC337
Veb=7.9V; Vec=6,4V; I=500uA
2SC945
Veb=8.1V; Vec=7,5V; I=500uA
As you can see for NPN BJT's the Vec voltage is smaller than Veb breakdown voltage.
http://www.cappels.org/dproj/simplest_LED_flasher/Simplest_LED_Flasher_Circuit.html
Thanks for sharing that info Jony. I suspect that the difference is not so much one of npn versus pnp, but rather due to differences in the reversed (c-e interchanged) current gain of the various transistors. I don't know if there's any systematic reason why pnp transistors would have a lower "reversed" current gain than npn types. Perhaps there is, though I can't think of anything off hand.
Current gain is usually relatively low in the "reversed" configuration, and if it is extremely low then we would expect little differences between the Vceo and Vcb breakdown voltages. This discrepancy (between the Vceo and Vcb breakdown voltages) is well known in both npn and pnp types, and in each case is due to the current amplification of the leakage in the Vceo (open cct base) configuration.
My oops!
As Jony130 observed that
- the (small) reverse current gain does not drop the breakdown voltage of a PNP with open base,
- this is consistent with only NPN oscillating
- and with the explanation through (reversed) Vces and Vceo.
The few times I tested a reverse beta for PNP, it has nothing shocking. There was some gain, not strikingly lower than for an NPN, so I suppose this is not a sufficient explanation.
My complementary explanation, but it's not trivial.
Avalanche is not symmetric. To sustain itself, it needs new electrons and holes be brought in the impact zone, otherwise the avalanche is just blown away by lack of one carrier. This, in conjunction with a varying field strength, is used in some particle detectors (proportional avalanche) to multiply the charge without runaway.
Now, electrons are more efficient than holes to create new pairs. It's a matter of mass (similar to impedance matching, fit E and p instead of U and I) between already energetic carriers and the E and p of the bandgap.
Reverse-avalanche the emitter-base of an NPN: electrons are injected in the emitter, holes in the not-depleted base region, and at the limit holes don't create new electrons efficiently by impact. Now, these holes make a base current which the reverse beta can amplify, letting the collector inject fresh electrons in the base which supplement the inefficient impact of holes. So (reverse) beta helps an NPN avalanche.
In a PNP, electrons leave the depleted zone in the base, and these can create new holes by impact efficiently. So beta helps avalanche less in a PNP (a reversed PNP).
There can be more reasons. Production processes aren't symmetric, for instance As (N dopant) diffuses very little in Si, B diffuses faster and P even faster, so As emitters achieve a steeper emitter profile that improves NPN transistors. Electrons are more mobile as well, and so on.
Current gain has much to do with doping profile and ratio (and very little with carrier lifetime, sorry books and teachers) so the reverse beta is not easy to justify. Compare doping in thee xpiaxial collector with doping in the base very near to the junction, and as well the dopant gradient within the base...
