Rate of flow from a bucket with a hole in it.
  • Thread starter Thread starter jprockbelly
    Flow Hole Rate
The discussion revolves around the rate of flow of water from a bucket with a hole at its base. The original poster presents a scenario where the bucket is filled to a height h above the hole and seeks to understand the factors influencing the flow rate.
  • The original poster attempts to apply equations related to velocity head and flow rate but questions the relevance of pressure differences. Some participants discuss the role of atmospheric pressure and the pressure exerted by the water column above the hole.
Participants are exploring different interpretations of pressure's role in the flow rate. While some assert that atmospheric pressure cancels out, others emphasize the importance of the pressure from the water column above the hole. The conversation reflects a mix of agreement and confusion regarding the underlying principles.
There is a noted confusion regarding the importance of pressure differences, particularly between the water at the base of the bucket and the atmosphere, as well as the pressure at the hole itself.
jprockbelly
Consider a bucket with a hole, area A, near the base. If the bucket is filled with water to a height h above the hole at what rate will water flow out of the hole?
I would guess that the relative equations are the velocity head, v2 = 2*h*g, and the rate of flow, Q = A*v. However I am not sure that this is the correct way to go, as I would have thought that the pressure difference between the water at the base of the bucket and the atmosphere would be important.
If I am correct this can then be solved as:
Q=A*(2*h*g)^0.5, as a volume per second
Can anyone tell me if there is another way to do this?
{sorry, just realized this should have been postd in the physics, not maths forum}
This is correct.
Although the air pressure is pushing down on the water at the top of the bucket, it is also pushing on the water coming out the hole in bottom. Sort of like it is trying to push the water back up into the bucket. The effect is that these two pressures from the atmosphere cancel out.
No, the "pressure difference between the water at the base of the bucket and the atmosphere" is NOT important. What is important is the pressure at the hole. The water in the bucket under the hole is irrelevant. Also the atmospheric pressure is not important because it is essentially the same at the top of the water and at the hole. On the pressure caused by the weight of the water above the hole is important. If the top of the water is h above the hole, then you have a column of water of volume hA above the hole. Its weight is [itex]g\mu hA[/itex] where [itex]\mu[/itex] is the density of water which, in g/cm3, you can take to be 1. The force at the hole is ghA so the pressure is gh.
Thanks to both of you for your replies.
HallsofIvy, I am somewhat confused by your reply. Are you saying that the pressure IS important, or are you simply elucidating for my benefit?
  • · Replies 20 ·
  • · Replies 17 ·
