Rectangular Plate SHM Time Period
37 replies · 7K views · last reply
Tanya Sharma
A rectangular plate of sides ‘a’ and ‘b’ is suspended from a ceiling by two parallel strings of length L each. The separation between the strings is ‘d’. The plate is displaced slightly in its plane keeping the strings tight. Find the time period of SHM.
I have drawn two rough sketches depicting the orientation of the plate while in motion.Not sure which one correctly describes the situation .In the first picture the side ‘b’ always remain horizontal while in 2nd picture the side ‘b’ makes an angle θ with the horizontal.θ is the angle which strings make with the vertical.
I think the 1st picture is correct . In that case the plate is not rotating about the CM and the plate can be simply replaced by its CM .
The CM is at a distance L+a/2 from the ceiling .
The time period will be 2π√(L+a/2)/g But this is incorrect .
I would be grateful if somebody could help me with the problem.
  • Diagram of a rectangular plate hung from a horizontal ceiling line by two vertical parallel strings, each labelled L; the plate sides are labelled a (vertical) and b (horizontal).
  • Two side-by-side sketches of a rectangular plate hanging from a horizontal ceiling line by two parallel strings. Left: plate kept horizontal in red. Right: plate tilted in green, with a faint grey outline of the original position in both.
Good.
Does the CM move along the arc of a circle? If so, where is the center of that circle?
... well you cannot get the rest unless you get this right! How would you figure that out for yourself?
Ask yourself: do the strings change length during the motion?
Which diagram agrees with the answer above?
[edit] looks like I was beaten to the punch :)
TSny said:
Good.
Hello TSny !
Yes...the CM moves along the arc of a circle . The center of the circle is the mid point of the length between the top end points of the string.
The blue dot represents the center .
Isn't the CM at a distance L+a/2 from the center?
  • Diagram of a rectangular plate hung by two strings from a horizontal bar, with a blue dot marking the midpoint of the bar; the plate is outlined in red and a grey outline shows its shifted position.
Yes, the plate will not rotate as the lengths of the strings can not change can you prove it?
How did you get your result? What forces act on the plate when the strings make an angle with the vertical?
ehild
Tanya Sharma said:
Hello TSny !
No. The blue dot is not the center of the circle that the CM moves along. Keep thinking about this.
Please forgive me if my answer doesn't make sense . I am just guessing .
Is it the top end of the left string ?
Does the center changes alternately between the two top end points of the strings ?
ehild
Since the plate does not rotate about the CM ,then the mass of the plate can be considered to be at the CM .
I think of the system of string and plate as similar to a simple pendulum with a time period 2π√(L/g) .
I thought the CM was at a distance L+a/2 from the ceiling,so the time period was 2π√(L+(a/2)/g)
I feel I am making some fundamental mistakes.
The forces acting on the plate are the tensions from the strings and the weight .
"I think" does not mean anything in Physics. You have to prove your guess.
Prove that the plate can not rotate.
If so, show the equation for motion of the CM. What forces act on the plate if the strings make an angle with the vertical?
You can also use the analogy with a mathematical pendulum, but you need to show that the CM moves on a circle, and find the centre and radius of that circle.
ehild
If the centre of a "circle" changes, it is not a circle.
What are the coordinates of the CM with respect to the blue dot when the strings make an angle θ with the vertical?
ehild
The tensions in the two strings are providing equal and opposite torques about the CM and the line of action of weight passes through the CM .Since net torque is zero,plate does not rotate.
Let the tension in the left string be T1 and right string be T2 .Then T1=T2=T
In the radial direction , 2T = mgcosθ , where θ is the angle which the strings make with the vertical.
In the tangential direction net force = -mgsinθ
ehild
The coordinates of CM with respect to the blue dot (i.e origin) are [(L+a/2)sinθ , -(L+a/2)cosθ]
Is it correct ?
Are you sure? Why? Is not possible that the tensions are different in the strings?
What do you mean on radial and tangential direction? Would not it be easier to use horizontal and vertical directions?
Does the CM not move in the vertical direction?
Is it correct ?
No.
If the tensions are different wouldn't the plate rotate about the CM ?
