Relative Motion Calculations: Solving for Time and Heading
In summary, a person can walk up a stalled escalator in 90 seconds and be carried up in 60 seconds when standing still on the same escalator in motion. It would take them 36 seconds to walk up the moving escalator and they could walk down the escalator while it was moving up in the same amount of time. For the flight, the pilot must use a heading of 52 degrees north of east and an air speed of 460 km/h to make a flight of 300 km northeast in 45 minutes with a constant wind of 80 km/h from the north.
52
A person walks up a stalled escalator in a department store in 90s. when standing still on the same escalator in motion, he is carried up in 60s
A) how much time would it take him to walk up the moving escalator?(36s)
B)Could he walk down the escalator while it was moving up? if so, how long would it take?
A pilot wishes to make flight of 300 km [NE] in 45 min. On checking with the meteorological office, she finds that there will be a wind of 80km/h from the north for the entire flight. What heading and air speed must she use for the flight? (52 N of E, 460 Km/h)
I spend 2 hours this evening trying to do these problems, but for these 2, I couldn't manage to even draw a proper diagram for :frown: ... For the last question, I tried to draw it, but the resultant vector wasn't matching with the answer, so obviously it was wrong...
Let ve be the speed of the escalator, vw be your walking speed. Let the length of the escalator be x. You know rate x time = distance, so
60ve = x
and
90vw = x
Therefore, 60ve = 90vw
vw = (2/3)ve
Can you work it from there?
I tried to work it out but doesn't that just restate the fact that walking is 2/3 times slower than escalator? Which you've already concluded from the 60 sec to 90 sec ratio...
This is really just like those "joint work" problems ("Billy can do a job in 2 hours, Rita can do the same job in 3 hours, how long would it take them working together?")
The persons speed, walking only, is
[tex]\frac{1}{90}\frac{"escalator"}{second}[/tex]
Riding the escalator without walking, the speed is
[tex]\frac{1}{60}\frac{"escalator"}{second}[/tex]
Walking with the escalator going, the speeds add. The person's speed is
[tex]\frac{1}{90}+ \frac{1}{60}= \frac{5}{180}\frac{"escalator"}{second}[/tex]
The time to go up the escalator ("seconds per escalator") is the reciprocal of that:
180/5= 36 seconds.
First, draw a picture. The desired flight is "300 km [NE]" and she wants to fly that in 45 min. Okay, here "net" velocity vector must be 300/(3/4)= 400 km/hr (45 min is 3/4 hr). Draw a line at 45 degrees to the horizontal and to the right (NE) with "length" 400 km/hr. The wind is blowing from the north at 80 km/hr so draw a line up from your first line, with "length" 80 km/hr. Finally, draw the third line of the triangle- that will be the "heading" vector of the airplane. If you like you can draw "arrow heads" showing the direction along those lines. Notice that the arrow head on the "wind" vector is at the bottom. You want the first vector you drew to be the sum of the other two. That's why you drew the wind vector "from the north" upward.
As always, there are two ways to do vector problems like this. One would be to break everything into coordinates. The coordinates for the wind are easy: 0i- 80j (i is to the east and j to the north, of course). The coordinates for the "true path" require trig: 400 cos(45)i+ 400 sin(45)j. Call the "heading" vector xi+ yj and add:
xi+ (y-80)j= 400 cos(45)i+ 400 sin(45)j. That gives you two equations (treat the i and j components separately) to solve for x and y.
However, since you give vectors by length and heading and give the answer that way, I suspect that you are intended to solve this by "solving the triangle". You have a triangle with two given sides of lengths 80 and 400. If you look closely at the triangle, you will see that the angle between those sides is 90+45= 135 degrees.
You can use the cosine law to solve for the length of the third side (the speed the airplane should make through the air) and then the sine law to find the angle inside the angle, at the origin. Adding that to the 45 degrees that first side is from the horizontal gives the airplanes heading (N of E).
Likes mariamelazab
Ok I got it, thanks.
What is relative motion?
Relative motion is the movement of an object in relation to another object or frame of reference. It takes into account the velocity and direction of both objects.
How do you solve relative motion problems?
To solve relative motion problems, you must first identify the two objects and their velocities. Then, you can use vector addition and subtraction to determine the resulting velocity of one object relative to the other.
What is the difference between relative motion and absolute motion?
Absolute motion refers to the movement of an object in relation to a fixed point or frame of reference, such as the Earth. Relative motion, on the other hand, takes into account the movement of two objects in relation to each other.
Can relative motion affect the speed of an object?
Yes, relative motion can affect the speed of an object. If two objects are moving in the same direction, the relative motion will result in a faster speed. However, if they are moving in opposite directions, the relative motion will result in a slower speed.
How is relative motion used in real life?
Relative motion is used in various fields such as transportation, physics, and navigation. For example, pilots must take into account the relative motion of their aircraft in relation to other planes and air currents when flying. It is also used in traffic engineering to determine the best routes and traffic patterns.
