What Is the Angle of Reflection in a Plane Mirror?
The angle of reflection in a plane mirror is always equal to the angle of incidence, confirming that if the angle of incidence is 50 degrees, the angle of reflection will also be 50 degrees. For an angle of incidence of 20 degrees, the angle between the light ray and the mirror can be found by subtracting from 90 degrees, resulting in 70 degrees. The discussion clarifies that while the angle of reflection pertains to light rays, it is distinct from the angle the reflected ray makes with the mirror's surface. Understanding these definitions is crucial for accurately determining angles in reflection scenarios. The conversation emphasizes the importance of distinguishing between the angle of reflection and the angle relative to the mirror.
Coco Hwang
1) If the angle of incidence of a ray of light to mirror is 50 degrees, what is the angle of reflection from the mirror?
2) If the angle of incidence of a ray of light to a mirror is 20 degrees, what angle does the light ray make with the mirror when it reflects?
3) If a ray of light makes an angle of 58 degrees with a mirror, what is the angle between the incident ray and the reflected ray?
The attempt - I'm having a hard time understanding the concept of mirrors, does the angle of reflection always equal to the angle of incidence?
Thank you!
Yes.
haruspex said:
Yes.
thank you!
would this also apply for light rays?
Coco Hwang said:
thank you!
Also? What were we discussing if not light rays?
Sorry, I was not aware that angle of reflection and light rays were the same thing.. :sorry:
They're not the same thing. Light rays are reflected in mirrors. The angle of reflection is an attribute of that reflection.
Although "reflection" generally refers to light, we can use the term in other contexts, figuratively.
But in the context of the present question, we are definitely discussing reflection of light rays.
Oh I see, thank you for your detailed response! So in this situation, would the answers for both questions #1 and #2 be the same as their angle of incidence?
For #1, yes, but for #2 you need to think carefully about how the following are defined:
  • Angle of incidence
  • Angle of reflection
  • Angle between the light ray and the mirror
ok so for #2, would I subtract 20 degrees from 90 degrees? ( 70 degrees ) Or do I just multiply 20 two times ( 40 degrees )
One of those is correct. Which one and why?
Ummm, is it subtracting 20 from 90? Because the angle of incidence is 90 so I subtract the angle made from the reflection from it?
Yes, but why? How is the angle of reflection defined, geometrically? How is that different from the angle the reflection makes to the mirror?
  • · Replies 16 ·
