Relation between inverse trigonometric function
11 replies · 7K views
Jhenrique
Mathematics news on Phys.org
Jhenrique said:
This relationship is correct?
The second one is incorrect, and the other two are obvious.
And which is the correct form for the second?
Also, where can I find a full list (and correct)?
cosh(ix) = cos(x)
therefore:
arcosh(x) = i arccos(x)
It's in the link you provided in the first post. You transcribed it incorrectly, that is all.
All you need to prove the others is:
sinh(ix) = i sin(x) and
tanh(ix) = i tan(x)
Give it a go, if can't work it out - ask again.
So, following your ideia, I got:
asin(x) = -i asinh(+i x)
acos(x) = -i acosh( x)
atan(x) = -i atanh(+i x)
acot(x) = -i acoth(-i x)
asec(x) = -i asech( x)
acsc(x) = -i acsch(-i x)
asinh(x) = -i asin(+i x)
acosh(x) = -i acos( x)
atanh(x) = -i atan(+i x)
acoth(x) = -i acot(-i x)
asech(x) = -i asec( x)
acsch(x) = -i acsc(-i x)
Correct?
I started with
sin(z) = -i sinh(iz) (1)
and I applied the arcsin for get z
arcsin(sin(z)) = z
So I realized that z should appears in the right side of equation (1) and the way this happen is aplying -i arcsinh(ix) in the right side, so:
arcsin(sin(z)) = - i arcsinh(i · -i sinh(iz)) = - i arcsinh(sinh(iz)) = -i·iz = z
Check this one.
And that one is not correct with many definitions of inverse hyperbolic cosine and inverse cosine.
Jhenrique, you are ignoring the problems of branch cuts. You have not even defined your definitions of the analytic continuations of the inverse functions. There are many choices; infinitely many. What choices have you made?
1st I was trying undertand how create the relation between arc functions and arc functions hyp...
Check this one.
x = cos(z) = cosh(iz)
acosh(cosh(iz)) = -i acos(cos(z))
iz = -iz ...
hummm
the formula worked for x = cosh(z) = cosh(iz)
So, which are the correct relations?
iz = -iz ...
No, this is obviously wrong. If you end up with a mathematical absurdity like ##x = -x## for nonzero ##x##, you've made a mistake.
If you want to go from ##\cos z = \cosh iz## to a relationship between the inverse circular and hyperbolic functions, here's one way to proceed:
Put ##iz = \cosh^{-1} x##, where ##z = \frac{1}{i}\cosh^{-1} x = -i\cosh^{-1} x##.
Then the RHS becomes ##x##. The LHS is ##\cos(-i\cosh^{-1}x)##.
You now have ##\cos(-i\cosh^{-1}x) = x##. Take the inverse cosine on both sides and you end up with
##-i\cosh^{-1} x = \cos^{-1}(x)##
Multiply both sides by ##i## to get:
##\cosh^{-1} x = i\cos^{-1}(x)##
which is the exact relationship mentioned in the Italian Wiki page.
