Relative velocity of Electromagnetic waves
The discussion centers on calculating the relative velocity of electromagnetic waves emitted by oxygen atoms in a distant galaxy, with observed frequencies of 5.71 * 10^14 Hz and 5.841 * 10^14 Hz. The initial calculation yielded a relative velocity of 3.3641 * 10^6 m/s, which was incorrect; the correct value is 6.724 * 10^6 m/s. The error stemmed from a misunderstanding of the formula Vrel = [(F(observed) - F(Source))/(2*F(Source))] * c, where the factor of 2 in the denominator was misinterpreted. The discussion highlights the importance of correctly applying the formula to avoid calculation errors.
  • Understanding of electromagnetic wave frequency and its relation to velocity
  • Familiarity with the formula for calculating relative velocity of astronomical objects
  • Knowledge of the speed of light (c) as a constant in physics
  • Basic grasp of astronomical observation techniques
  • Review the derivation of the formula Vrel = [(F(observed) - F(Source))/(2*F(Source))] * c
  • Study the Doppler effect and its application in astronomy
  • Learn about the implications of frequency shifts in electromagnetic waves
  • Explore different references and sources for astronomical formulas
Astronomers, physics students, and anyone interested in understanding the calculations related to the relative motion of celestial objects and electromagnetic wave behavior.
Eng67
I have a problem that I cannot get the correct answer.
An Astronomer observes electromagnetic waves emmitted by oxygen atoms in a distant galaxy that have a frequency of 5.71 *10^14 Hz. On earth, oxygen atoms emit waves that have a freq. of 5.841 *10^14. What is the relative velocity of the galaxy with respect to the astronomer on earth.
Vrel = [(5.710*10^14 - 5.841*10^14)/(2*5.841*10^14)] * (3.00 *10^8)
answer = 3.3641 *10^6 m/s
What is wrong with my calculations?
The correct answer is 6.724 * 10^6 m/s
Thanks
Notice your answer is off by a factor of 1/2. Recheck the formula you used and you'll see there should be a 2 in the denominator.
By the way- your title, "Relative velocity of Electromagnetic waves", is very misleading! Obviously the velocity of electromagnetic waves (light) is, relative to anything, the speed of light, c. What you see different from another observer is the frequency which is what allows you to calculate the velocity of the source relative to you.
This formula already has the 2 in the denominator. To get the correct answer, It would need to be 4*F(Source)?
I cannot find anything to support this.
I mistyped, obviously I meant there shouldn't be a two in the denominator. Check your reference.
Thanks.
I finally found the correct reference for this formula. Many sources have this listed differently.
