Reaction Forces at A, B, & C in Beam ABC
  • Thread starter Thread starter giacomh
    Point Reaction
5 replies · 8K views
giacomh
http://imgur.com/AjUdF
Segments AB and BC of the beam ABC are pin connected a small distance to the right of joint B. Axial loads act at A and at the midspan of AB. A concentrated moment is applied at joint B.
Find the reaction at A, B, and C.
ƩF
ƩM= (Fi)(di)
I split the bar at joint B and drew two separate free-body diagrams. For the right side of the bar, I have Cy and Cx at C, Bx from the pin, and the moment about B (100 ft-lb).
I solved:
ƩMb=10Cy-100
Cy=10
From there I took the moment of the entire bar about point A, and found By=-20 lb, which I don't think is correct.
I think I'm mostly confused because there are no downward y forces in this problem, and I didn't think rollers could ever have a downward force.
Thanks!
giacomh said:
1. Homework Statement [/b]
ƩF
ƩM= (Fi)(di)
I solved:
ƩMb=10Cy-100
Cy=10
Thanks!
In this problem, the roller supports are free to slide in the x direction, and thus cannot support any load in that direction, but they are quite capable of supporting vertical forces in the y direction. The applied moment is applied at the support joint B, not at the pin to the right of B. When you look at a FBD of the right section from the pin to C, you have at most just x and y forces at the pin and at C, no applied moment . By using the equilibrium equations, you can find Cy and the vert pin force rather easily.
Then look at the left section from A to the pin. Use the equilibrium equations again on this section to solve for Ay , By, and the horiz force at the pin. Then back to the right section for Cx.
Sorry, but how would I find any forces on the right side? Wouldn't my equilibrium equations just be:
Fy= By+Cy=0
Mb=(10)(Cy)=0
Fy= By+Cy=0
Mb=(10)(Cy)=0
Yes, more or less, but remember you are not looking at the joint B at the support in this FBD, you are looking at the pin just to the right of B, call it B'. So your equations should be
Sum of forces in y direction = B'y + Cy = 0, and
Sum of moments about B' = 10Cy = 0.
from this last equation, Cy = ?
And then from the first, B'y = ?
You still have B'x and Cx forces to contend with.
So they're both just equal to zero?
