Reaction between aspirin and NaOH
  • Thread starter Thread starter tgt
9 replies · 27K views
tgt
Does this reaction occur?
Aspirin = C9H8O4 (numbers are meant to be subscripts)
Aspirin + NaOH => what?
Aspirin + NaOH => 9 carbon dioxide + 4 water molecules + 9 hydrogens (i.e H2)
No. You have to look at the structure of aspirin, using just overall formula will lead you nowhere.
The empirical formula for Aspirin is not exact enough; you want to know that Aspirin is acetyl salicylic acid. (or is it three separate words, "acetylsalicylic acid ?")
Read the wikipedia article, it clearly states what should happen when you put aspirin in NaOH solution.
Aspirin has got a carboxyl group -COOH and an ester group -CO-OCH3 (acetyl); the first function reacts as an acid and becomes -COO-, the second function overcomes saponification RCOOR' + OH– -> RCOO– + R'OH
Would the saponification reaction be a much slower reaction, possibly relying on more extreme conditions other than moderate concentrations at room temperature?
Aspirin in basic solution hydrolises quite fast. Fast enough that it will at least partially hydrolise during standard titration with base, giving unreproducible results.
That is the reason for you need to use an excess of sodium hydroxide (at high temperature to ensure that all the aspirin reacts) to titrate aspirine and then, in a second step, titrate the excess of sodium hydroxide. But you will have to consider that one mol of aspirin reacted with two moles of base in your calculation.
