RE: vehicle weight, HP, and gearing comparison between vehicles
The discussion revolves around a project to create a V12 engine using two Kawasaki Voyager motorcycle engines for a VW-based kit car, targeting Lamborghini-like acceleration. The project has calculated 250 horsepower and 220 lb-ft of torque for a car weighing 1,800 pounds. The creator seeks to compare weight, power, and gearing to optimize performance, looking for calculations and formulas to assist in this process. An acceleration simulator was recommended to evaluate performance based on power-to-weight ratios and gearing. The project is still in progress, with challenges related to engine component alignment noted.
ydeardorff
Hello all.
I am now enrolled at VRI at WWU!
I am working on a sort of independent study project. I am making a V12 out of a pair of motorcycle engines to go into a VW based kit car.
I have run the IHP formula and come out with 250hp, and 220 lb/ft of torque.
The car weighs 1800 pounds.
Ok now, onto the next. I am targeting as close to Lamborghini acceleration as I can.
What I am looking for is a way to compare the weight, power, and gearing (including final drive ratio) of one vehicle to set the gearing of the other.
I know adjustments will have to be made for the torque/hp curve peaks. but trying to get a good close ball park and start from there.
The transmission will be modular and a sequentially shifted unit.
Any one point me to the proper calculations, or formulas?
Thanks in advance!
Yaughn
This acceleration simulator should help you evaluate the performance you can achieve with a given power/weight ratio, tire's friction coefficient and vehicle layout; no matter what type of engine or transmission. (the theory is at the bottom of the page)
Once you know the target vehicle' speed and the engine rpm for the desired power output, you just need to calculate the proper gear ratio to link the engine to the wheels (formula and link to nice calculator here).
Thanks! Ill look into them.
Im trying to iron out some details on the engine component alignments. There's always something to have to wriggle into place. A V12 has very little room to work with ironically.
I have something that can model this for you:
It took me about 2 years to write. Admittedly, I wasn't working on it flat out, but it's pretty involved.
What pair of motorcycle engines have you made a V12 out of?
kawasaki voyager. Its a work in process, not complete yet.
thanks for your replies. but after a recent thread, I'll stop asking questions here
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
Thread 'What's the most likely cause for this carbon seal crack?'
We have a molded carbon graphite seal that is used in an inline axial piston, variable displacement hydraulic pump. One of our customers reported that, when using the “A” parts in the past, they only needed to replace them due to normal wear. However, after switching to our parts, the replacement cycle seems to be much shorter due to “broken” or “cracked” failures. This issue was identified after hydraulic fluid leakage was observed. According to their records, the same problem has occurred...
