Ratio of Kinetic to Potential Energy of Simple Harmonic Oscillator
The ratio of kinetic energy (KE) to potential energy (PE) for a simple harmonic oscillator (SHO) when its displacement is half the amplitude is calculated using the equations KE = 1/2mv² and U = 1/2kx². At half the amplitude, the potential energy is U = 1/8kA², while the total energy E remains constant at E = 1/2kA². The correct ratio of KE to PE at this point is 3:1, confirming that the kinetic energy is three times the potential energy when the displacement is half the amplitude.
  • Understanding of simple harmonic motion (SHO)
  • Familiarity with kinetic and potential energy equations
  • Knowledge of conservation of energy principles
  • Basic algebra for manipulating equations
  • Study the derivation of energy equations for simple harmonic oscillators
  • Learn about the effects of damping on simple harmonic motion
  • Explore the relationship between amplitude and velocity in SHO
  • Investigate the implications of energy conservation in oscillatory systems
Students studying physics, particularly those focusing on mechanics and oscillatory motion, as well as educators teaching concepts related to energy in simple harmonic oscillators.
darkblue
Calculate the ratio of the kinetic energy to the potential energy of a simple harmonic oscillator when its displacement is half its amplitude.
KE=1/2mv2 = 1/2kA2sin2(wt)
U=1/2kx2 = 1/2kA2cos2(wt)
KEmax=1/2kA2
Umax=1/2KA2
What I'm thinking is that when the displacement is half the amplitude, the simple harmonic oscillator is halfway to the equilibrium point. When the displacement is half of the amplitude, is the potential energy half of its maximum value? At this point, wouldn't the kinetic energy be half of its maximum value as well? I assumed this is true and attempted to answer the question, which yielded an answer of 1, which is incorrect. Is there something wrong with my logic?
Yes, since the potential energy term goes as the square of the displacement, and not linearly with displacement, half the amplitude does not correspond to half the maximum potential energy.
Just plug x=1/2A into your equation for U=1/2kx^2 and then use conservation of energy to find the kinetic energy at that point.
Oh, I see what you're saying...but I'm a little lost at the conservation of energy part. I don't understand how to use that here. I know the potential energy is equal to 1/2k(A/2)^2 but isn't the kinetic energy just equal to 1/2mv^2? I understand that kinetic energy is related to the amplitude of the motion because velocity is related to amplitude...but I'm still not able to see how they are connected.
The total energy of the system E=T+U where T is kinetic, and U is potential energy. If you have U and E you can find T. In a SHO E is a constant and does not change. You just found U. Do you know what E is?
I took a closer look at my notes. Is the total energy equal to the square of the amplitude?
Oh woops, I don't think that makes sense.
Ok, at maximum amplitude, v=0, correct? That means at maximum amplitude, T=0. Now if E=T+U (at ALL times), and if T=0 then E=?
Yup, that makes sense...so E = U = 1/2kA^2, so at this point U is at its maximum value. As you said, for a simple harmonic oscillator, E is a constant...so this would mean that E is always equal to 1/2kA^2, right?
E=1/2kA^2
U=1/8kA^2
T=?
Is the above correct? Now I'm starting to understand what you're saying. We did some problems like this in class...if you don't know E, you can always choose the point where either T or U is equal to 0 to figure it out...right? I mean, you'd only have to do that if you didn't know one or the either, like in this question.
Yes, you are on the right track. Now just figure out T from the above, and take a ratio.
The important thing to note here is that in a SHO, there is no damping. As such there is no dissipation of the energy, so E remains constant.
I got T=3, which is the correct answer. Thanks so much for all your help! :)
  • · Replies 18 ·
13K
