Relating Electric Field and Voltage in an Insulating Sphere
The discussion focuses on deriving the electric potential V for a uniformly charged insulating sphere with radius R, given the electric field expressions E=kQ/r² for r>R and E=kQr/R³ for r PREREQUISITES
  • Understanding of electric fields and potentials in electrostatics
  • Familiarity with calculus, specifically integration techniques
  • Knowledge of the concept of conservative forces in physics
  • Basic understanding of the relationship between electric field and electric potential
  • Study the derivation of electric potential from electric field using integration
  • Explore the concept of conservative fields and their properties
  • Learn about the implications of electric potential continuity at boundaries
  • Investigate the applications of electric fields and potentials in real-world scenarios
Students of physics, particularly those studying electromagnetism, educators teaching electrostatics, and anyone seeking to deepen their understanding of electric fields and potentials in charged objects.
NeonJay
Positive electric charge Q is distributed uniformly throughout the volume of an insulating sphere with radius R. From the expression for E=kQ/r^2 for r>R and E=kQr/R^3 for r<R, find the expression for the electric potential V as a function of r both inside and outside the uniformly charged sphere. Assume that V = 0 at infinity.
k=1/(4*π*ε0)
\int_A^B\vec{E}\cdot\mathrm{d}\vec{r} = V(A) - V(B)
2.5. Apparent Answer
(kQ/2R)[3-(r^2)/(R^2)]
Apologies ... I'm not very knowledgeable in tex, but that last part would read r-squared over R-squared.
I have already obtained V = kQ/r for r>R. This was a simple antiderivative.
I'm getting really caught up on r<R. I've tried integrating from 0 to r, 0 to R, r to R, and backwards versions of the same. Nothing comes to the answer in 2.5 above. I'm really at a loss for how this integral should be done. I can understand most of it except for the 3 in the second expression; where the heck does it come from? I've seen this answer in a couple of different places, but none of them actually explain it.
Any help would be appreciated. Thanks ahead of time.
k=1/(4*π*ε0)
Hello NeonJay. Welcome to PF !
Extend this to r = R, to get V(R) = kQ/R.
Then use \displaystyle \int_A^B\vec{E}\cdot\mathrm{d}\vec{r} = V(A) - V(B) to get V(r) for r < R . To do this, A = R, B = r .
The potential is continuous function, and you know it at r=R. V(R)=kQ/R2 . Integrate from r to R:
V(r)-V(R)=\int_r^R{\frac{kQ}{R^3}rdr}
substitute kQ/R for V(R) and solve for V(r).
ehild
I think I get it. I was essentially neglecting part of my equation.
Thanks for the help! It really clears a lot of things up.
The equation comes from the definition of the electric potential: a function V(r) of position r so as the negative gradient of V is equal to the electric field intensity.
-V(r)=E.The electric field is conservative so the work done on unit charge between two points A and B does not depend on the path taken.
\int_A^B{-\nabla V d\vec r}=\int_A^B{\vec Ed\vec r}
V dr=dV, the increment of V.
\int_A^B{-dV}=V(A)-V(B)=\int_A^B{\vec Ed \vec r}ehild
  • · Replies 17 ·
  • · Replies 22 ·
