Relationship between differential pressure and airflow through a filter
2 replies · 5K views · last reply
ShanePC
I have a question regarding the relationship between differential pressure across a filter, the airflow through the filter and the size of the orifice that the aire is moving through. I would like to be able to predict differential pressure required to maintain a constant airflow as the filter I am using blocks over time.
I am having trouble finding a suitable expression online and Filter Manufacturers do not supply this information with their filters.
Can anybody tell me if there is a simple expression which can be used please?
Thanks in advance to anybody who can assist me!
Shane
Welcome to PF!
I'm sorry, but this can't work because you have one unknown driving the other: You would have to know the loading of the filter to find the pressure drop on a table or via a formula but the only way to measure filter loading is by measuring the pressure drop!
What you need is to maintain a constant dp across a device known to be fixed, such as a cooling or heating coil. Then the pressure across the filter can fluctuate while keeping the airflow constant.
Thanks for the welcome Russ. I am not an engineer so I am taking time to get through things that probably seem very basic.
In relation to the pressure drop and loading I am working through correlating the two through measurements.
I am using a vacuum pump to generate the flow through the filter but cannot control the pressure or loading across the filter. I know the pressure before and after the filter but not the airflow. Am I dealing with too many unknowns? Thanks for your help.
S.
