Recommend a physics&calculus book
  • Thread starter Thread starter Hossam Halim
    Book
The discussion revolves around recommendations for physics and calculus textbooks suitable for a high school student interested in studying theoretical physics and mathematics. Participants explore various book options and the appropriateness of different resources, including MIT OpenCourseWare (OCW).
  • Homework-related
  • One participant seeks recommendations for calculus and physics books, specifically asking about the MIT OCW curriculum.
  • Some participants emphasize the importance of knowing the student's current level in math and physics before recommending books.
  • Thomas Calculus and Halliday and Resnick's Fundamentals of Physics are suggested as potential textbooks.
  • Spivak and Apostol's calculus texts are discussed, with some participants noting that they may not be suitable as first books for calculus.
  • One participant suggests Lang's "First Course in Calculus" for beginners, while others recommend Apostol for those with some calculus knowledge.
  • There is a discussion about the student's familiarity with calculus concepts, particularly integration, and how that affects book recommendations.
  • Some participants express caution regarding the use of MIT OCW as a primary resource, suggesting that it should be supplemented with actual textbooks for a solid foundation.
  • Concerns are raised about the potential confusion of studying multiple calculus courses from OCW that use different textbooks.
Participants generally agree that the student's current knowledge level is crucial for determining appropriate resources. However, there is disagreement on the suitability of MIT OCW as a primary resource and whether to follow multiple calculus courses recommended by OCW.
Participants note the variability in high school students' backgrounds in mathematics and physics, which affects the recommendations made. There is also mention of the non-standard approach of some textbooks, such as Apostol covering integration before differentiation.
Hossam Halim
Hi,
I am a high school student . I'd like to study theoretical physics and mathematics : pure and applied in the near future .
So, can you suggest me a book to study calculus and another for physics ??
And do you agree with me that it is a good idea to go along with the order and textbooks of MIT opencourseware ?
Thanks
It depends on what you already know: how much math/physics do you know so far? Which grade are you in?
Thomas Calculus & Fundamentals of physics Halliday and Resnick
NR
NR
What about Spivak or Apostol's calculus ?
Are you already comfortable to some of the ideas of calculus? How comfortable are you with proofs? Spivak is not meant as a first calc book, it's even more intro to analysis. Apostol seems a bit more doable, but I wouldn't recommend it as first book either.
If it is your first encounter to calculus, then I highly recommend Langs "First course in calculus".
If you already know the basic ideas of calculus, then go for Apostol.
If you already know calculus moderately well and if you know proofs, then go for Spivak.
I said : i am a high school student
That's very vague.
Some high school students barely know basic algebra, some already know linear algebra and Calc III. Same with physics.
I don't know anything about integration
I know functions, limits and some differentiation .
So, which stage i am on now ?
Then perhaps you can go for Apostol. The book is quite challenging though. He also covers integration before differentiation, which is nonstandard. But if you get through it, then you'll be an expert on calculus.
micromass said:
That's very vague.
I know basic algebra, functions,limits and some differentiation and don't know anything about integration.
In physics, i know some mechanics and waves
From experience, I'd say you can go to MIT's OCW, and start with calculus 1 and physics 1. The scholar courses do not require any textbooks, but you could consider some of the books already mentioned in this thread as a supplement (although I wouldn't bother about them at first, before completing the scholar courses on OCW).
You're a high school student, so I don't know if you have so much experience to begin with.
Also, I recommend against this. MITs OCW should absolutely be treated as secondary resources, not as primary resources. You absolutely need to focus on working through an actual calculus book. Any other way will likely give you bad foundations.
Ok, but there they recommend Simmons' then Apostol's then Spivak's !
So, would i study calculus from zero point three times !
*Sighs*... Thanks for reminding me of that fact...
Then I guess that you should follow micromass' advice.
There they give on single variable calculus two times :
1.single variable calculus (uses Simmons)
2.calculus with theory (uses Apostol)
So, should i consider the two courses or only one of them ?
  • · Replies 26 ·
  • · Replies 36 ·
  • · Replies 30 ·
