Radioactivity & Specific Heat Capacity Question
The discussion focuses on a homework problem involving the decay of radium-226, specifically calculating its decay constant, curie measurement, energy release per decay, and estimating the time required for a temperature increase in a sample. The decay constant was determined to be 1.4x10^-11 s^-1, and 1 curie equals 3.7x10^10 Bq. The energy released during the decay of a single Ra-226 nucleus is calculated as 7.9x10^-13 J. The main challenge lies in part c), where the user seeks clarification on calculating the time needed for a 1°C temperature rise, incorporating the energy absorbed from decaying nuclei. The discussion emphasizes the need to correctly apply the equations for energy and decay to solve for time.
Magda|A380
0.2g of a radium salt was separated from a ton of uranium ore. The radioactive radium nuclide Ra-226 decays by alpha-particle emission with a half-life of 1600 years. 1 year = 3.16x107s.
The curie is defined as the number of disintegrations per second from 1.0g of Ra.
Show that:
a)i) the decay constant of the radium nuclide is 1.4x10-11 s-1
ii) 1 curie equals 3.7x1010Bq
b) Show that the energy release in the decay of a single nucleus of Ra-226 by alpha-particle emission is 7.9x10-13J.
nuclear mass of Ra-226 = 226.0254u
nuclear mass of Rn-222 = 222.0175
nuclear mass of He = 4.0026u
c)Estimate the time it would take a freshly made sample of radium of mass 0.2g to increase in temperature by 1oC. Assume that 80% of the energy of the alpha particles is absorbed within the sample so that this is the energy which is heating the sample. Take the specific heat capacity of radium to equal 110Jkg-1K-1. Use the data from a) and b)
For a)i) I used λt1/2 = 0.693
For ii) I used A = λN (I used Avogadro's constant to find N of 1.0g of Ra-226.)
For b) I used E = Δmc2; 1u = 1.661x10-27kg
For c) E=mcΔT
Both part a) and b) were fine, but I'm having trouble with part c)
I was thinking of using E = mcΔT and having E = 0.8 x 7.9x10-13, m = 2x10-4kg, c=110; what value of ΔT should I be using? I thought it should be 1 because the temperature is being increased by 1oC? However, that doesn't fit the equation. Also, how can I find the time from this? Should I equate E to Qt or should I be using a different equation?
Sorry this is so long; I included parts a) and b) as they might be needed to work out part c).
Any help would really be appreciated.
Thanks :smile:
find no. of nucleus decayed in time t.
use this to calculate energy released in time t.
then, E=mcΔT.
then, E=mcΔT.
How would I go about finding the no. of nuclei decaying in time, t? I was thinking of using N = N0e-λt; but which values should I use for N0 and N?
I worked out, using Avogadro's constant, that 0.2g of radium-226 has 5.3x1020 nuclei. The question says that 80% of the energy of the alpha-particles heats the sample; so 0.8 x 7.9x10-13 = 6.3x10-13J. So I thought that to find the amount of energy required to heat 0.2g of radium, I'd have to multiply it by the number of nuclei in 0.2g of radium. I tried incorporating this into E=mcΔT, but I'm still not sure how to figure out the time from this :confused:
Thanks again :smile:
Could anyone help with the above question? My exam is in less than a week...
Thread 'Correct statement about a reservoir with outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
