Real Part of Gain of LRC Circuit
  • Thread starter Thread starter PatsyTy
    Circuit Gain Lrc
The discussion revolves around analyzing the gain of an LRC circuit at a specific frequency, focusing on the relationship between the output and input voltages. Participants are exploring the transfer function and its magnitude, as well as the implications of complex values in this context.
  • Participants discuss using a voltage divider approach to find the transfer function. There is an attempt to express the output-to-input voltage ratio in a form suitable for extracting the real part and magnitude. Questions arise regarding the need to take the real part for magnitude and the distinction between gain and transfer function.
Some participants have provided clarifications about the nature of the transfer function and its magnitude. There is ongoing exploration of how to manipulate the expressions to achieve the desired form for evaluation. Multiple interpretations of the problem setup are being considered.
Participants are working within the constraints of a homework assignment, which may limit the information available and the methods that can be used. There is a focus on ensuring the correct interpretation of the circuit elements and their relationships.
PatsyTy
Given the circuit below (image uploaded) driven at a frequency ##ω=2πƒ## show that
$$|\frac{v_{out}}{v_{in}}|=\frac{1}{\sqrt{1+(\frac{1}{ωτ_{l}}-ωτ_{c})^2}}$$
where ##τ_{c}=RC## and ##τ_{l}+L/R##
##Z_R=R##, ##Z_L=jωL## and ##Z_C=-j/ωC## where ##j=\sqrt-1##
I start with
$$\frac{v_{out}}{v_{in}}=\frac{Z_R}{Z_C Z_L / (Z_C+Z_L)+Z_R}=\frac{Z_R(Z_C+Z_L)}{Z_C Z_L+Z_R(Z_C+Z_L)}$$
where the impedance of the resistor, inductor and capacitor are ##Z_R##, ##Z_L## and ##Z_C## respectively. I sub in values for the impedances seeing as I don't think there is any more simplification I can do here
$$\frac{v_{out}}{v_{in}}=\frac{R(-j/ωC+jωL)}{-j/ωC jωL+R(-j/ωC+jωL)}$$
I know I have to get this into a form where I can take the real part of $$\frac{v_{out}}{v_{in}}$$, in other words I want this in the form
$$\frac{v_{in}}{v_{out}}=\frac{A+jB}{C+jD}$$
however I have no idea how to do this, I'm not sure if I have set up the problem wrong. I've tried multiplying through by ##\frac{j}{j}## and ##\frac{-j}{-j}## but it doesn't seem to get me anywhere. I feel I know how to solve most of this problem, I am just unsure how to rearrange this expression to get a usable result.
You've used a voltage divider approach, which is fine, but it looks like you're taking the output as being across the resistor rather than the LC section. Note that the reference node is at the bottom.
What you're looking for is the magnitude of the transfer function, ##|\frac{v_{out}}{v_{in}}|##. That's not the same thing as the real part of the transfer function.
I thought that ##\frac{v_{out}}{v_{in}} was a complex value function, do I not need to take the real part to get the magnitude? Also we were told we are looking for the gain of the function, is that different?
The transfer function is complex. The magnitude of a complex value is determined by both of the components: ##|a + jb| = \sqrt{a^2 + b^2}## .
The ratio of the output to the input is the gain function, also known as the transfer function. It's magnitude at a given frequency is called the gain at that frequency.
Ok, so I still need the function to be of the form ##a+jb## to be able to evaluate the magnitude? For the ##\frac{v_{out}}{v_{in}}## I should start by working with
$$\frac{v_{out}}{v_{in}}=\frac{\frac{Z_C Z_L}{Z_C+Z_L}}{\frac{Z_C Z_L}{Z_C+Z_L}+R}$$
I believe?
Sure. You may find it expedient to divide the through the top and bottom by ##\frac{Z_C Z_L}{Z_C+Z_L}## to begin with in order to concentrate all the required simplification in one place :wink:
Also, note that ##\left| \frac{a + jb}{c + jd} \right| = \frac{|a + jb|}{|c + jd|}## That may help.
Thanks, I'll do so!
Just one quick question, your last line I'm not sure if I'm missing something but it looks like you repeated the same thing on both sides of your equation.
Not quite. Note the extent of the "|" operators in each case. For the magnitude of a fraction you can take the magnitudes of the numerator and denominator separately.
Ah now I see, I need that eye for detail! Thanks again!
  • · Replies 21 ·
  • · Replies 20 ·
