Relationship betweem angle of a ramp and tension in rope
The discussion focuses on the relationship between the angle of a ramp and the tension in a rope attached to a cart. In a lab experiment, it was observed that as the angle of the ramp increased, the tension in the rope increased proportionally until reaching 45 degrees. Beyond this angle, the tension approached 9.8 N due to the gravitational force acting on the 0.5 kg cart. The tension is mathematically represented as the mass of the cart multiplied by the sine of the ramp angle, with significant deviations from the small-angle approximation occurring at angles greater than Pi/4 radians (45°).
  • Understanding of basic physics concepts, particularly forces and tension.
  • Familiarity with trigonometric functions, specifically sine.
  • Knowledge of the small-angle approximation in physics.
  • Ability to perform calculations using radians in a scientific calculator.
  • Explore the mathematical derivation of tension in inclined planes.
  • Learn about the small-angle approximation and its applications in physics.
  • Investigate the effects of varying mass on tension in similar setups.
  • Examine real-world applications of tension in ropes and angles in engineering contexts.
Students in physics courses, educators teaching mechanics, and anyone interested in understanding the principles of tension and forces on inclined planes.
kf00zy
In my physics class we did a lab where we attached one end of a string to a .5 kg cart and the other end to a force meter which was all on a ramp. As we increased the angle of the ramp, the tension increased proportionally until the angle reached 45 degrees. From 45 degrees to 90 degrees, as we increased the angle, the tension approached m9.8. I understand why it approaches m9.8, but why does that start at 45 degrees?
The tension on the rope is equal to the mass of the cart times the sine of the angle of the ramp. For small angles the angle, in radians, is approximately equal to the sine of the angle. As the angle becomes larger the difference becomes larger and it begins to become significant around Pi/4 which is 45°. Try it with a calculator and you'll see what I mean. Set it to radians and enter small values and calculate the sine and you'll see that for small radians angle=sine(angle).
http://en.wikipedia.org/wiki/Small-angle_approximation
