Relationship between speed and flow
The discussion revolves around the relationship between the speed of a person on a water slide and the flow of water, with a focus on how various factors such as slope, water depth, and air resistance may influence this speed. Participants explore theoretical and practical aspects of this relationship, including the application of physics principles and relevant equations.
  • Homework-related
  • One participant seeks formulas to relate the maximum speed of a person on a water slide to water flow and slope.
  • Another participant points out that individuals can travel faster than the water flow, suggesting that the scenario may need clarification.
  • There is a consideration of how water depth affects sliding speed, with some arguing that a thin film of water may not significantly impede speed.
  • Participants discuss the role of gravitational acceleration versus friction, with some suggesting that friction can be neglected in certain conditions.
  • One participant proposes that the maximum speed is more related to the slope than the water flow, while still acknowledging some relationship to water flow.
  • There is a discussion about the relevance of mass and area of the person sliding, with references to Galileo's experiment indicating that mass does not affect falling speed, but area may due to drag.
  • Concerns are raised about the accuracy of speed calculations and the importance of considering variations and factors that may limit accuracy.
  • One participant suggests focusing on air resistance effects rather than water friction for calculations.
  • Another participant recommends starting with gravitational acceleration to estimate maximum speed based on height and slope.
  • There is a suggestion to compare the calculated speed of the rider with the water's velocity to determine if water drag is significant enough to warrant further investigation.
Participants express differing views on the relative importance of water flow, slope, and air resistance in determining the speed of a person on a water slide. There is no consensus on a single formula or approach to establish the relationship, and multiple competing perspectives remain throughout the discussion.
Participants highlight limitations in their calculations, such as the need to consider variations, the accuracy of estimates, and the potential impact of factors not initially included in their models.
This discussion may be of interest to students and professionals involved in engineering, physics, and design of recreational water slides, as well as those exploring fluid dynamics and related calculations.
Uricucu
Hi! I'm currently doing a project to simulate a water slope, and want to find the maximum speed of a person going downhill in function of the water flow. At first I thought using a combination of the Manning equation and the Newton Law for viscosity, through the sheet of water, but I'm in a dead point...
Does anyone know any group of formulas to establish such relationship? Thanks!
Welcome to PF.
I'm not sure I understand your question. People on water slides can travel faster than the water flow. They even have slopes where the water moves up the slope (negative water speed), while the people on surfboards go down slope.
Can you explain better the scenario you are asking about?
anorlunda said:
Welcome to PF.
Thank you for responding. Actually I'm trying to calculate the speed of a person in a water slide, in particular the descending speed in a slope. I guess the person speed is related to the water flow and the degree of the slope, but I was asking for any formula that relate both.
Hope I could clarify things, if not, feel free to ask!
Wouldn't it depend on depth of the water also? I think of a slide with a wetted surface <1 mm thick. The film of water hardly moves at all but the person sliding can go very fast.
But if the water is deep enough, then the person is "surfing" with no contact between his body and the slide itself. Similarly, the person's body position would also be a factor.
I guess what I'm saying is that I doubt that there is one simple formula. But I have been wrong many times before, so perhaps other PF members can prove me wrong.
Yep, I thought about the Newton viscosity law, that links the velocity with the water thickness. But that thickness is the one beneath the person, so its like 0,01 mm (logically). My idea is to know the flow in order to not exceed the maximum velocity, which is 14 m/s.
It might, but I was thinking at least for a thin film moving with the person, the coefficient of friction is so low you can ignore it and just use gravitational acceleration.
That's what I was thinking. Then, to limit the top speed, you have to limit the height (or limit the height in anyone continuous downslope). For 14 m/sec I get 10 meters max change in elevation.
I never thought of it before, but I guess that's why the slides seen in waterparks always seem to have "flat spots" -- to limit the top speeds.
So the speed is more related to the slope than the water flow? But it's still related to water flow in some way, isn't it?
Hi again, thank you all of you for responding my post. I don't know if I get the main ideam but what you all seem to agree is that I should apply the basics of physics, meaning the formulas like: x=xo+vo*t+0.5*g*t^2 and v=vo+gt?
Then, the mass of people and their area aren't a variable that effect their velocity, are they? Moreover, do you think that the water speed has any effect at all in the user's speed?
Thanks.
Search for Galileo's experiment. He dropped a heavy ball and a light one at the same time. They landed at the same time. So no, mass does not change the speed of falling.
Area is different. A feather falls more slowly because of air drag.
"any effect at all" is not the right way to engineer this. Engineers deal with "any effect big enough to worry about?" and to that, the consensus is no. Water speed is probably not big enough to worry about, and air drag at speeds less than say 50 mph are also too small to worry about.
Also, a good engineer always remembers about variations, and factors not considered that limit the accuracy of calculations. You should aim for an estimate of speed to the nearest 10 mph, not 0.01 mph. Then add a range to that, such as 40 mph ##\pm{10} mph##.
So maybe I've been focusing in the relationship between the water flow and the water depth with the user's speed, while I should have been focusing in the air effects, since you adivsed me to neglect water friction effects in terms of calculations.
Guess I will try to limit the terminal velocity to the effect of the air drag.
To context you all, since I think I haven't been clear at all, my college project consists in designing a water slide, from the design itself to the steel structure. Now I'm focusing in calculating the user's speed in order to guarantee they don't exceed the maximum allowed, which is 14 m/s.
Thanks!
If you are going to start by ignoring the water effect then a very basic start would be to calculate the maximum speed based upon the acceleration of gravity for the planned height and slope of your slide and then compare that to your terminal velocity calculation. At the same time, since water inserted at the top of the slide will achieve the same velocity, except for the slide surface drag effects, you might use the standard equations for sloped channel flow to estimate the water's velocity to see if there is a significant enough differential to your first calculation to see if an investigation of the water drag on your rider would be worthwhile.
  • · Replies 21 ·
10K
  • · Replies 17 ·
  • · Replies 30 ·
