Really understanding how to apply calculus.
  • Context: Undergrad
  • Thread starter Thread starter IronPlate
    Apply Calculus
1 reply · 2K views
IronPlate
Aside from learning all the tools to solving differential equations and taking derivatives, I've been trying to practice actually applying this knowledge to the creation of my own equations to find out certain things. Where I'm uncertain is, have I achieved the actual expression?
Let's start with the simple, Newton's Second Law
Assume mass is constant with time.
(1) [itex]F=ma[/itex]
(2) [itex]F=m\frac{dv}{dt}[/itex] ; F(t,v)
(3) [itex]F=m\frac{d^{2}u}{dt^{2}}[/itex] ; F(t,u,[itex]\frac{du}{dt}[/itex])
Rate at which v changes with time (acceleration)
(4) [itex]\frac{dv}{dt}=\frac{F}{m}[/itex]
Rate at which F changes with time
(5) [itex]\frac{dF}{dt}=m\frac{d^{3}u}{dt^{3}}[/itex]
Rate at which u changes with time
(6) [itex]\frac{du}{dt}=\frac{1}{m}∫Fdt[/itex]
Assume m(t), no longer constant.
(7) Same as (4)
(8) [itex]\frac{dF}{dt}=m\frac{d^{3}u}{dt^{3}}+\frac{d^{2}u}{dt^{2}}\frac{dm}{dt}[/itex]
(9)Absolutely no clue, still working on it.
I'll leave it there.Is there anything wrong with my notation? Does each expression capture the descriptions?
(6) needs an additional integration constant, which corresponds to the initial velocity.
"u" for a position can be a bit confusing. In (6), I would use a different variable in the integral (like t'). Apart from that, it looks fine.
Hint for (9):
##\frac{du}{dt}=c+\int_0^{t} \frac{dv}{dt} dt'##
