spareine
- 129
- 39
And may be this helps: each raindrop of the rain curtain is represented by a single pinhole in the screen.
A nearer parallel could be the limited field of view through a small mirror.Orodruin said:just as you cannot see an object behind a wall if there is no window in the object's direction.
Yes. That, again, is fairly obvious at this stage in the discussion. In fact I really don't see where the last few posts have been going. A straightforward rainbow was explained to me when I was 15 years old or less and the whole class got the whole thing except the position of the image (not discussed ). Non-standard rainbows have been dealt with.spareine said:each raindrop of the rain curtain is represented by a single pinhole in the screen.
Only if you put a lot of other mirrors arranged with their surfaces parallel to the first small mirror such that you never really lose sight of the object.sophiecentaur said:A nearer parallel could be the limited field of view through a small mirror.
Sorry about the late reply computer down.OmCheeto said:I will have to think about this some more.
Perhaps someone should start a survey: Where is the image of the rainbow?
To make it simpler, perhaps we should reduce it to one raindrop, as natural rainbows are a mess of parallax, angles, a 3D refraction screen, and a non-point source of light.
I was thinking about someone's comment; "No two people see the same rainbow". This got me thinking, and I came up with the question; "At what distance, do each of our eyes not see different rainbows"? Perhaps we should shut one eye when talking about rainbows. That would cut the confusion in half, at least for me.
From anorlunda's image, It is my vote, that the "rainbow image" should be located at the surface of the south pole of the raindrop, where the light finally exits.
I'm fairly certain that the water hose "water shape & flow selection device" was set on "mist", so the globs of water would have been nearly spherical.
Likewise with my "Hippies & Rainbows" image. Everyone was standing under a "mister", as it was somewhat hot that day.
The picture of my 90° intersecting rainbows was caused by a reflecting source.
The second bow being created by the sun reflecting off of the convex back window on one of my cars.
So according to anorlunda; "I think you mean "reflection" rainbow, not "reflected""
It is an example of a natural, and a reflection rainbow, captured in a single image.
Yes, it is interesting; more so because the form of the rainbow is exactly the same for everyone. This contrasts with the different view that two people have of most other things they may both be observing. We say that we all see the same Moon but the views from different parts of the Earth is measurably different. This conversation says more about People than about the Physics of the situation.Buckleymanor said:The comment about no two people see the same rainbow is interesting
But this is precisely what you expect for an object at infinity! So why have you (seemingly) been arguing that the rainbow (as a virtual object) is not at infinity?sophiecentaur said:Yes, it is interesting; more so because the form of the rainbow is exactly the same for everyone.
This has to do with the aperture, not the location of the virtual object. Just like seeing the rainbow is dependent on the aperture in the form of the raindrops. The rainbow itself as a virtual object is not at the raindrops, but at infinity. There is a family of rays which are parallel, corresponding to an image at infinity, whether you see it or not depends on the aperture.sophiecentaur said:I can put the image of a microscope sample at infinity. Can anyone else see that?
I am only trying to understand how you can have the view that the rainbow as a virtual image is at the raindrops at the same time as you consider it to not change depending on the observer - a typical property of an image at infinity.sophiecentaur said:I really don't know where you are going with this.
I don't have that view. Where did I say that? Was it because of my comments about seeing a rainbow 'in front of' a field of grass? I would argue that I do and I assume most people do, also (due to the stories of pots of gold etc.) Where we place an image (mentally) need have nothing to do with the optics of the situation because our brains don't just use optics when we build up a scene in our minds. We 'see' a rainbow in a field because out brain tells us that we could not actually be seeing 'through' solid Earth and grass. We perceive the rainbow moving across the field as we walk. Interestingly, it is quite the opposite when we see an image in a mirror because we are quite prepared to believe there's a whole roomfull of stuff in that solid brick wall.Orodruin said:how you can have the view that the rainbow as a virtual image is at the raindrops
Perhaps, I just got that impression over the course of the thread.sophiecentaur said:I don't have that view. Where did I say that? Was it because of my comments about seeing a rainbow 'in front of' a field of grass?
Of course we cannot be objective, our brain plays tricks on us all the time, which is why I have always focused on the physics aspect. If you have been talking about the perception all the time this would explain why we talk around each other.sophiecentaur said:I think we would not be having any of this discussion is we could be totally objective about what enters out eyes. If you want to discus just the Physics of the Rainbow then that's ok but the thread would need to have been terminated way back.
Yes. You are right. The reason for my treating that rainbow as 'something different' is that it's treated by many (most) people as such. It's in the same neck of the woods as Colour. So many people treat that as a matter of Physics when it's psychology and perception.Orodruin said:If you have been talking about the perception all the time this would explain why we talk around each other.
