Really complex function to integrate
The discussion centers on the challenge of performing symbolic integration for a complex function involving multiple terms and constants, specifically using the integral of the form ∫ 1.38346 P ~u ~e^{-25 y/8}~ (1-y/8)^3~ y^{1/7} dy. The user has attempted to use MathCAD and Maple without success and is seeking a software solution capable of handling this complexity. They emphasize the need for an analytical method rather than numerical approximation due to the nature of the functions involved, particularly the ideal gas law and density calculations.
  • Understanding of symbolic integration techniques
  • Familiarity with mathematical software such as MathCAD or Maple
  • Knowledge of the ideal gas law and its application in density calculations
  • Basic concepts of polynomial approximation methods
  • Research advanced features of Mathematica for symbolic integration
  • Explore numerical methods for polynomial approximation in mathematical software
  • Learn about the Gamma function and its applications in integration
  • Investigate alternative mathematical software options for complex integrations
Mathematicians, engineers, and researchers involved in complex function integration, particularly those working with symbolic mathematics and needing precise analytical solutions.
womfalcs3
Hello,
I have a really complex function to integrate (not homework), and I was wondering if there is any software application that can handle it.
I have tried MathCAD and Maple, but both can't perform it. I don't think I can do it by hand, with all the integration by parts and expansions I would have to go through.
I would also have to go at it term by term once expanded. (The numerator expands to 5 terms.)
Here is the integral:
u and delta are functions of x, and P, Ti, and Tinf are constants (I could take out those that can be taken out of the integrand, but it doesn't get me anywhere with the process.).
So I need a symbolic integration.
I've worked to simplify the integral to this... taking out constants, and using an very good approximation for the exponential function below. I've also changed the interval, so that the approximation is valid.
I don't think I can do it numerically, because I can't use quadruture symbolically. I would have to plug it many data values and then fit a curve to the plot. I won't do that.
Capital delta is "Ti-Tinf".
The numerator is one of 5 terms I have to integrate one by one as part of the expansion.
\int 1.38346 P ~u ~e^{-25 y/8}~ \left(1-\frac{y}{8}\right)^3~ \sqrt[7]{y}~ \text{dy} =
-\frac{0.00270207 P u \left(0.32 e^{3.125 y} (y-9.68055) y \left(y^2-15.3252 y+60.7908\right)+22.8611 (-y)^{6/7} \Gamma<br /> (0.142857,-3.125 y)\right)}{y^{6/7}}
on the other hand with a sum in the denominator not mathematica doesn't integrate it
Thanks Ice, but the symbol isn't an "8", but rather a small-case delta, which is a function of x. Also, the denominator is imperative, because I'm integrating the product of velocity and the ideal gas law set equal to density.
Density = P/(R*T)
So I need the denominator.
I'm thinking I have to approximate the expenonetial function using a polynomial for the small interval. Since I need an analytial method of solution.
I already have a linear function that can be within 20% error.
Is there a good polynomial expression (Where the power is 1 or larger for all powers in the function.) to approximate:
f(y)=(1-y1/7)2
