A Relativistic generalization of Newton’s equation
Zak
If say you have some scalar field, θ(x^u), where x^u represents the 4-vector coordinates of spacetime, and then the typical classical equation of motion, a = -∇θ, how would one go about 'generalizing' this to a relativistic version? Since F = ma, would you have to write it as d/dt (P^u) where P^u is the relativistic 4-momentum? But since P^0 = m, this means that the 0 component of the 4-vector simply vanishes, and this seems unsatisfactory to me since you're essentially just keeping everything Newtonian. Can anybody shed some light on this?
(sorry for the bad notation)
Thanks in advance
Newtonian physics applies as long as you stay inside one inertial reference frame.
Relativity is all about the differences between observers.
For the general results, you want to look up "relativistic mechanics" and hunt down "equation of motion".
Yes, this is how you define the 4-force used in special relativity. However, note that the usual thing to do is to define the 4-force as the derivative of the momentum with respect to the proper time of the object, not the coordinate time - which is frame dependent.
Zak said:
But since P^0 = m
This is incorrect. By definition, ##P^0 = m\gamma##, where ##\gamma## is the Lorentz factor. You also have to use the relativistic momentum for the spatial part of the 4-momentum.
This is not really true. Newtonian mechanics breaks down at speeds close to the speed of light regardless of whether you consider only one inertial frame or not.
It is also unclear what you mean by "stay inside one inertial reference frame". Physics applies equally to all inertial frames and any object that exists in one frame exists also in another.
The most intuitive way to guess equations of motion is to use the manifestly covariant action principle. For free particles you have
$$S_0=-m c^2 \int \mathrm{d} \lambda \sqrt{\eta_{\mu \nu} \dot{x}^{\mu} \dot{x}^{\nu}},$$
where ##\eta_{\mu \nu}=\mathrm{diag}(1,-1,-1,-1)## is the Minkowski-pseudometric and ##\lambda## an arbitrary scalar parameter to parametrize the world line. The Lagrangian is parametrization invariant, and that's why in fact only 3 equations are independent.
To get the interaction with an external scalar field, the most simple way to get a consistent equation of motion is to use again a parametrization-invariant scalar, and the most simple one is
$$S_{\text{int}}=-\int \mathrm{d} \lambda \Phi(x) \sqrt{\eta_{\mu \nu} \dot{x}^{\mu} \dot{x}^{\nu}}.$$
Then the Euler-Lagrange equations lead to the equations of motions,
$$(m+\phi) \ddot{x}^{\mu}=(\eta^{\mu \nu}-\dot{x}^{\mu} \dot{x}^{\nu})\partial_{\nu} \phi.$$
As you see, thanks to the manifest covariance and the parametrization independence you get the correct constraint condition enabling the on-shell condition for the four-momentum,
$$\dot{x}_{\mu} \ddot{x}^{\mu}=0.$$
Unfortunately I was called away from the computer before I could finish the thought... but that's why the suggestions for what to look for.
All quantities should be measured in the same frame... no using measurements from different frames in the same equation without the appropriate transformation.
I won't complete the thought left dangling since (a) good search terms are given, and (b) vanhees has a nice starter.
Likes vanhees71
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. The Relativator was sold by (as printed) Atomic Laboratories, Inc. 3086 Claremont Ave, Berkeley 5, California , which seems to be a division of Cenco Instruments (Central Scientific Company)... Source: https://www.physicsforums.com/insights/relativator-circular-slide-rule-simulated-with-desmos/ by @robphy
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
