Relationship between Velocity, Kinetic Energy, and Heat
The discussion centers on the relationship between velocity, kinetic energy, and heat generation in objects moving through a medium, specifically the atmosphere. Participants clarify that heat generation occurs primarily due to friction forces when an object moves through air, as opposed to in a vacuum where no friction exists. The equation for kinetic energy, expressed as KE = 1/2mv², is acknowledged, but the simulation of kinetic energy without actual motion remains a point of contention. Ultimately, it is established that high velocity does not inherently cause temperature rise without external interactions.
  • Understanding of kinetic energy and its formula (KE = 1/2mv²)
  • Knowledge of thermodynamics, specifically heat generation through friction
  • Familiarity with closed systems in physics
  • Basic concepts of motion through different mediums (e.g., air vs. vacuum)
  • Research the principles of thermodynamics related to heat generation from friction
  • Explore simulations of kinetic energy in closed systems using software like MATLAB or Simulink
  • Study the effects of atmospheric drag on high-velocity objects
  • Investigate the relationship between pressure, temperature, and kinetic energy in gases
Physics students, engineers, and researchers interested in the dynamics of motion, heat generation, and simulations of kinetic energy in various environments.
Awilson012
Hi all,
I'm new here.
I am curious to know if I could simulate high velocity on an object by applying the forces (compression) to it that it would experience at those high velocities.
Also, I'm curious to know if this high velocity (Kinetic Energy) would generate heat, and if so, what's the equation?
Thanks a lot! Looking forward to a discussion on this topic!
Awilson012
Science news on Phys.org
I assume you are referring to a high speed object traveling through the atmosphere? Otherwise your question makes no sense, as an object traveling in a vacuum does not experience friction and will not increase in temperature just because it is moving.
Yes, the object would be moving through the atmosphere. Sorry for the lack of clarity. I guess what I'm looking for is a way to simulate kinetic energy without having the object move, like a lab test/model/simulation (I know KE requires velocity, as 1/2mv2).
So what you are saying is, heat will only be generated by the friction forces? How could I translate motion (KE) into heat generation (if that's even possible)?
Other than making the object move through the air, or the air move over the object, I don't know. I'm sure you can simulate it, but I do not have any experience in that area.
Also, I'm not clear on why you think compressing an object would simulate motion.
well by compressing it you would only simulate one part of what happens when the object is in motion through a medium like atmosphere.compressing things especially liquids and gases does increase their temperature bt it's not the whole picture , by compressing what you want to compress you would only get one little aspect of what your after.
Maybe you need to explain what exactly is that which you want to simulate? A rock faling through air towards Earth like a meteoryte ? a metal ball falling from a plane ? what is that you want to know out of your test?
Or maybe you want to simulate the pressure on the traveling object by just pressing on it with the same force?
Basically I want to simulate a closed system that is completely insulated (no heat would come from the atmosphere). If this object is moving super fast, would any heat generate internally because of the kinetic energy of the entire closed system?
Are you thinking that just because something is moving fast that it will somehow 'heat up'? (Apart from interaction and collision with other things, such as the atmosphere.)
Yeah, I was just curious if the high velocity and KE would cause a temperature rise. Guess I was wrong, thanks everybody for the help!
How fast are you moving while standing still?
The solar system is revolving around the centre of the Milky Way at 568,000 m.p.h.
Valid point CWatters, I never even thought of that. That was really helpful.
  • · Replies 73 ·
  • · Replies 17 ·
21K
  • · Replies 23 ·
  • · Replies 32 ·
