RE:Newton's Laws of Motion Block Problem
rajumahtora
In the arrangement shown, all surfaces are frictionless, mass of block M = 30 kg and m = 20 kg.
If F = 180 N , Find accelerations of both the blocks
Hand-drawn diagram of a large block labelled M on a horizontal surface, with a smaller block labelled m on top, connected by a string over a pulley at the right edge to a horizontal segment with tension T and an applied force F pointing right.
2. Doubt
How much force will be applied on the larger block M by the pulley(coz of tension)?
1. T towards right
2. T towards up
3. T√2 45° to the right
4. Any other answer3.Reason for doubt
If the total for exerted on the T i(cap) + T j(cap) i.e. Fnet on Bock M due to tension of string on pulley is T√2,
then there will be a force which will tend to pull block M upward...and if the accln of string is much higher, then the tension in the string will cause the block to accelerate up.
[To Jilang and tiny-tim,
After reading ur answer, i had this doubt too...so i asked again]
If anything else, please answer...
Thanks
  • Hand-drawn diagram of a large block labelled M on a horizontal surface, with a smaller block labelled m on top, connected by a string over a pulley at the right edge, with the string running down to a second pulley where a horizontal force F acts to the right, and tension T labelled on both string segments.
