Radioactive Decay Rates and the Relationship between Decay Constants
The discussion centers on the relationship between decay constants D1, D2, and D3 in a radioactive decay scenario involving nuclei A, B, X, and Y. The key conclusion is that for nucleus B to first increase, peak, and then decrease, the condition D1 > D2 + D3 must be satisfied. The participants also explored the mathematical relationships governing the decay rates, specifically the equations dN2/dt = N1D1 - N2(D2 + D3) and dN1/dt = -D1N1, which describe the dynamics of the system over time.
  • Understanding of radioactive decay and decay constants
  • Familiarity with differential equations and their applications in decay processes
  • Knowledge of integrating factors in calculus
  • Basic principles of parallel disintegration in nuclear physics
  • Study the derivation of decay equations in radioactive decay scenarios
  • Learn about integrating factors and their use in solving differential equations
  • Explore the concept of parallel disintegration in more depth
  • Investigate the implications of decay constant relationships in nuclear physics
Students of nuclear physics, educators teaching radioactive decay concepts, and researchers interested in the mathematical modeling of decay processes.
Krushnaraj Pandya
Consider nucleus A decaying to B with decay constant D1, B decays to either X or Y (decay constants D2 and D3). at t=0, number of nuclei of A,B,X and Y are J,J,0 and 0. and N1,N2,N3 and N4 are the number of nuclei of A,B,X and Y at any instant.
My question is, what is the relation between D1,D2 and D3 for B to first increase, peak and then decrease?
rate of decay = DN
I figured the rate of accumulation of B is N1D1- N2D2- N3D3, since this also involves N, I don't know how to figure out a relation between D1,D2 and D3 alone for the specified conditions. I also figured out that no matter what D1,D2,D3 are- after a long time B will have zero nuclei (so will A).
If D1 is greater it will cause a peak but I'm not sure how the values will change with subsequent change in N
Your equation should read ## \frac{dN_2}{dt}= N_1D_1-N_2D_2-N_2D_3 ##, with an ## N_2 ## in the 3rd term. ## \\ ## When ## N_1D_1=N_2(D_2+D_3) ## that will be when ## N_2 ## peaks, with ## \frac{dN_2}{dt}=0 ##. ## \\ ## You can actually solve the equation ## \frac{dN_1}{dt}=-D_1 N_1 ## for ## N_1(t) ## , and plug into the ## \frac{dN_2}{dt} =N_1 D_1-N_2(D_2+D_3) ## equation, and solve this equation for ## N_2 =N_2(t) ##. (It's been a while since I did this particular calculation, but I believe it uses a technique of integrating factors). ## \\ ## As I remember it, when you have ## \frac{dX}{dt}+AX =f(t) ##, (where ## X=X(t) ##), you can multiply both sides by ## e^{At} ##, (called an integrating factor), and the left side is then ## \frac{d(Xe^{At})}{dt} ##. The right side has ## f(t)e^{At} ##, and you can then integrate to get ## Xe^{At} =\int f(t) e^{At} \, dt ##.
Interesting, I understand this for the most part but I doubt my textbook wants me to derive the answer using the calculus you mentioned since only basic parallel disintegration is in our course- the answer given is simply D1>D2+D3 for the given conditions to occur, is there a simple intuitive way to know that?
I believe ## N_2 ## will always experience a peak. If ## D_2 ## and ## D_3 ## are very large, that will occur when ## N_2 ## is very close to zero and ## N_1 ## very close to its initial value. In this case, I believe your book has an incorrect answer. The equation that I posted is the correct equation: ## N_1 D_1=N_2(D_2+D_3) ##
I understand, thank you very much :D
  • · Replies 24 ·
  • · Replies 17 ·
