Radioactive decay: Solve for delta t
The discussion revolves around a problem involving radioactive decay, specifically calculating the time difference (Δt) between two isotopes based on their proportions at different times. The subject area includes concepts of decay rates and relationships between isotopes.
  • Participants explore the relationship between decay rates (λ) and the proportions of isotopes over time. Questions arise regarding the necessity of knowing the decay constants and whether one or two decay rates are applicable in the scenario. There is also discussion about dimensional analysis and the implications of having only dimensionless ratios.
The discussion is ongoing, with participants providing insights into the relationships between the isotopes and their decay rates. Some guidance has been offered regarding the mathematical relationships, but there remains uncertainty about the specific scenario being addressed and the implications of the decay rates involved.
There is a lack of explicit information regarding the decay rates (λ), which is a critical factor in solving the problem. Participants are navigating the implications of different interpretations of the decay process, whether it involves one isotope converting to another or two isotopes decaying independently.
Lagraaaange
Two isotopes N1, N2. You are given the value of the proportions N1(t1)/N2(t1) and N1(t2)/N2(t2). From this calculate Δt.
dN/dt = -λN
Solve dN1/N = -λdt and dN2/N = -λdt
obtain: N1(t2) = N1(t1)exp(-λ1(t2-t1)) (1)
and N2(t2) = N2(t1)exp(-λ2(t2-t1)). (2)
[/B]
Divide (1) by (2) and take ln of both sides
=> ln[(N1(t2)/N2(t2))/(N1(t1)/N2(t1))] = (-λ1+λ2)(Δt)
Okay so if I'm given the proportions (say X) I can get a numerical result for left hand side
ln(X)/(-λ1+λ2) = Δt
But if I'm not given the λ's how can I obtain them? I feel like I'm missing some relationships between λ and the proportionality constants.
I'm not sure whether there are supposed to be two lambdas or one. Maybe the only process is the conversion of the one isotope to the other?
But either way, you're right: you do have to know some rate. This is very easily proved by dimensional analysis. If the only info you have consists of two dimensionless numbers, no valid physical equation is going to produce an answer that has a physical dimension, such as time.
1. Is this "right" in terms of variables; that is, are the mathematics and physics ok?
2. In the case of one isotope being converted to the other I would have one λ? I would still need the constant to be provide, right? I mean I'd need a half life or something if I don't have λ given.
Yes, what you wrote is correct for two separate isotopic decays. And yes, even if it is conversion from one to the other you still need to be given the rate.
Can you see how to change your result for λ1 and λ2 very simply to get the conversion case result?
I don't see it. If I change it to a conversion of one to the other wouldn't I have a differential equation of the form: d(N2-N1) = -λdt
No, it would not be of that form. The equation for the decaying isotope does not change. The quantity of the decay product follows easily from that.
But the "very simple" modification I was thinking of doesn't work either.
If the rate is for one isotope to another, wouldn't the lambdas just cancel out? I mean would giving 1 lambda even make sense given two rates at two times?
It would cancel in terms of the total number of atoms, but not in terms of the ratio. One will gain what the other loses.
Consider the last line in my outline. It would be -λ+λ = 0. This would result in a nonsensical answer. Also this tells me that λ2 must be greater than λ1 unless the ratios result in less than 1 in which case the log would be negative and I'd be ok. I have an exam on a question of this type so I'm trying to make sense of this.
One isotope decaying into the other is different from both decaying at the same rate. It is not -λ+λ.
How does one obtain the conversion result, say where one isotope is converted to another?
You know the decay from the one. What that loses, in terms of number of atoms, the other gains.
Suppose at time t a sample N1 goes to N2 with rate λN1.
Then N1(t) = Kexp(-λt). Let us choose t=0 to be when no particles decayed. Let N0 be total amount of particles, (N1+N2), thus N1(0) = N0
=> N1(t) = N0exp(-λt).
Note N0-N1(t) = N2(t) = N0(1-exp(-λt))
So N1(t)/N2(t) = N0exp(-λt)/N0(1-exp(-λt)) = 1/exp(λt)-1
if N1/N2 = R1, 1/exp(λt1)-1 = R1
=> exp(λt1) = 1+1/R1
Repeating we get, exp(λt2) = 1+1/R2
Dividing: exp(λΔt) = R1(R2+1)/R2(R1+1) and simplifying,
Δt=ln[(R1(R2+1))/(R2(R1+1))] / λ
What do you think?
What do you think?
Looks right.
haruspex said:
Looks right.
Thanks. Let's hope my professor agrees.
Bear in mind that we do not know for sure which scenario is intended: one isotope decaying into another, according to one decay rate, or two isotopes decaying into two other isotopes, at two distinct decay rates. Since no decay rates were provided, we can't tell.
But I've got both case down, right? The former being for two isotopes into two and the latter for one to another?
Yes.
