Relative angle after Compton scattering?
4 replies · 3K views · last reply
skrat
Photon with ##\lambda =10^{-12} m## hits an electron (Compton scattering). After the interaction the photon and electron move under relative angle of 90°. Calculate the kinetic energy of electron. Hint: First find the relation between ##\theta ## and ##\varphi##. (##\theta +\varphi = 90°##)
I can't find the relation! How on Earth can I find it?
The only thing I get from components of momentum is: ##\frac{hc}{\lambda ^{'}}sin\theta =cp_esin\varphi ##
But this doesn't help me much... or does it? O.o
Please help.
Use energy conservation together with momentum conservation. Alternatively, find a formula for the electron momentum and λ′ as function of the two angles.
Ok...
##cp_esin\varphi =E_{\gamma }^{'}sin\theta ## and therefore ##\frac{cp_esin\varphi }{sin\theta }=E_{\gamma }^{'}##
momentum conservation along x axis:
##E_{\gamma }=cp_ecos\varphi +E_{\gamma }^{'}cos\theta ## using the last expression above:
##cp_e=\frac{E_\gamma }{cos\varphi +sin\varphi ctg\theta }##
so If I now insert this to ##cp_esin\varphi =E_{\gamma }^{'}sin\theta ## than:
##E^{'}=\frac{E_\gamma }{sin(\varphi +\theta )}##
But I can't see how this helps me?
##cp_e=\frac{E_\gamma }{cos\varphi +sin\varphi ctg\theta}## and ##cp_esin\varphi =E_{\gamma }^{'}sin\theta##
so
##\frac{E_\gamma }{cos\varphi +sin\varphi ctg\theta}sin\varphi =E_{\gamma }^{'}sin\theta##
##\frac{E_\gamma }{sin\theta cos\varphi +sin\theta sin\varphi ctg\theta}sin\varphi =E_{\gamma }^{'}##
##sin\theta cos\varphi +sin\theta sin\varphi ctg\theta=sin\theta cos\varphi+sin\varphi cos\theta =sin(\varphi + \theta )##
##\frac{E_\gamma }{sin(\theta +\varphi )}sin\varphi =E_{\gamma }^{'}##
I know it doesn't like right... :D That's why I am here asking.. :/
