How Is the Kinetic Energy of a Proton Calculated in an Electric Field?
The kinetic energy (KE) of a proton in a uniform electric field of 5.0 x 106 V/m, accelerated over a distance of 1 km, is calculated using the formula KE = q * E * s. The correct calculation yields a kinetic energy of 5000 MeV, confirming the user's result. The discrepancy with the book's value of 500 MeV is attributed to a potential error in the book's calculations, as the potential difference calculated is 5000 MV, which aligns with the user's findings.
  • Understanding of electric fields and their properties
  • Familiarity with the concept of kinetic energy
  • Knowledge of unit conversion between joules and mega-electronvolts (MeV)
  • Basic principles of electrostatics, including charge and potential difference
  • Study the derivation of kinetic energy in electric fields using classical mechanics
  • Learn about the relationship between electric field strength and potential difference
  • Explore unit conversion techniques between joules and MeV in particle physics
  • Investigate common errors in physics textbooks regarding electric field calculations
Physics students, educators, and anyone interested in understanding the principles of kinetic energy in electric fields and resolving discrepancies in textbook problems.
Peter G.
Hi,
A proton initially at rest finds itself in a region of uniform electric field of magnitude 5.0 x 106 Vm-1. The electric field accelerates the proton for a distance of 1 km.
Find the kinetic energy of the proton.
So, what I did was the following:
KE = q * E * s
I then converted the result from J to MeV. I, however, get 5000 MeV and the book gets 500 MeV. Is my line of thought incorrect?
Thanks once again!
Your answer is right for the given numbers.
Thanks! I checked and rechecked my calculations and numbers several times before posting here and I was about to go crazy! I guess the book made a mistake (everyone has the right to!)
Given the numbers for the electric field and distance, you should be able to calculate the potential difference of 5000 MV between the two endpoints. Because the proton has charge e, to get the work done, you just stick an e in front of the V in the units. If you do that, you can see pretty easily 5000 MeV is correct. You don't need to worry that you made a mistake while converting units.
  • · Replies 54 ·
11K
11K
