Recharging on the Moon: How to Revive a Dead Battery with Only a Copper Wire
  • Thread starter Thread starter shounakbhatta
    Moon
The discussion centers on the feasibility of recharging a dead battery on the Moon using only a small copper wire. Participants debate the effectiveness of generating static electricity through methods such as rubbing the wire with wool, while also considering the influence of solar wind on the lunar surface. It is concluded that while a small copper wire may not effectively recharge a battery, utilizing the electrostatic charges created by solar wind could provide a minimal charge if connected correctly. The conversation emphasizes the challenges of voltage mismatches and conductivity issues inherent in this scenario.
  • Understanding of electrostatic charge generation
  • Basic knowledge of battery chemistry and charging principles
  • Familiarity with solar wind effects on lunar surfaces
  • Awareness of electrical conductivity concepts
  • Research methods for generating static electricity using materials like wool and copper
  • Study the effects of solar wind on lunar electrostatics
  • Learn about battery charging techniques and voltage management
  • Explore practical applications of electrostatic charging in remote environments
Scientists, engineers, and enthusiasts interested in lunar exploration, battery technology, and electrostatic phenomena will benefit from this discussion.
shounakbhatta
suppose that you went to moon.You have nothing else with you except a discharged battery.now if I have to recharge it how'd I do it? Only equipment permitted is a small copper wire.
Tanks
I don't think there's any way to generate electricity using a small copper wire.
A long copper wire maybe, but not a small/short one.
Tanks
What are your thoughts on how to do it?
Maybe rubbing the wire with wool or some clothes and generate static electricity? Though I doubt it will manage to recharge the battery.
Tell me about the effect of the solar wind on the lunar surface.
phinds said:
Do you really think that has any bearing on the OP's question?
The solar wind creates electrostatic charges on the moons surface. He's only given a short copper wire to charge the battery. That's clearly what his professor has in mind.
That method of charging a battery is at least as practical as being on the moon with a dead battery you're looking to charge.
If MacGyver tried it, the battery would be charged in less time than it takes to explain the process.
Perhaps Shounakbhatta will get back to us on what his prof was looking for.
Even if we ignore the scale of those charge distributions (you need a difference to do anything), neglect issues like the bad conductivity of the material, tiny energy density, mismatched voltages and so on: how do you determine which way you have to connect the battery to avoid discharging it 50% of the time?
I believe areas exposed to the solar wind get a + charge, so put the battery in a shaded/protected area with the copper wire attached to the + terminal and extend the wire to an area where dust is suspended because of the electrostatic charge. Then bear in mind that if I create a single ion in that battery, I can claim to have charged it - though not "fully" charged it. You can then radio the professor (using another battery inaccessibly tucked into your suit) and have him get you back to Earth.
  • · Replies 36 ·
  • · Replies 72 ·
20K
  • · Replies 16 ·
