Regarding Real numbers as limits of Cauchy sequences
28 replies · 4K views
Terrell
Let ##x\in\Bbb{R}## such that ##x\neq 0##. Then ##x=LIM_{n\rightarrow\infty}a_n## for some Cauchy sequence ##(a_n)_{n=1}^{\infty}## which is bounded away from zero.
2. Relevant definitions and propositions:
3. The attempt at a proof:
Proof:(by construction)
Let ##x\in\Bbb{R}## such that ##x\neq 0##. Then by definition 5.3.1., ##x=LIM_{n\rightarrow\infty}a_n## such that ##(a_n)_{n=1}^{\infty}## is a Cauchy sequence; That is \begin{align}\forall\epsilon\in\Bbb{Q^+}\exists N\in \Bbb{Z^+}\forall j,k\geq N(\vert a_j-a_k\vert\leq\epsilon)\end{align}
and ##(a_n)_{n=1}^{\infty}## is also bounded. Suppose ##x=LIM_{n\rightarrow\infty}a_n## is not bounded away from zero. Thus, ##\exists j\in\Bbb{N}## such that ##a_j=0##.
Consider ##x'=LIM_{n\rightarrow\infty}a'_n## where ##\forall n\in\Bbb{N}(n\neq j\Leftrightarrow a_n=a'_n)##. Consequently due to definition 5.3.4. and Lemma 5.3.6.
\begin{align}x-x'=LIM_{n\rightarrow \infty}a_n - LIM_{n\rightarrow \infty}a'_n=LIM_{n\rightarrow \infty}(a_n-a'_n)\end{align}
Thus, ##\forall n\in\Bbb{N}(n\neq j\Leftrightarrow a_n-a'_n=0)##. Keep in mind that ##x,x'\in\Bbb{R}## and ##\forall\in\Bbb{N},a_n,a'_n\in\Bbb{Q^+}##. Since ##a'_j\neq a_j=0##, then by trichotomy of rationals ##a'_j>0## or ##a'_j<0##. Without loss of generality, suppose ##a'_j>0## then ##\vert a_j-a'_j\vert =\vert 0-a'_j\vert =\vert -a'_j\vert=-(-a'_j)=a'_j##. Hence, ##LIM_{n\rightarrow\infty}(a_n-a'_n)## where ##(a_n-a'_n)_{n=1}^{\infty}## represents the sequence \begin{align}a_1-a'_1=0,...,a_{j-1}-a'_{j-1}=0,a_j-a'_j=a'_j,a_{j+1}-a'_{j+1}=0,0,...\end{align}
Clearly, for all ##\epsilon'\in\Bbb{Q^+}## there exists ##\overline{n}\in\Bbb{Z^+}## such that ##\forall k\geq\overline{n},\vert a_k-a'_k\vert\leq\epsilon'##. Since ##x## is equivalent to ##x'## and the sequence ##(a'_n)_{n=1}^{\infty}## representing ##x'## is bounded away from zero, then ##(a'_n)_{n=1}^{\infty}## is a cauchy sequence representing ##x## that is bounded away from zero because by definition 5.3.1. equivalent cauchy sequences represent the same real number.
Terrell said:
Proof:(by contradiction)
You have tried to show that all sequences ##(a_n)## representing ##x## are bounded away from ##0##. This cannot be true. A simple counterexample is ##(a_n) = 0, 1, 1, 1 \dots##, which clearly is a sequence representing the number ##1##.
The question requires that you show that there exists a Cauchy sequence for ##x## bounded away from ##0##. Not that all such sequences are bounded away from ##0##.
Also, if ##(a_n)## is not bounded away from ##0## it doesn't mean that ##a_j = 0## for any ##j##. For example:
##a_n = 1/n##
To add to what @PeroK said, you can take any Cauchy sequence that represents ##x##. If it is bounded away from 0 you are done. If it is not, then you can construct a one that is based on it, which will be a proof of existence.
##a_n = 1/n##
Using these definitions
What if I end my argument with "since ##x## is equivalent to ##x'## and the sequence ##(a'_n)_{n=1}^{\infty}## representing ##x'## is bounded away from zero, then ##(a'_n)_{n=1}^{\infty}## is a cauchy sequence representing ##x## that is bounded away from zero because by definition 5.3.1. equivalent cauchy sequences represent the same real number."
