Reaction forces on simple 2 strut truss
James C
Calculate reaction forces R1x, R1y, R2x, R2y. Load of 100N. Node 1 and 2 are fixed. Distances listed on image.
Hand-drawn free-body diagram of a two-member truss with pin supports at two bottom nodes, a 100 N downward load at the top-right node, dimensions 100 mm, 60 mm and 80 mm, and handwritten force and moment equations.
[/B]
I have:
∑Fx = 0 = R1x + R2x
∑Fy = 100 = R1y + R2y
∑M2 = 0 = (-100 x 0.1) + R1 x 0.06 + R1y x 0.02
∑M1 = 0 = (-100 x 0.04) + (-R2x x 0.06) + (-R2y x 0.02)
Using this equations I have tried to solve using matrices but I get a number error in Excel. Could someone please help clarify if I've made a mistake or why this can't be solved?
Thank you
Perhaps too obvious to be the problem but I assume you mean...
∑M2 = 0 = (-100 x 0.1) + R1x x 0.06 + R1y x 0.02
{See image in OP.}
[/B]
I have:
∑Fx = 0 = R1x + R2x
Thank you
For static equilibrium, you can write one force equation and one moment equation. You should pick either support #1 or support #2 as the reference for you moment equation and solve for the remaining unknowns.
The OP said the connections at support Nos. 1 and 2 were "fixed", but your equations assume each is a pinned connection, which cannot develop a moment reaction.
Thank you for your response SteamKing. You are correct that the supports should be fixed instead of pinned. How could I go about solving the 4 variables in this instance? You're saying I can write one force and one moment but then I have 4 unknowns and 2 equations don't I?
Haha yes sorry it should be R1x
If the two supports are indeed fixed, then the struts are statically indeterminate, and the equilibrium equations alone are insufficient to determine the reactions. You have to develop additional equations based on the deflections of the members.
