Relative Centripetal Acceleration
The discussion revolves around the concept of relative centripetal acceleration experienced by two individuals on spinning rings that rotate in opposite directions. Participants explore the implications of different reference frames, the nature of centrifugal and Coriolis forces, and the effects of these forces on perceived motion and acceleration.
  • Some participants propose that from the perspective of person A, they are stationary while person B appears to be spinning at a higher speed, leading to confusion about the calculation of centripetal acceleration.
  • Others argue that the centrifugal force experienced by the individuals is an inertial force in the rotating frame, while the centripetal force is the actual force acting on them from the rings.
  • A later reply introduces the Coriolis force, suggesting that it must be considered alongside centrifugal force when analyzing the motion from person A's perspective.
  • One participant questions the relationship between Coriolis force and centrifugal force, noting their perpendicular directions and whether the effects would change with larger rings.
  • Another participant clarifies that the Coriolis force arises from a velocity vector that is not parallel to the angular velocity, challenging earlier misconceptions about its nature.
  • Discussion includes the behavior of gyroscopes in different frames of reference, emphasizing the distinction between inertial and non-inertial frames and their implications for understanding motion.
  • Some participants express uncertainty about the role of time dilation in this context, with suggestions that the discussion remains within classical physics rather than relativistic considerations.
Participants express differing views on the interpretation of forces in rotating frames, the nature of the Coriolis force, and the implications of reference frames. There is no consensus on the resolution of these issues, indicating ongoing debate and exploration.
Limitations include potential misunderstandings of the Coriolis force, the distinction between inertial and non-inertial frames, and the implications of time dilation, which remain unresolved in the discussion.
Ryan Reed
Let's say you have two rings. Both rings have the same radius and are aligned so that the holes are perfectly parallel to each other and a straight line can be drawn through them without interference. Both rings spin along the same axis with the same speed, but in opposite directions.
If you put a person on ring A and a person on ring B, they both experience the centripetal force of acceleration that pushes them towards the outside of the ring.
Here is what I cannot understand.
From the perspective of person A, he is not spinning. Both ring A and himself are stationary with some force that is pushing himself away from the center of his ring. But in reality, ring A is spinning at a speed of V, and to person A, person B should be spinning with a speed of 2V as he is spinning in the opposite direction.
If person A knows of the centripetal acceleration formula, they would calculate person B's acceleration as (2V)^2/R.
Person B's actual acceleration is only V^2/R, just like person A's, but person A would see the other's acceleration as (2V)^2/R, which is 4 times what it actually is.
Is there an error to my thought process, and if so what am I missing?
In this universe there are no stars, no planets, just the two rings and the two people.
Let us start by getting the concepts clear. It is the centrifugal force (i.e., the inertial force in the respective rotating frames) that pushes the persons towards the outside of the ring. The centripetal force is the force from the rings on the persons and that is a very real force that is present regardless of looking at it in a rotating frame or not.
You are missing the fact that (seen from the rotating reference frame of A), B is moving. As such, there will be a Coriolis force on top of the centrifugal force.
Your situation can actually be simplified with the same kind of "paradox". Consider B to be stationary in the inertial frame. There are then no forces acting on B, but in the rotating frame of A, B is subject to a centrifugal force that is exactly canceled by the Coriolis force.
I do not think I fully understand. The Coriolis Force is caused by the difference of the change in angle as you travel farther from the center point right? So the head would experience different centrifugal forces than the feet.
And you are right, I did not account for those forces when thinking about this.
But I am still missing something because I can't see how the Coriolis force could counteract the centrifugal forces as they operate in directions that are perpendicular(centrifugal pointing from the center of the ring, and Coriolis pointing tangent to the circumference). Would this be different if the rings were large enough to make the Coriolis forces negligible?
I also forgot the mention that both person A and person B are already up to speed with the ring and are planted firmly on its surface and are not falling towards the outside.
No, this is not correct. It is caused by a velocity vector that is not parallel to the angular velocity.
This is not correct either. It is only correct when the velocity is radial. When the velocity is tangential, the Coriolis force is radial.
Suppose person A has a gyroscope. The gyroscope points in the same direction in an inertial frame of reference. But in your "perspective of person A", the gyroscope doesn't point in the same direction, it's axis of rotation precesses. How does person A explain this? It's not due to "centrifugal force". That force doesn't cause a gyroscope to precess. This is an important difference from "the perspective of person A" as compared to an inertial frame of reference. Clearly, there is something different about person A's perspective, and it's not just "centrifugal force". One way of describing the difference is to introduce the coriolis force, but the basic issue is assuming that the "perspective of person A" is the same as an inertial frame.
Gyroscopes can be physical, or implmented with lasers as in a ring laser gyroscope. It's hard to describe the details of the behavior of "the perspective of person A" without mathematics, but these simple thought experiments can show the need for thought on the matter.
Note that we have by no means completely described "the perspective of person A". Notably missing is a discussion of the behavior of clocks according to "the perspective of person A", which don't all tick at the same rate, unlike an inertial frame.
So the gyroscope, if in an inertial frame, would keep its angle the same, but in this case it would precess? And that an inertial frame is different from a perspective? Is this correct?
And are you saying that if we include time dilation, it would help solve this problem?
What do you mean by "a perspective"? An inertial frame is different from a non-inertial frame. In the typical non-inertial frame in classical mechanics, you both have the possibility of the frame origin accelerating as well as the basis vectors rotating. It is common to refer to a non-inertial frame as an object's rest frame if its position and orientation relative to that frame remains the same. Such a frame is not necessarily inertial.
No, this is a purely classical issue as long as you do not start rotating at relativistic speeds. I believe @pervect is going beyond your question due to your post being in the relativity forums (the classical physics forum would have been a better placement).
Basically yes, an inertial frame is different from what I think you mean by perspective.
As far as the time dilation goes, I'm basically thinking that your question is purely Newtonian
THe thought occurs to me that perhaps you are talking about rotation being relative, rather than the special theory of relativity. The short answer to that revised question is that rotation is not relative, one can tell by experiments (as with the gyroscope, for instance) if one is rotating or not.
  • · Replies 24 ·
  • · Replies 16 ·
  • · Replies 37 ·
  • · Replies 22 ·
  • · Replies 16 ·
