RC Helicopter in a Train (Forces)
The discussion centers on the behavior of an RC helicopter hovering inside a boxcar of a train as the train accelerates. When the train begins to move, the helicopter will initially remain in its position relative to the air but will experience backward motion due to the drag of the accelerating air. To maintain its hover, the helicopter pilot must pitch forward to increase lift, compensating for the induced downwash and the relative motion of the air. Ultimately, the helicopter's ability to maintain altitude and position depends on the pilot's control inputs and the dynamics of airflow within the train car.
  • Understanding of Newton's laws of motion
  • Basic principles of aerodynamics, specifically lift and drag
  • Knowledge of helicopter flight dynamics and control inputs
  • Familiarity with the concept of induced downwash in hovering flight
  • Research the effects of drag on hovering aircraft in moving environments
  • Study helicopter flight dynamics, focusing on control inputs for maintaining altitude
  • Learn about airflow patterns in confined spaces, such as train boxcars
  • Explore the relationship between acceleration and forces acting on free bodies in motion
Aerospace engineers, physics students, RC helicopter enthusiasts, and anyone interested in the dynamics of flight in non-static environments.
BrendanKerrisk
I was talking to my Physics teacher about this at lunch.
If I was to have an rc Helicopter which i had hovering perfecting (if only i had the skill) on a train at rest. What would happen in terms of the position of the helicopter as the train accelerated? Would is stay at the same point in reference to the train (e.g above my table) or would it stay is the same point in the air and the train would move without it? My teacher and i thought that at first the helicopter would go backwards but then just stay hovering slightly behind where it was when at rest. Any insights or thoughts please.
Assuming the helicopter is inside a box car of the train, if the train accelerates forwards, then the helicopter would only accelerate forwards at a small fraction of the train's acceleration, due to the drag of the forward accelerating air on the helicopter, and the back wall of the box car would collide into the helicopter.
...unless in your attempt to maintain the hover you pitch forward and increase lift.
Is it any different than a passenger in the train? Don't you feel your body press into the seat as the train accelerates? Every free body in the train need a force to accelerate it to match the train's speed.
Even the air in the car must experience higher pressure at the back of the car as the train accelerates.
This could happen without control input, when the helicopter starts moving back through the air.
Yes, but both in proportion to the slide and neither enough to maintain position and altitude without control input.
As russ_watters, the pilot could compensate with forward pitch. If the air ends up circulating so that it's moving horizontally backwards as it passes by the helicopter, then the lift (collective / power) input would be decreased. In a hover, a helicopter ends up operating in it's own induced downwash, requiring more power than in forward flight, where the helicopter advances into "fresh" air, from the air's frame of reference. From the helicopters frame of reference, if the air is moving "backwards", then it takes less collective / power to maintain altitude.
There's a limit to this. As forward speed (relative to air) increases, eventually the power / collective will have to be increased, including beyond that needed for a hover.
  • · Replies 18 ·
  • · Replies 38 ·
  • · Replies 52 ·
  • · Replies 87 ·
12K