I changed the last paragraph and added some new preliminary definitions. Thank you for the feedback!
##a_n = 1/n##
Yes, but if the series does not converge to zero, it does. However, that there exists a ##j## for which ##a_j = 0## does not mean that there does not exist other values of ##n## for which ##a_n = 0## as well. Thus, just removing the zero at ##j## does not guarantee that the new sequence will be bounded away from zero.
To OP: I think you are seriously overthinking this problem. Ask yourself the question if infinite sub-sequences of Cauchy series are also Cauchy series.
I would not know since I haven't reach that part of the textbook I'm using yet. I would like to follow the text axiomatically so I am avoiding using any theorems that are ahead of the chapter. But do you think my changes to my original proof verifies the proposition to be proven? Thank you! P.S. I am currently using Terrence Tao, Analysis I.
Your proof is not repairable and you need to rethink. Post #2 explains why. Note that you will need to use the definition of equivalent Caucky sequences at some point, as that is the key to the condition ##x \ne 0##.
You must have. It is an easy thing to show from the basic definition of a Cauchy sequence.
And, in fact, all you need here is that if you chop off the first part of a Cauchy sequence, you still have a Cauchy sequence. That, I would say, is obvious enough that it can be stated without proof.
I was trying to avoid spelling it out so bluntly ... :rolleyes:
I have shown this in an earlier exercise. How could this be used?
sorry I misunderstood because you wrote "series" instead of "sequence".
Ooops. I do that mistake from time to time. Of course, I intended to write Cauchy sequence, there are no series here.
The first thing you need is a strategy for this proof. What is your strategy here?
I don't understand why "since ##x## is equivalent to ##x'## and the sequence ##(a'_n)_{n=1}^{\infty}## representing ##x'## is bounded away from zero, then ##(a'_n)_{n=1}^{\infty}## is a cauchy sequence representing ##x## that is bounded away from zero because by definition 5.3.1. equivalent cauchy sequences represent the same real number." would not repair the proof :(
my strategy is to construct an equivalent sequence for ##x## which is constructed as the sequence of ##x'## as shown above. Then I will show that ##(a_n)_{n=1}^{\infty}## is equivalent to ##(a'_n)_{n=1}^{\infty}##. Then use definition 5.3.1.
Post #2 showed that simply removing any zero term from the sequence is not sufficient.
Your strategy was:
Take a Cauchy sequence representing ##x##. Assume it is not bounded away from 0. This implies it has a single zero term. Remove the single zero term from the sequence ...
That is ill-conceived as a sequence that is not bounded away from 0 might have an infinite number of 0 terms; or, it might have none!
But what I think I have shown is despite ##x## being represented as a sequence ##(a_n)_{n=1}^{\infty}## with a zero term, we can construct an equivalent sequence ##(a'_n)_{n=1}^{\infty}## without zeroes that represents ##x##.
what if I use the method of constructing ##x'## above then use induction to 'cover' all zeroes? If this still would not work, can I have any other ideas? Thank you!
There might be no zeroes in the sequence for ##x##.
Can I use cases with induction? Would that work?
I think you need to start again. In particular you need to think about:
##x \ne 0##, therefore, ##(a_n)## does not converge to zero. And what you can say about ##(a_n)## from this.
##x \ne 0##, therefore, ##(a_n)## does not converge to zero. And what you can say about ##(a_n)##.
It converges to a nonzero number...? And there is a lower bound to all terms in the sequence which could or not be the nonzero number it converges to.
Terrell said:
It converges to a nonzero number..?
You need to rethink the whole proof.
Also, this whole subject you are studying is a development of the real numbers as Cauchy sequences. Even my hint about not converging to 0 is a bit of a short-cut that doesn't really respect the formality of this mathematics. Technically, one Cauchy sequence does not converge to a number, it is that number.
The only numbers you have at this stage are the rationals. And ##(a_n)## does not necessarily converge to a non-zero rational. All you know is that it doesn't converge to 0.
You need to rethink the proof; otherwise, I'll just be taking you through what would be my proof step at a time.
What general strategy do you have in mind?
I would take a Cachy sequence representing ##x## and use the fact that it doesn't converge to 0 to produce an equivalent Cauchy sequence that is bounded away from zero.
You don't need a proof by contradiction.
Now, it's definitely up to you. I've given you more than enough!
This will do. Thank you again!
