Radiation from an ideal LC tank circuit
The discussion focuses on calculating the power radiated per cycle in an ideal LC tank circuit due to accelerating charges. The current is modeled as i(t)=Ae^{j\omega t}+Be^{-j\omega t}, with \omega=\frac{1}{\sqrt{LC}}. The Larmor radiation formula is applied to derive the power expression, leading to a discrepancy with Feynman's result from the Feynman Lectures, Volume 1, Section 32.2, which presents P=\frac{1}{3}\frac{e^2\omega^4}{c^3}. The discussion seeks clarification on this discrepancy and the assumptions made regarding charge density and instantaneous acceleration.
  • Understanding of ideal LC tank circuits
  • Familiarity with differential equations and oscillatory motion
  • Knowledge of the Larmor radiation formula in Gaussian units
  • Basic concepts of charge density and instantaneous acceleration
  • Study the derivation of the Larmor radiation formula in detail
  • Explore the implications of charge oscillation under simple harmonic motion (SHO)
  • Investigate the differences between classical and quantum mechanical treatments of radiation
  • Learn about effective resistance in oscillatory circuits and its applications
Physicists, electrical engineers, and students studying electromagnetic theory, particularly those interested in radiation from oscillating charges in circuits.
confuted
Consider an ideal LC tank circuit with some initial conditions such that oscillations take place. I am trying to find the amount of power radiated per cycle due to the accelerating charges (I realize that this should come out to be a very small value).
Setup and solve the relevant differential equations, and you'll get
with \omega=\frac{1}{\sqrt{LC}}. Here I am using i(t) as current, and j=\sqrt{-1}. For appropriate initial conditions, we can take
i(t)=A\sin{\omega t}.
Now the instantaneous current is equal to some charge density multiplied by the instantaneous velocity of the charge carriers:
i(t)=\rho v. (Is this a valid assumption?)
So the instantaneous acceleration of the charge carriers is
a(t)=\frac{dv}{dt}=\frac{d}{dt}\frac{i(t)}{\rho}=A\omega\cos{\omega t}
The time average of the square of this acceleration is
a^2=<a^2(t)>=\frac{A^2\omega^2}{2}
Now (in Gaussian units), the Larmor radiation formula is
P=\left(\frac{2}{3}\right)\frac{e^2<a>^2}{c^3}=\left(\frac{1}{3}\right)\frac{e^2A^2\omega^2}{c^3} (*)
We could model this (as far as the circuit is concerned) as an effective resistance. The power dissipated in a resistor is
P=i^2*R
Taking time averages and substituting in (*),
R=<P>/<i^2>=\left(\frac{2}{3}\right)\frac{e^2\omega^2}{c^3}
All seems well and good, except that Feynman (Feynman Lectures, Volume 1, Section 32.2) derives a similar formula for charge oscillating under SHO. His result seems to be
P=\frac{1}{3}\frac{e^2\omega^4}{c^3} (I've dropped his x02 factor.)
Where's the discrepancy?
Science news on Phys.org
Sorry to bump my thread, but I feel like it didn't get much attention because of LaTeX being down after the move. Does anybody have some insight here?
I can imagine a fudge. :rolleyes: Take Q(t)=Acos(wt). Then you can differentiate twice to get another power of w.
  • · Replies 21 ·
  • · Replies 23 ·
  • · Replies 19 ·
  • · Replies 0 ·
