Reference frame symmetry in Special Relativity
35 replies · 7K views
x-vision said:
Given that there is no acceleration involved in this example, can we safely assume that the two reference frames are fully symmetrical?
Yes, we can. The usual Lorentz contraction scenarios are not symmetrically.
I extend your scenario by an additional object and call it "Earth". The Earth is 10 LJ away from the star.
In the reference frame of the star:
The rocket is 10 LJ away from the star, when the rocket passes the Earth.
In the reference frame of the rocket:
The star is 10 LJ away from the rocket, before the Earth passes the rocket.
x-vision,
While my prior spacetime diagram was correct in its depicted coordinates, it was technically incorrect from a standpoint of "proper convention" for spacetime diagrams. Proper convention, is to present the system which holds the velocity as positive (worldines slant from lower-left to upper-right) as unprimed, which is usually depicted as stationary (vertical). From the point of view (POV) of the other system, that system records a negative velocity (worldines slant from lower-right to upper-left). For that system, the "Inverse LTs" apply.
The LTs ...
t’ = γ(t-vx/c²)
x’ = γ(x-vt)
y’ = y
z’ = z
γ = 1/√(1-v²/c²)
Inverse LTs ...
t = γ(t’+vx’/c²)
x = γ(x’+vt’)
y = y’
z = z’
γ = 1/√(1-v²/c²)
My next figure will have the STAR frame depicted as stationary, unprimed, with black solid worldline and black dashed (horizontal) lines-of-simultaneity. The ROCKET frame will be depicted as moving, primed, and with blue worldine and blue dashed (slanted) lines-of-simultaneity.
The inverse LTs are derived from the usual standard LTs, by merely plugging in -v for v into the LTs. The only reason this is done, is because many trying to learn SR often confuse the systems. With the above convention, you no longer have to be concerned with the velocity's polarity when using the transforms, although you do need to remember which system to present as unprimed. The only exception is the light path, which is always at 45 degrees in either direction, and which also bisects the time and spatial axes of all depicted systems, moving or not.
If you have any questions regarding the spacetime figures, feel free to ask.GrayGhost
x-vision,
Wrt my prior post #28, your OP scenario's spacetime diagram redone with with proper convention ...
GrayGhost
x-vision,
BTW, for your scenario the LTs apply, but only after some modification. The LTs were derived for spacetime systems that have a common origin. IOW x,y,z,t = x',y',z',t' = 0,0,0,0. Their spatial origins momentarily coincide at one point in time, when both their clocks read zero. In your scenario, as you had defined it, this is not the case. Your 2 systems momentraily coincide when both clocks read 10ly/v = 11.11 y. As such, I had to modify the LTs for the 11.11 y time offset. Here are the equations I used ...
So, I used the modified LTs above.
Try plugging in star frame coordinates to determine corresponding rocket frame coordinates, as per my spacetime figure. Also, try plugging in rocket frame coordinates to determine corresponding star frame coordinates. Play with it a bit, and it gets pretty easy.
You might try your same scenario assuming they meet up when both their clocks read 0, versus 11.11. Then you just use the standard LTs and Inverse LTs, and no longer need the Modified LTs above. Feel free to ask questions, as I'd be happy to assist. Hope that helps.GrayGhost
Dale said:
GrayGhost said:
I get 6.268 y, not 6.96.
Wow, this forum is awesome! This kind of fact checking really improves the accuracy and credibility of the forum.
OK Dale. You're right, I shall try to do better in that respect. Here's what I had for that ...
Best Regards,
GrayGhost
I think you may have taken my praise of your fact checking as a sarcastic criticism. My praise was completely sincere, I genuinely appreciate being corrected when I am wrong. Of course, this most recent post is even better, as you said you would try to do!