Running a true rainbow effect in POV-ray would be quite a challenge (POV-ray has an rainbow object, but is just a simulation). It has its limitations. While it can deal with refraction and reflection, in order to get effects like light bouncing off a reflective object illuminating another surface or for light passing through a refractive material to produce accurate caustics, you need to use a feature called "photons", which adds a great deal to the processing time. As a result, I had to limit myself to working with single objects, and even then I had to keep the dispersion samples (which determines how many colors the prismatic effect produces) down to a fairly low number which means the rainbow effects aren't all that smooth.OmCheeto said:That's how I make them.Buckleymanor said:You don't have to arrange the rain to come at the right time of the day and month you could make a spray with some with water and a hose.
Ha ha! The semantics of science. The two "nots" cancel and your phrase becomes; "I am sure if they are 3D objects".Buckleymanor said:I am not sure if they are not 3D objects.
Which, if you throw out the "if", looks suspiciously like "I am sure they are 3D objects".
I suspect they are 3D objects.
Where the hell is @Janus when you need a ray-trace guru??!?
Now that sounds like a grand experiment!If you stood in the same position and took a series of photos of the rainbow would the rainbow appear as a sphere when the photos were combined together.Provided there was enough time to do it.
ps. Rainbows are complicated. I like that about them.![]()
Does the focus of the camera affect how sharp natural rainbows appear in the picture?spareine said:If the Sun was replaced by a point-like light source with a line spectrum the rainbow would become a focusable object. Photos of that rainbow would be blurred unless the camera was focused at infinity.
As long as they are inspirational, they are illuminating.Janus said:...I don't know how illuminating they are towards the discussion, but they interesting to look at.
One thing I should mention is that these are not perfectly accurate physical representations. One limitation is that once the white light is broken up into its spectra, the refractive index for each color does not vary. In reality, each color would refract slightly differently. For instance, in the POV-ray model after passing light through a prism, passing it through a second prism will not reassemble the spectrum back into white light.
This has been worrying me. The raindrops can be, indivudually, very small (<1mm) and diffraction could be relevant but I can't be sure of the appropriate calculation, bearing in mind the enormous range of distances involved - between a couple of metres and a km. The diffraction limit for a 1mm aperture at 600nm is about 6 e-6 (in radians). How this could relate to the effect on focussing the line (arc), I can't be sure. Also, as Walther Lewis says in his lecture 'Rainbows and Blue Skies' in the above post that there is a 'narrow peak' in the range of angles which are wavelength selective. He makes the point that the region where the bow occurs is the only place where the wavelengths are individually selected. The sharpness of an arc will depend on how narrow this peak happens to be.A.T. said:Does the focus of the camera affect how sharp natural rainbows appear in the picture?
I refuse to be drawn in on this one!anorlunda said:Most people would say that it is four rainbows, but since there is only one virtual image at infinity, others would argue that it is only one.
I do not think anyone would argue that. The one image at infinity is predicated on there being one point source of light at infinity, which is not always the case. Optical effects may lead to several images (as in the later photos) being reflected by the raindrops.anorlunda said:Most people would say that it is four rainbows, but since there is only one virtual image at infinity, others would argue that it is only one.
Does it mean I'm obsessed with rainbows, if I admit that I recognize this one?anorlunda said:![]()
This picture is reported to have gone viral today, from Glen Cove, NY.
Keith_McClary said:
It's refreshing to read of someone who finds the topic so straightforward. I hope your confidence is well founded.chemaster said:I wonder how a physicist can struggle so much with such an incredibly simple phenomenon as rainbows.
APOD said:Explanation: Why would the sky look like a giant fan? Airglow. The featured intermittent green glow appeared to rise from a lake through the arch of our Milky Way Galaxy, as captured last summer next to Bryce Canyon in Utah, USA. The unusual pattern was created by atmospheric gravity waves, ripples of alternating air pressure that can grow with height as the air thins, in this case about 90 kilometers up. Unlike auroras powered by collisions with energetic charged particles and seen at high latitudes, airglow is due to chemiluminescence, the production of light in a chemical reaction. More typically seen near the horizon, airglow keeps the night sky from ever being completely dark.
I was confused when I first read the term in a non-GR context. All it means is a surface wave on a fluid (often water) where the restoring force ( to make the water level) is gravity - just plain old waves. They can happen at the interface between any two fluids, aamof. I think it's what you can see when you look from a mountain top at a layer of cloud, below you (when there's no detectable wind) and the cloud layer seems to form slow motion waves which appear to 'crash' on the mountain slope. Good excuse to stop climbing and just enjoy it.anorlunda said:but on PF gravity waves usually mean something else.
