RC circuit and discharging a capacitor
22 replies · 6K views
-EquinoX-
RC circuits and discharging a capacitor
ok, say I have the following:
R = 4700 ohm
C = 39 micro farads
they are arranged in series and the battery is replaced using a function generator, which we set to produce a square wave (on/off). With any frequencies set.
How can I graph the Vcap vs time?
I know the equation V(t) = Vo * e^(-t/RC) can be used.. however in this case what is Vo (initial voltage) here?
if this is so then what is the purpose of the square wave function generator? Doesn't it matter on how big the frequencies are set?
Are the R and C in series or parallel? :smile:
oops forgot to mention that, it's in series
If you are familiar with Laplace transformation, this problem can simply be solved by making a laplace transformation of the circuit and calculating the necessary value.
no.. I am not familiar with Laplace transformation
When you swith on the function generator, a peak voltage will be across RC circuit. During horizontal protion of the square wave, capacity will start charging. During vertically down ward portion and next horizontal portion of the square wave the capacity will discahrge.
so I want to get this numerically... is there a way to compute it
If you know the peak voltage and the period of the square wave, it is possible to find V(t).
well the period of the square wave I know, but how do I get the peak voltage?
I am just using a normal function generator.. so maybe the peak voltage is known...
You can select the peak voltage of the function generator, say 20 V peak-to-peak and period 500 ms. (greater then time constant RC). Find the voltage at every 50 ms. Plot the graph V(t) vs time.
I don't want to do this experimentally.. I want to do this on paper actually... so if the peak voltage is 20V and period was 500 ms what is the Vo
To draw graph use V(t) = 20*e^-t/RC formula.
Put the values of t as 50ms. 100ms, ,,and so on. Substitute the values of RC. Find the values of V(t)
ok.. gotcha.. is there actually a setting in the function generator to set the peak voltage... or is that hard coded in every function generator
Yes. It is there. It can be varied, say from 0 to 30V.
What does the amplitude take account for?
Which amplitude? Amplitude of square wave it self is the Vo.
What would be a good frequency to set on the function generator if the amplitude was around 2-5V and the RC is as I specified in my first post... I need some range of the frequency
In the given circuit the time constant RC = 0.183 S. So to draw the graph, if possible set the function generator to 2 Hz.
what is S there? 2 Hz.. isn't that really2 small? What should I set the time/div to be
Set to 500 ms.
RC is the time constant and it is measured in seconds.
