Iodine Clock Kinetics: Which Mechanism is Supported?
The iodine clock kinetics experiment determined the rate law to be R = [I-]1[S2O82-]1, supporting Mechanism 2: I-(aq) + S2O82-(aq) ---> [S2O82-·I]3-(aq) (slow) followed by [S2O82-·I]3-(aq) + I-(aq) ---> I2(aq) + 2 SO42-(aq) (fast). Mechanism 1, Mechanism 3, and Mechanism 4 were ruled out based on their derived rate laws. The discussion emphasizes the importance of evaluating mechanisms based on experimental variables rather than intermediates.
  • Understanding of chemical kinetics and rate laws
  • Familiarity with reaction mechanisms in aqueous solutions
  • Knowledge of the iodine clock reaction
  • Ability to analyze and derive rate expressions from experimental data
  • Study the derivation of rate laws in chemical kinetics
  • Explore the iodine clock reaction in detail, including its applications
  • Learn about reaction intermediates and their role in kinetics
  • Investigate the differences between elementary and complex reaction mechanisms
Chemistry students, educators, and researchers interested in reaction kinetics, particularly those studying the iodine clock reaction and its mechanisms.
cvc121
1. Homework Statement
An iodine clock kinetics experiment was performed by varying the composition of reactant solutions and measuring resulting rates of reaction (based on the data given, I have determined the rate law to be R = [I-]1[S2O82-]1). Which of these four proposed mechanisms below would be supported by these results?
Mechanism 1: I-(aq) + I-(aq) ---> I22-(aq) (slow)
I22-(aq) + S2O82-(aq) ---> I2(aq) + SO42-(aq) (fast)
Mechanism 3: I-(aq) + S2O82-(aq) <---> [S2O82-·I]3-(aq) (fast)
Mechanism 4: 2I-(aq) + S2O82-(aq) ---> I2(aq) + 2SO42-(aq)
2. Homework Equations
Rate law: R = k[A]xy
3. The Attempt at a Solution
Mechanism 1: R = [I-]2. Therefore, this is incorrect.
Mechanism 2: R = [I-][S2O82-] Therefore, this is correct.
Mechanism 3: R = [[S2O82-·I]3-][I-]. Therefore, this is incorrect.
Mechanism 4: R = [I-]2[S2O82-]. Therefore, this is incorrect.
Answer: Mechanism 2
Can anyone confirm if I am on the right track? Thanks. All help is very much appreciated.
Pardon me for the incorrect rate law equation that I listed.
Yes I'd say you are on the right track. I agree mechanism (2) is consistent with the kinetics.
However have another look at mechanism 3, which after all is only quantitavely different from 2. You have to work out the rate expression as a function of your experimental variables (which your other three are) not of intermediates. You may find the answer is more nuanced. :oldwink:
22K
10K
