Relativistic equations vs classical
The discussion revolves around the comparison of Galilean and Lorentz equations for position, specifically examining the relative speed at which their outputs differ by 1%. The subject area includes concepts from classical mechanics and special relativity.
  • Participants explore how to express the difference between the Galilean and Lorentz equations as a percentage, questioning what the 1% difference should be based on. There are attempts to clarify the meaning of the equations and the implications of the factor of gamma in the relativistic equation.
The discussion is active, with participants questioning the assumptions behind the equations and the meaning of the percentage difference. Some guidance has been offered regarding the relationship between the equations and the factor of gamma, but no consensus has been reached on the specific approach to take.
Participants note the ambiguity in defining the 1% difference and the implications of gamma being greater than or equal to 1. There is also mention of a potential extension of the problem to kinetic energy, raising further questions about the relationship between classical and relativistic expressions.
phyguy321
At what relative speed will the Galilean and the Lorentz expressions for position x differ by 1%? What fraction of the speed of light is this?
G- x' = x - vt
L- x' = [tex]\gamma[/tex]x - vt
I don't know what I am trying to do exactly.
G-L = .01
G = .99L
G = L + .01L
Do any of these seem relevant?
The second one seems relevant. Can you explain why you wrote these down and what you think they mean?
I was trying to figure out how to make them differ by 1%. would we say that at some speed they are equal and so when G = 1.01L then G is 1% less than L then solve for v or the v that's inside the gamma?
G- x' = x - vt
G-L = .01
This makes no sense! A % is always of a % of something!
[/quote]G = .99L
G = L + .01L
Do any of these seem relevant?[/QUOTE]
You want G and L to differ (G- L or L- G) by 1% of something. 1% of what? Possible choices are G-L= 0.01L so G= 1.01L, G- L= 0.01G so L= 0.99G, L- G= 0.01L so G= 0.99L, or L- G= 0.01G so L= 1.01G. Is [itex]\gamma[/itex] always larger than or always less than 1? That would affect which of these can be true.
The two equations are different only because of the factor of [itex]\gamma[/itex] in the relativistic equation. So, you have to figure out for what speed [itex]\gamma=1.01[/itex]. Note that [itex]\gamma[/itex] is never less than 1 [prove that yourself], and so there is no real ambiguity in the question here.
Ok that makes sense, now what if we wanted the kinetic energies to differ by 1%? so
1/2mv^2 and [tex]\gamma[/tex]mc^2 - mc^2 differ by one percent? do i plug in the velocity from part a into the gamma and solve for v in the classical equation?
No, of course you don't use the same velocity as from part a, because the classical and relativistic kinetic energies do not simply differ by a factor of [itex]\gamma[/itex]. Since the relativistic kinetic energy is always larger than the classical one, there is again no ambiguity in how to make them differ by 1 percent.