Are the coordinates of CM [Lsinθ , -(Lcosθ+a/2)] ?
It would, but you can not be sure that the tensions are equal. As you can not be sure that the plate does not rotate. What is that you know for sure?
Much better :smile: It is true if the y-axis points upward. So is it a circle, the CM moves on?
ehild
I am sure only about one thing ; that I can not solve this problem :-p
Just kidding... that the strings are inextensible .
ehild
No,the CM doesn't move in a circle about the blue dot .
But the CM does move in a circle . Right ?
You can solve the problem.
Is it possible that the strings make different angles with the vertical if they are of the same length?
It is right. What are the centre and radius of the circle?
ehild
  • Diagram of a rectangular plate hung by two parallel strings of equal length L from a horizontal bar of length d, with the plate's top edge tilted; labels read d on the bar and d on the plate, and L on each string.
ehild
Is (0,-a/2 ) center of the circle (purple) i.e point at a vertical distance a/2 downwards to the blue dot ?
In that case the radius is L .
Does that make sense ?
  • Diagram of a rectangular plate hung from a horizontal line by two thin wires, with a blue dot on the line and a purple dot below it, and a vertical arrow labeled a/2 between them.
It does... :smile:
ehild
Thanks ehild...
The restoring force would be along the tangent to the arc i.e -mgsinθ.How would we come up with the restoring force by working with accelerations in horizontal and vertical directions ?
Again I am still not clear how did you and TSny straightaway knew that the CM moves in a circle .
I came up with the answer by a lot of incorrect guesses and manipulating the coordinates of the CM w.r.t the blue dot .
I incorrectly guessed that the blue dot was the center .From that coordinates of CM were found .Then I shifted the origin and tried to manipulate the coordinates so as to fit in the motion of CM along the arc .
But what if I didn't know that the CM moves along the arc .
What is the correct way to think about this problem ?
I did not know that the CM would move along a circle. But it came out ...
You can guess but before working with it, prove it is true.
I wrote up the relation between acceleration and forces for the horizontal and vertical components. Cancelled the tensions. Then I used the relation between angle and coordinates. Not a nice method, but I can not make too big mistakes.
ehild
Could you explain how the tensions in the two strings will be unequal,yet no torque about the CM.
It can happen if the strings are not parallel.
ehild
When the strings are not vertical, can you see that the moment arms (lever arms) about the CM for the two tensions are not equal?
Can you determine at what angle θ one of the strings must go slack if the oscillations are large enough?
Tanya Sharma said:
Thanks ehild...
Consider the quadrilateral whose corners are at the ends of the two strings. So, two sides are the strings, one side is the line segment connecting the upper ends of the string, and the 4th side is the line segment connecting the lower ends of the string. What kind of quadrilateral is this (assuming both strings are taut)? If the top of the quadrilateral remains horizontal, what can you say about the bottom of the quadrilateral?
If the plate doesn't rotate, then it must move in pure translation. Thus the trajectories of any two points of the plate are congruent.
But the strings remain parallel throughout the motion. Right ?
The green and blue lines are the moment arm .
How should I convince myself that they are unequal ?
  • Diagram of a rectangular plate hung by two parallel strings from a horizontal support, with a red outline showing the plate and a grey rectangle showing its tilted position; a blue dot marks the centre and a green and a blue line are drawn from it to the plate's corners.
The quadrilateral is a parallelogram . The bottom side will remain parallel to the top side.
Did you pick anyone point and analysed its trajectory and then deduced that the CM should also have that trajectory ?
If yes,even in that case ,how did you come up that the trajectory is an arc ?
Can you see that your blue line is longer than your green line?
It helps to draw the plate with a larger vertical dimension.
Yes.
The trajectory of the point of attachment of one of strings to the plate should be easy to see.
Excellent thinking :smile:
Is it right to say that as the plate moves towards right upwards ,the moment arm of tension in the left string decreases (tension T1 increases) and the moment arm of the tension in the right string increases (tension T2 decreases ) such that T1r1 = T2r2 ?
That's right. You can see the angle θ at which the moment arm on the left goes to zero. So, what happens to T2 at that angle?
